[Ovmsdev] Multi frame query
Mon Mar 29 14:58:04 HKT 2021
Didier,
nice find, are you going to submit a PR for this fix?
Am 28.03.21 um 23:46 schrieb didier at ernotte.com:
> Ok, I think I found the issue.
> In
> voidOvmsReToolsPidScanner::IncomingPollFrame(constCAN_frame_t*frame)
> frameLength should not be a 8 bits, it should rather be a 16 bits
> uint8_tframeLength= frame->data.u8[0] & 0x0f;
> Didier
> Le dimanche 28 mars 2021 13 h 40 min 02 s UTC−4, Michael Balzer
> <dexter at expeedo.de> a écrit :
> Didier,
> the PID scanner normally works perfectly with multi frame responses,
> but I haven't had a response that long yet.
> For 1503 bytes, 215 consecutive frames need to be transmitted. The PID
> scanner requests these to be sent with 25 ms separation time, so they
> should need 5.375 seconds.
> Maybe some frame gets lost, or maybe the device doesn't allow a
> separation time that high for a transmission that huge.
> Your log quote wasn't from the re-pid component but from obd2ecu,
> which has nothing to do with the RE tools. You should raise the log
> level for re-pid to see more info. Another tracing option is to use
> the CAN log monitor.
> Btw, you should never need 30 seconds timeout for a PID poll, as the
> scanner checks against the last frame reception.
> Am 28.03.21 um 17:52 schrieb didier at ernotte.com
> <mailto:didier at ernotte.com>:
>> I am investigating some PID with very long data. I am using the PID
>> scanner for this.
>> When I turn on the log level debug , I can see this as the first repy
>> D (1456677) obd2ecu: Rcv 7ec: 8 (15 df 62 48 83 0 0 0)
>> From the Canbus doc, I understand that the first "1x (15)" tells me
>> that this is the first frame of a multi frame, and the length is
>> "5df" . The Pid scanner seems to return only "df", not "5df" data,
>> and I can see in the log that I have around 1500 byte returned, not
>> 220. Any explanation ? anyone see this problem as well ? The scan
>> command is (I had to hack the code to allow timeout > 10sec)
>> re obdii scan start 1 7e4 4883 4883 -r500-7ff -t22 -x30
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
> <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210329/c62e357c/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210329/c62e357c/attachment.sig>
