[Ovmsdev] Branch for-v3.3 network issues
Tue Mar 23 15:02:13 HKT 2021
Mark,
regarding point 2: I've had the same issue with jobs that need to
iterate over the mongoose connection list, I introduced the netmanager
job queue for this to delegate these to the mongoose context.
I remember seeing LwIP has a similar API while browsing the source… yes,
found it: the "tcpip_callback…" functions, e.g.:
  * Call a specific function in the thread context of
  * tcpip_thread for easy access synchronization.
  * A function called in that way may access lwIP core code
  * without fearing concurrent access.
  * @param function the function to call
  * @param ctx parameter passed to f
  * @param block 1 to block until the request is posted, 0 to
non-blocking mode
  * @return ERR_OK if the function was called, another err_t if not
err_t
tcpip_callback_with_block(tcpip_callback_fn function, void *ctx, u8_t block)
So we probably can use this to execute PrioritiseAndIndicate() in the
LwIP context.
Am 23.03.21 um 06:47 schrieb Mark Webb-Johnson:
> OK, some progress…
>  1. I’ve added a check in the OvmsSyncHttpClient code to refuse to
>     block while running as the netman (mongoose) task. This will now
>     simply fail the http connection, and log an error. Not perfect,
>     and not a solution to the core problem, but at least it avoids a
>     known problem.
>     I’m not sure of the best permanent solution to this. It seems that
>     we need a callback interface to run commands asynchronously, and
>     use that in mongoose event handlers. Adding another mongoose event
>     loop, or using a separate networking socket with select(), just
>     minimise the problem - they don’t solve it. The core issue here is
>     blocking during a mongoose event delivery. That is going to pause
>     all high level networking.
>  2. I found a race condition in ovms_netmanager that seems nasty. The
>     new cellular code could raise duplicate modem.down signals, picked
>     up and handled in ovms_netmanager. As part of that it calls
>     a PrioritiseAndIndicate() function that iterates over the network
>     interface list (maintained by LWIP). If that network interface
>     list is modified (eg; removing an interface) while it is being
>     traversed, nasty crashes can happen. The ‘fix’ I’ve done is again
>     just a workaround to try to reduce the duplicate signals and hence
>     reduce the likelyhood of the problem happening, but it won’t fix
>     the core problem (that is in both master and for-v3.3).
>     There is a netif_find function in LWIP, but (a) that requires an
>     interface number that we don’t have, and (b) doesn’t seem to lock
>     the list either.
>     Can’t think of an elegant solution to this, other than
>     modifications to lwip. We could add our own mutex and use that
>     whenever we talk to lwip, but even that would miss out on some
>     modifications to the network interface list, I guess.
> These two changes are in ‘pre’ now, and I am trying them in my car.
>> On 22 Mar 2021, at 6:06 PM, Michael Balzer <dexter at expeedo.de
>> Signed PGP part
>> In master, running commands via ssh or server-v2 block, because these
>> are running synchronously in the mongoose context.
>> Running commands via web doesn't block, as the webcommand class
>> starts a separate task for each execution.
>> The firmware config page does a synchronous call to
>> MyOTA.GetStatus(), so that call is executed in the mongoose context.
>> It still works in master, just needs a second or two to fetch the
>> version file.
>> Am 22.03.21 um 10:38 schrieb Mark Webb-Johnson:
>>> In master branch, at the moment, if a command is run from the web
>>> shell (or server v2), surely the mongoose task will block as the web
>>> server / server v2 blocks waiting for the command to run to completion?
>>> Doesn’t necessarily need to be a networking command. Something long
>>> running like the string speed tests.
>>> In v3.3 I can easily detect the task wait being requested in the
>>> http library (by seeing if current task id == mongoose task), and
>>> fail (which I should do anyway). But I am more concerned with the
>>> general case now (which I think may be wrong in both master and
>>> for-v3.3).
>>> Regards, Mark
>>>> On 22 Mar 2021, at 5:22 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>  I think we must avoid blocking the Mongoose task, as that's the
>>>> central network dispatcher.
