[Ovmsdev] Generator / V2G metrics
Mon May 24 19:38:41 HKT 2021
Derek,
nice work! So the "first" once again goes to the Leaf :-)
Of course you can extend the V2 message protocol. Maybe introduce a new
message type for that, as "S" and "D" already are quite loaded.
The grid log already contains the generator metrics and should be
triggered by a change to the gen state metric as well. That's meant to
log sessions though, not to transport live data.
Car support shouldn't be a parameter (= user config) though, it should
be a property of the car adaption. Car capabilities have been on the
rework todo list for some time.
Am 24.05.21 um 08:58 schrieb Derek Caudwell:
> Hi all,
> In case it is helpful to others here is a sample output of the V2G
> metrics populated for the Leaf from a recent session. Note I've opted
> for presenting the Chademo voltage, current and power output (as the
> grid voltage and inverter efficiency is not known -external to car-
> but nominal grid voltage could be set with a parameter and then
> calculated).
> v.g.climit 19.8939A
> v.g.current
7.5A
> v.g.duration.empty 533Min
> v.g.duration.range
> v.g.duration.soc
> v.g.efficiency
> v.g.generating yes
> v.g.kwh 0.0562549kWh
> v.g.kwh.grid
> v.g.kwh.grid.total
> v.g.limit.range
> v.g.limit.soc
> v.g.mode standard
> v.g.pilot
yes
> v.g.power 2.8275kW
> v.g.state exporting
> v.g.substate onrequest
> v.g.temp
> v.g.time 104Sec
> v.g.timermode
> v.g.timerstart
> v.g.type chademo
> v.g.voltage
377V
> Michael, is it possible to have v.g metrics added to the V2 server
> message format for incorporating into the ovms app?
> Is it worth having a parameter to indicate car support for V2G
> functionality?
> Cheers Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210524/58eaa45d/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210524/58eaa45d/attachment.sig>
