[Ovmsdev] Update from master
Shane @ Kilve Engineering
shane at kilve-engineering.co.uk
Tue Nov 2 03:44:49 HKT 2021
Hi all I ve just done an update from ovms master and gone to do a build and got given lots of options to select?
Now my builds won’t connect to v2 server
Regards
Shane
shane at Shanes-MacBook-Pro OVMS.V3 % make
Toolchain path: /Users/shane/.espressif/tools/xtensa-esp32-elf/1.22.0-97-gc752ad5-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-97-gc752ad5
Compiler version: 5.2.0
GENCONFIG
* Restart config...
* System Options
Stack size for command execution (OVMS_SYS_COMMAND_STACK_SIZE) [6144] 6144
Task priority for command execution (OVMS_SYS_COMMAND_PRIORITY) [5] (NEW)
Queue size for file logging (OVMS_LOGFILE_QUEUE_SIZE) [100] 100
Task priority for file logging (OVMS_LOGFILE_TASK_PRIORITY) [2] 2
* Include the GPL licensed MONGOOSE networking library (web server, etc)
Include the GPL licensed MONGOOSE networking library (web server, etc) (OVMS_SC_GPL_MONGOOSE) [Y/n/?] y
Enable MONGOOSE filesystem support (MG_ENABLE_FILESYSTEM) [Y/n/?] y
Enable MONGOOSE directory listing support (MG_ENABLE_DIRECTORY_LISTING) [Y/n/?] y
Enable MONGOOSE SSL/TLS support (MG_ENABLE_SSL) [Y/n/?] y
Select the MONGOOSE SSL/TLS library to use
> 1. mbedTLS (MG_SSL_IF_MBEDTLS) (NEW)
2. WolfSSL (MG_SSL_IF_WOLFSSL) (NEW)
choice[1-2?]: 2
Enable MONGOOSE debug logging (MG_ENABLE_DEBUG) [N/y/?] n
* Library Support
Select the OVMS javascript library to use
1. No javascript support (OVMS_SC_JAVASCRIPT_NONE)
> 2. Use the MIT licensed DUKTAPE library (OVMS_SC_JAVASCRIPT_DUKTAPE)
choice[1-2?]: 2
Include the GPL licensed WOLFSSH and WOLFSSL libraries (ssh server) (OVMS_SC_GPL_WOLF) [Y/n/?] y
Include ZIP archive support (OVMS_SC_ZIP) [Y/n/?] y
JavaScript (DukTape) task stack size (OVMS_SC_JAVASCRIPT_DUKTAPE_STACK) [12288] 12288
JavaScript (DukTape) task queue size (OVMS_SC_JAVASCRIPT_DUKTAPE_QUEUE_SIZE) [40] 40
JavaScript (DukTape) task priority (OVMS_SC_JAVASCRIPT_DUKTAPE_PRIORITY) [3] 3
Enable Javascript (Duktape) dedicated heap memory management (OVMS_SC_JAVASCRIPT_DUKTAPE_HEAP_UMM) [Y/n/?] (NEW)
Javascript/Duktape default size of dedicated memory chunk (KB) (OVMS_SC_JAVASCRIPT_DUKTAPE_HEAP_UMM_DEFAULTSIZE) [512] (NEW)
Javascript/Duktape size of a memory block (bytes) (OVMS_SC_JAVASCRIPT_DUKTAPE_HEAP_UMM_BLOCKSIZE) [32] (NEW)
# configuration written to /Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/sdkconfig
App "ovms3" version: 3.2.014-1137-g8bc1c599-dirty
Python requirements from /Users/shane/esp-idf/requirements.txt are satisfied.
Building partitions from /Users/shane/Open-Vehicle-Monitoring-System-3-MGEV/vehicle/OVMS.V3/partitions.csv...
CC build/bootloader/bootloader_support/src/bootloader_clock.o
CC build/bootloader/bootloader_support/src/bootloader_common.o
CC build/bootloader/bootloader_support/src/bootloader_flash.o
CC build/bootloader/bootloader_support/src/bootloader_flash_config.o
CC build/bootloader/bootloader_support/src/bootloader_init.o
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211101/b11431fa/attachment.htm>