>>>> Chris had implemented a workaround in one of his PRs that could
>>>> allow that to be done temporarily by running a local Mongoose main
>>>> loop during a synchronous operation, but I still see potential
>>>> issues from that, as it wasn't the standard handling as done by the
>>>> task, and as it may need to recurse.
>>>> Maybe the old OvmsHttpClient using socket I/O is the right way for
>>>> synchronous network operations?
>>>> Regards,
>>>> Michael
>>>> Am 22.03.21 um 07:15 schrieb Mark Webb-Johnson:
>>>>> Not sure how to resolve this.
>>>>> OvmsSyncHttpClient is currently used in commands from ovms_plugins
>>>>> and ovms_ota.
>>>>> I could bring back the OvmsHttpClient blocking (non-mongoose)
>>>>> implementation, but I don’t think that would address the core
>>>>> problem here:
>>>>>     Inside a mongoose callback (inside the mongoose networking
>>>>>     task), we are making blocking calls (and in particular calls
>>>>>     that could block for several tens of seconds).
>>>>> But fundamentally is it ok to block the mongoose networking task
>>>>> for extended periods during a mongoose event callback?
>>>>> Mark
>>>>>> On 21 Mar 2021, at 9:57 PM, Michael Balzer <dexter at expeedo.de
>>>>>> Signed PGP part
>>>>>> I've found opening the web UI firmware page or calling "ota
>>>>>> status" via ssh to consistently deadlock the network on my module.
>>>>>> I (130531) webserver: HTTP GET /cfg/firmware
>>>>>> D (130531) http: OvmsSyncHttpClient: Connect to
>>>>>> ovms.dexters-web.de:80 <http://ovms.dexters-web.de/>
>>>>>> D (130541) http: OvmsSyncHttpClient: waiting for completion
>>>>>> After that log message, the network is dead, and the netmanager
>>>>>> also doesn't respond:
>>>>>> OVMS# network list
>>>>>> ERROR: job failed
>>>>>> D (183241) netmanager: send cmd 1 from 0x3ffe7054
>>>>>> W (193241) netmanager: ExecuteJob: cmd 1: timeout
>>>>>> The interfaces seem to be registered and online, but nothing gets
>>>>>> in or out:
>>>>>> OVMS# network status
>>>>>> Interface#3: pp3 (ifup=1 linkup=1)
>>>>>>   IPv4: 10.170.195.13/255.255.255.255 gateway 10.64.64.64
>>>>>> Interface#2: ap2 (ifup=1 linkup=1)
>>>>>>   IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
>>>>>> Interface#1: st1 (ifup=1 linkup=1)
>>>>>>   IPv4: 192.168.2.106/255.255.255.0 gateway 192.168.2.1
>>>>>> DNS: 192.168.2.1
>>>>>> Default Interface: st1 (192.168.2.106/255.255.255.0 gateway
>>>>>> 192.168.2.1)
>>>>>> A couple of minutes later, server-v2 recognizes the stale
>>>>>> connection and issues a network restart, which fails resulting in
>>>>>> the same behaviour as shown below with finally forced reboot by
>>>>>> loss of an important event.
>>>>>> Doing "ota status" from USB works normally, so this looks like
>>>>>> OvmsSyncHttpClient not being able to run from within a mongoose
>>>>>> client.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 18.03.21 um 08:14 schrieb Mark Webb-Johnson:
>>>>>>> Tried to repeat this, but not having much success. Here is my
>>>>>>> car module, with network still up:
>>>>>>>     OVMS# boot status
>>>>>>>     Last boot was 262355 second(s) ago
>>>>>>> I did manage to catch one network related crash after repeatedly
>>>>>>> disconnecting and reconnecting the cellular antenna. This was:
>>>>>>>     I (3717989) cellular: PPP Connection disconnected
>>>>>>>     Guru Meditation Error: Core  1 panic'ed (LoadProhibited).
>>>>>>>     Exception was unhandled.
>>>>>>>     0x400fe082 is in OvmsNetManager::PrioritiseAndIndicate()
>>>>>>>     (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_netmanager.cpp:707).
