[Ovmsdev] Poller support for VW TP 2.0
Mon May 31 05:00:29 HKT 2021
Everyone interested in VW/VAG vehicles: I've added a first
implementation of the VW TP 2.0 protocol in the vehicle poller.
I've pushed this to a new branch for testing:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/tree/vwtp20
This includes refactoring the ISO TP engine into a separate module, so
may introduce bugs with that. Please do not introduce larger changes in
the master poller code until we've tested and merged this change.
The VW TP 2.0 engine is based on the explanation by Jared Wiltshire
(https://jazdw.net/tp20) plus some observations & tests I've made with
my Seat Mii.
I've added a text version of Jared's page in the vehicle docs folder:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/vwtp20/vehicle/OVMS.V3/components/vehicle/docs/VW-TP-2.0.txt
VW TP 2.0 polls integrate seamlessly into an existing poller list and
can also be sent as single OBD requests. Quoting from vehicle.h:
// VWTP_20: this protocol implements the VW (VAG) specific "TP 2.0",
which establishes
// OSI layer 5 communication channels to devices (ECU modules) via a CAN
gateway.
// On VWTP_20 poll entries, simply set the TXID to the gateway base ID
(normally 0x200)
// and the RXID to the logical 8 bit ECU ID you want to address.
// TP 2.0 transports standard OBD/UDS requests, so everything else works
the same way
// as with ISO-TP.
// VW TP 2.0 poll entry examples:
//   // TXID, RXID,  TYPE,    PID,      TIMES,  BUS,  PROT
//   { 0x200, 0x1f,  0x10,   0x89,  {…times…},    0,  VWTP_20 }
//   { 0x200, 0x1f,  0x22, 0x04a1,  {…times…},    0 , VWTP_20 }
// VW gateways currently do not support multiple open channels. To
minimize connection
// overhead for successive polls to an ECU, the VWTP_20 engine keeps an
idle connection open
// until the keepalive timeout occurs. So you should try to arrange your
polls in interval
// blocks/sequences to the same devices if possible.
// To explicitly close a VWTP_20 channel, send a poll (any type) to RXID
0, that just
// closes the channel (ECU ID 0 is an invalid destination):
//   { 0x200,    0,     0,      0,  {…times…},    0 , VWTP_20 }
To manually send a request, use the "-v" option on the OBD request
command to select VW TP 2.0, e.g.:
OVMS# obd can1 req dev -v 200 1f 22f197
200[1f] 22f197: Response:
47 57 2d 4b 2d 43 41 4e 20 54 50 32 30          | GW-K-CAN TP20
To manually close a channel from the shell, issue:
OVMS# obd can1 req dev -v 200 00 0000
Feedback, code audits & tests are welcome.
If you encounter errors or misbehaviour, please send me a debug log
including the CAN range 200-3ff:
OVMS# log level debug vehicle-vwtp
OVMS# can log start monitor crtd 200-3ff
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210530/4dfc3674/attachment.sig>
