[Ovmsdev] 3.2.018 release
Fri Nov 19 05:24:28 HKT 2021
Sounds OK for me.
Regarding using the platform revision instead of CONFIG_OVMS_HW_BASE_3_x
config: so in case someone accidentally installs the wrong firmware, the
system would heal itself by a simple OTA update? Sounds good and should
be a simple change.
Am 18.11.21 um 08:06 schrieb Mark Webb-Johnson:
> We need to get the v3.3 release ready for release now, as the new v3.3
> hardware is about to enter production and the factory needs the firmware.
> Accordingly, I suggest:
>  1. I have already updated the for-v3.3 branch with all the recent
>     changes from v3.2.
>  2. We now (today/tomorrow) release the current v3.2 branch as tag
>     3.2.018, OTA release. This would be the (hopefully) last v3.2 release.
>  3. After release of that, we branch off master to a v3.2 branch, for
>     historical purposes (and if we need it for anything).
>  4. We then merge back for-v3.3 into the master branch and start
>     working through the usual daily builds for that to get it ready
>     for production. I think there is still some work to do on pouring
>     the plugins, but the core code (and in particular new modem
>     support) should be ok now.
> I think we will need to investigate an approach for dual builds for
> v3.3-or-later and pre-v3.3 hardware, to take advantage of the new
> ESP32 rev3 chips. I think those will require a different sdkconfig. We
> can do that automatically in the OTA system, by building the URL based
> on the ESP32 platform revision. Should we do that with the v3.3
> release (even if the builds are for the moment the same), or at a
> later date?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211118/3c676fe2/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211118/3c676fe2/attachment.sig>