>>>>>>>         707       if ((pri->name[0]==search[0])&&
>>>>>>>     0x400ed360 is in
>>>>>>>     OvmsMetricString::SetValue(std::__cxx11::basic_string<char,
>>>>>>>     std::char_traits<char>, std::allocator<char> >)
>>>>>>>     (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_metrics.cpp:1358).
>>>>>>>         1357    void OvmsMetricString::SetValue(std::string value)
>>>>>>>     0x4008bdad is at
>>>>>>>     ../../../../.././newlib/libc/machine/xtensa/strcmp.S:586.
>>>>>>>     0x4008bdd1 is at
>>>>>>>     ../../../../.././newlib/libc/machine/xtensa/strcmp.S:604.
>>>>>>>     0x400fe886 is in
>>>>>>>     OvmsNetManager::ModemDown(std::__cxx11::basic_string<char,
>>>>>>>     std::char_traits<char>, std::allocator<char> >, void*)
>>>>>>>     (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_netmanager.cpp:522).
>>>>>>>         522 PrioritiseAndIndicate();
>>>>>>>     0x400fd752 is in std::_Function_handler<void
>>>>>>>     (std::__cxx11::basic_string<char, std::char_traits<char>,
>>>>>>>     std::allocator<char> >, void*), std::_Bind<std::_Mem_fn<void
>>>>>>>     (OvmsNetManager::*)(std::__cxx11::basic_string<char,
>>>>>>>     std::char_traits<char>, std::allocator<char> >, void*)>
>>>>>>>     (OvmsNetManager*, std::_Placeholder<1>,
>>>>>>>     std::_Placeholder<2>)> >::_M_invoke(std::_Any_data const&,
>>>>>>>     std::allocator<char> >&&, void*&&)
>>>>>>>     (/home/openvehicles/build/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600).
>>>>>>>         600             { return
>>>>>>>         (__object->*_M_pmf)(std::forward<_Args>(__args)...); }
>>>>>>>     0x400f512e is in std::function<void
>>>>>>>     void*)>::operator()(std::__cxx11::basic_string<char,
>>>>>>>     std::char_traits<char>, std::allocator<char> >, void*) const
>>>>>>>     (/home/openvehicles/build/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271).
>>>>>>>         2271  return _M_invoker(_M_functor,
>>>>>>>         std::forward<_ArgTypes>(__args)...);
>>>>>>>     0x400f52f1 is in
>>>>>>>     OvmsEvents::HandleQueueSignalEvent(event_queue_t*)
>>>>>>>     (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_events.cpp:283).
>>>>>>>         283 m_current_callback->m_callback(m_current_event,
>>>>>>>         msg->body.signal.data);
>>>>>>>     0x400f53d8 is in OvmsEvents::EventTask()
>>>>>>>     (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_events.cpp:237).
>>>>>>>         237 HandleQueueSignalEvent(&msg);
>>>>>>>     0x400f545d is in EventLaunchTask(void*)
>>>>>>>     (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_events.cpp:80).
>>>>>>>         80  me->EventTask();
>>>>>>> My for_v3.3 branch does include the preliminary changes to
>>>>>>> support the wifi at 20MHz bandwidth, and perhaps those could be
>>>>>>> affecting things. I do notice that if I ‘power wifi off’, then
>>>>>>> ‘wifi mode client’, it can connect to the station, but not get
>>>>>>> an IP address. I’ve just tried to merge in the latest fixes to
>>>>>>> that, and rebuilt a release. I will continue to test with that.
>>>>>>> Regards, Mark.
>>>>>>>> On 12 Mar 2021, at 10:32 PM, Michael Balzer <dexter at expeedo.de
>>>>>>>> Signed PGP part
>>>>>>>> I just tried switching to for-v3.3 in my car module after tests
>>>>>>>> on my desk module were OK, and I've run into the very same
>>>>>>>> problem with for-v3.3. So the issue isn't related to esp-idf.
>>>>>>>> The network only occasionally starts normally, but even then
>>>>>>>> all connectivity is lost after a couple of minutes.
