[Ovmsdev] OVMS going comatose
    Mon Mar 29 15:52:04 HKT 2021
Steve,
that might be the first real clue about the WDT issue, possibly in
combination with Mark's finding of a corrupted netif list.
Maybe the NetMan task was running some endless loop due to an unclean
modem (ppp) shutdown?
A modem reboot is currently necessary once in a while when the modem
gets stuck. We should investigate the shutdown sequence if that happens
with a connection in use.
Am 29.03.21 um 02:37 schrieb Stephen Casner:
> On Sun, 28 Mar 2021, Stephen Casner wrote:
>> BTW, I did also get a WDT error after resetting on the previous lockup
>> (before file logging), and after the reset this time there was a hang
>> that did not last long enough to trigget the WDT.  Log segment below.
> I just remembered that I still had the log output from the USB console
> for the previous lockup where the WDT error occured.  Both began after
> "simcom: Power Cycle".  Log segment below.
>                                                          -- Steve
> I (31990) simcom: State timeout, transition to 2
> I (31990) simcom: State: Enter PoweringOn state
> I (31990) simcom: Power Cycle
> W (32660) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> I (32670) webserver: HTTP GET /cfg/logging
> W (34820) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (36940) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> I (38900) simcom: State: Enter PoweredOn state
> W (41220) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (43420) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (43430) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 72 drops
> W (45560) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (45570) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 8 drops
> W (47740) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (47750) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 7 drops
> W (48990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (49870) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (49880) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 9 drops
> W (49990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (50990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (51930) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (51940) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 11 drops
> W (51990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (52990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (53990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (54050) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 11 drops
> W (54060) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (54990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (55000) script: DuktapeDispatch: msg type 3 lost, queue full
> W (55990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (56140) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (56150) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 12 drops
> W (56990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (57990) script: DuktapeDispatch: msg type 3 lost, queue full
> I (57990) simcom: State: Enter MuxStart state
> I (58000) gsm-mux: Start MUX
> W (58000) script: DuktapeDispatch: msg type 3 lost, queue full
> I (58000) gsm-mux: Channel #0 is open
> I (58010) gsm-mux: Channel #1 is open
> I (58020) gsm-mux: Channel #2 is open
> I (58020) gsm-mux: Channel #3 is open
> I (58030) gsm-mux: Channel #4 is open
> W (58220) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (58240) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 18 drops
> I (58990) simcom: State: Enter NetWait state
> W (58990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (59000) script: DuktapeDispatch: msg type 3 lost, queue full
> W (59990) script: DuktapeDispatch: msg type 3 lost, queue full
> W (60350) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detectedE (75150) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
> E (75150) task_wdt:  - OVMS DukTape (CPU 1)
> E (75150) task_wdt: Tasks currently running:
> E (75150) task_wdt: CPU 0: IDLE0
> E (75150) task_wdt: CPU 1: OVMS NetMan
> W (60370) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 13 drops
> I (62480) webserver: HTTP POST /cfg/logging
> W (62480) webserver: HandleLogin: auth failure for username 'admin'
> W (62490) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (62510) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 7 drops
> W (64550) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (66670) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (66690) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 17 drops
> W (68760) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (68770) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow resolved, 7 drops
> I (70880) webserver: HTTP POST /cfg/logging
> I (70890) webserver: HandleLogin: 'admin' logged in, sid 847393266b07789
> W (70900) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> W (73060) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> I (75070) webserver: HTTP GET /menu
> W (75100) websocket: WebSocketHandler[0x3f84b22c]: job queue overflow detected
> I (75110) webserver: HTTP GET /cfg/logging
> OVMS#
> W (87900) script: DuktapeDispatch: msg type 3 lost, queue full
> W (87910) script: DuktapeDispatch: msg type 3 lost, queue full
> W (87910) script: DuktapeDispatch: msg type 2 lost, queue full
> W (87920) script: DuktapeDispatch: msg type 3 lost, queue full
> W (87930) script: DuktapeDispatch: msg type 3 lost, queue full
> W (87940) script: DuktapeDispatch: msg type 3 lost, queue full
> W (87950) script: DuktapeDispatch: msg type 3 lost, queue full
> W (87960) script: DuktapeDispatch: msg type 3 lost, queue full
> W (87970) script: DuktapeDispatch: msg type 3 lost, queue full
> W (87980) script: DuktapeDispatch: msg type 3 lost, queue full
> I (87980) simcom: CREG Network Registration: RegisteredRoaming
> W (87990) script: DuktapeDispatch: msg type 3 lost, queue full
> I (87990) simcom: State: Enter NetStart state
> W (88000) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88010) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88020) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88030) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88040) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88050) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88060) script: DuktapeDispatch: msg type 3 lost, queue full
> I (88060) simcom: PPP Connection is ready to start
> I (88060) simcom: State: Enter NetMode state
> I (88060) gsm-ppp: Initialising...
> W (88070) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88080) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88090) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88100) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88110) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88120) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88130) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88140) script: DuktapeDispatch: msg type 3 lost, queue full
> W (88150) websocket: WebSocketHandler[0x3f84b154]: job queue overflow detected
> W (88150) websocket: WebSocketHandler[0x3f84b3ac]: job queue overflow detected
> W (88170) websocket: WebSocketHandler[0x3f84b3ac]: job queue overflow resolved, 32 drops
> W (88590) websocket: WebSocketHandler[0x3f84b154]: job queue overflow resolved, 35 drops
> I (90870) gsm-ppp: StatusCallBack: None
> I (90870) gsm-ppp: status_cb: Connected
> I (90870) gsm-ppp:    our_ipaddr  = 10.170.41.247
> I (90870) gsm-ppp:    his_ipaddr  = 10.64.64.64
> I (90870) gsm-ppp:    netmask     = 255.255.255.255
> I (90870) gsm-ppp:    DNS#0       = 212.9.0.135
> I (90870) gsm-ppp:    DNS#1       = 212.9.0.136
> I (90870) gsm-ppp:    our6_ipaddr = ::
> I (90880) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210329/39e39d1e/attachment-0001.sig>
