[Ovmsdev] OVMS going comatose
Stephen Casner
casner at acm.org
Mon Mar 29 23:26:29 HKT 2021
Michael,
It seems the NetMan loop is not endless, just long, since the two
events I've reported look very similar but the WDT did not occur in
the one I reported from the file log and in both cases normal
operation resumed. Actually, almost normal. In one case I found that
ssh connection attempts timed out although telnet worked, so I had to
reboot again. I don't recall encountering that situation before.
On Mon, 29 Mar 2021, Michael Balzer wrote:
> Steve,
> that might be the first real clue about the WDT issue, possibly in combination
> with Mark's finding of a corrupted netif list.
> Maybe the NetMan task was running some endless loop due to an unclean modem
> (ppp) shutdown?
> A modem reboot is currently necessary once in a while when the modem gets
> stuck. We should investigate the shutdown sequence if that happens with a
> connection in use.
> Am 29.03.21 um 02:37 schrieb Stephen Casner:
> > On Sun, 28 Mar 2021, Stephen Casner wrote:
> > > BTW, I did also get a WDT error after resetting on the previous lockup
> > > (before file logging), and after the reset this time there was a hang
> > > that did not last long enough to trigget the WDT. Log segment below.
> > I just remembered that I still had the log output from the USB console
> > for the previous lockup where the WDT error occured. Both began after
> > "simcom: Power Cycle". Log segment below.
> > -- Steve
> > I (31990) simcom: State timeout, transition to 2
> > I (31990) simcom: State: Enter PoweringOn state
> > I (31990) simcom: Power Cycle
> > W (32660) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > I (32670) webserver: HTTP GET /cfg/logging
> > W (34820) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (36940) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > I (38900) simcom: State: Enter PoweredOn state
> > W (41220) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (43420) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (43430) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 72 drops
> > W (45560) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (45570) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 8 drops
> > W (47740) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (47750) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 7 drops
> > W (48990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (49870) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (49880) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 9 drops
> > W (49990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (50990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (51930) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (51940) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 11 drops
> > W (51990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (52990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (53990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (54050) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 11 drops
> > W (54060) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (54990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (55000) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (55990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (56140) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (56150) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 12 drops
> > W (56990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (57990) script: DuktapeDispatch: msg type 3 lost, queue full
> > I (57990) simcom: State: Enter MuxStart state
> > I (58000) gsm-mux: Start MUX
> > W (58000) script: DuktapeDispatch: msg type 3 lost, queue full
> > I (58000) gsm-mux: Channel #0 is open
> > I (58010) gsm-mux: Channel #1 is open
> > I (58020) gsm-mux: Channel #2 is open
> > I (58020) gsm-mux: Channel #3 is open
> > I (58030) gsm-mux: Channel #4 is open
> > W (58220) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (58240) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 18 drops
> > I (58990) simcom: State: Enter NetWait state
> > W (58990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (59000) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (59990) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (60350) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detectedE (75150) task_wdt: Task watchdog got triggered. The following tasks
> > did not reset the watchdog in time:
> > E (75150) task_wdt: - OVMS DukTape (CPU 1)
> > E (75150) task_wdt: Tasks currently running:
> > E (75150) task_wdt: CPU 0: IDLE0
> > E (75150) task_wdt: CPU 1: OVMS NetMan
> > W (60370) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 13 drops
> > I (62480) webserver: HTTP POST /cfg/logging
> > W (62480) webserver: HandleLogin: auth failure for username 'admin'
> > W (62490) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (62510) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 7 drops
> > W (64550) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (66670) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (66690) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 17 drops
> > W (68760) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (68770) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > resolved, 7 drops
> > I (70880) webserver: HTTP POST /cfg/logging
> > I (70890) webserver: HandleLogin: 'admin' logged in, sid 847393266b07789
> > W (70900) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > W (73060) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > I (75070) webserver: HTTP GET /menu
> > W (75100) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow
> > detected
> > I (75110) webserver: HTTP GET /cfg/logging
> > OVMS#
> > W (87900) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (87910) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (87910) script: DuktapeDispatch: msg type 2 lost, queue full
> > W (87920) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (87930) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (87940) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (87950) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (87960) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (87970) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (87980) script: DuktapeDispatch: msg type 3 lost, queue full
> > I (87980) simcom: CREG Network Registration: RegisteredRoaming
> > W (87990) script: DuktapeDispatch: msg type 3 lost, queue full
> > I (87990) simcom: State: Enter NetStart state
> > W (88000) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88010) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88020) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88030) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88040) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88050) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88060) script: DuktapeDispatch: msg type 3 lost, queue full
> > I (88060) simcom: PPP Connection is ready to start
> > I (88060) simcom: State: Enter NetMode state
> > I (88060) gsm-ppp: Initialising...
> > W (88070) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88080) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88090) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88100) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88110) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88120) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88130) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88140) script: DuktapeDispatch: msg type 3 lost, queue full
> > W (88150) websocket: WebSocketHandler[0x3f84b154]: job queue overflow
> > detected
> > W (88150) websocket: WebSocketHandler[0x3f84b3ac]: job queue overflow
> > detected
> > W (88170) websocket: WebSocketHandler[0x3f84b3ac]: job queue overflow
> > resolved, 32 drops
> > W (88590) websocket: WebSocketHandler[0x3f84b154]: job queue overflow
> > resolved, 35 drops
> > I (90870) gsm-ppp: StatusCallBack: None
> > I (90870) gsm-ppp: status_cb: Connected
> > I (90870) gsm-ppp: our_ipaddr = 10.170.41.247
> > I (90870) gsm-ppp: his_ipaddr = 10.64.64.64
> > I (90870) gsm-ppp: netmask = 255.255.255.255
> > I (90870) gsm-ppp: DNS#0 = 212.9.0.135
> > I (90870) gsm-ppp: DNS#1 = 212.9.0.136
> > I (90870) gsm-ppp: our6_ipaddr = ::
> > I (90880) netmanager: MODEM up (with WIFI client up): staying with WIFI
> > client priority
> > OvmsDev mailing list