>>>>>>>> The stale connection watchdog in server-v2 triggers a network
>>>>>>>> restart, but that also doesn't seem to succeed:
>>>>>>>> 2021-03-12 14:53:01.802 CET W (981652) ovms-server-v2: Detected
>>>>>>>> stale connection (issue #241), restarting network
>>>>>>>> 2021-03-12 14:53:01.802 CET I (981652) esp32wifi: Restart
>>>>>>>> 2021-03-12 14:53:01.802 CET I (981652) esp32wifi: Stopping WIFI
>>>>>>>> station
>>>>>>>> 2021-03-12 14:53:01.812 CET I (981662) wifi:state: run -> init (0)
>>>>>>>> 2021-03-12 14:53:01.812 CET I (981662) wifi:pm stop, total
>>>>>>>> sleep time: 831205045 us / 975329961 us
>>>>>>>> 2021-03-12 14:53:01.812 CET I (981662) wifi:new:<1,0>,
>>>>>>>> old:<1,1>, ap:<1,1>, sta:<1,1>, prof:1
>>>>>>>> 2021-03-12 14:53:01.832 CET I (981682) wifi:flush txq
>>>>>>>> 2021-03-12 14:53:01.842 CET I (981692) wifi:stop sw txq
>>>>>>>> 2021-03-12 14:53:01.842 CET I (981692) wifi:lmac stop hw txq
>>>>>>>> 2021-03-12 14:53:01.852 CET I (981702) esp32wifi: Powering down
>>>>>>>> WIFI driver
>>>>>>>> 2021-03-12 14:53:01.852 CET I (981702) wifi:Deinit lldesc rx
>>>>>>>> mblock:16
>>>>>>>> 2021-03-12 14:53:01.862 CET I (981712) esp32wifi: Powering up
>>>>>>>> WIFI driver
>>>>>>>> 2021-03-12 14:53:01.862 CET I (981712) wifi:nvs_log_init, erase
>>>>>>>> log key successfully, reinit nvs log
>>>>>>>> 2021-03-12 14:53:01.882 CET I (981732) wifi:wifi driver task:
>>>>>>>> 3ffd4d84, prio:23, stack:3584, core=0
>>>>>>>> 2021-03-12 14:53:01.882 CET I (981732) system_api: Base MAC
>>>>>>>> address is not set, read default base MAC address from BLK0 of
>>>>>>>> EFUSE
>>>>>>>> EFUSE
>>>>>>>> 2021-03-12 14:53:01.902 CET I (981752) wifi:wifi firmware
>>>>>>>> version: 30f9e79
>>>>>>>> 2021-03-12 14:53:01.912 CET I (981762) wifi:config NVS flash:
>>>>>>>> enabled
>>>>>>>> 2021-03-12 14:53:01.912 CET I (981762) wifi:config nano
>>>>>>>> formating: disabled
>>>>>>>> 2021-03-12 14:53:01.912 CET I (981762) wifi:Init data frame
>>>>>>>> dynamic rx buffer num: 16
>>>>>>>> 2021-03-12 14:53:01.912 CET I (981762) wifi:Init management
>>>>>>>> frame dynamic rx buffer num: 16
>>>>>>>> 2021-03-12 14:53:01.922 CET I (981772) wifi:Init management
>>>>>>>> short buffer num: 32
>>>>>>>> 2021-03-12 14:53:01.922 CET I (981772) wifi:Init dynamic tx
>>>>>>>> buffer num: 16
>>>>>>>> 2021-03-12 14:53:01.922 CET I (981772) wifi:Init static rx
>>>>>>>> buffer size: 2212
>>>>>>>> buffer num: 16
>>>>>>>> 2021-03-12 14:53:01.922 CET I (981772) wifi:Init dynamic rx
>>>>>>>> buffer num: 16
>>>>>>>> 2021-03-12 14:53:02.642 CET I (982492) wifi:mode : sta
>>>>>>>> (30:ae:a4:5f:e7:ec) + softAP (30:ae:a4:5f:e7:ed)
>>>>>>>> 2021-03-12 14:53:02.652 CET I (982502) wifi:Total power save
>>>>>>>> buffer number: 8
>>>>>>>> 2021-03-12 14:53:02.652 CET I (982502) cellular-modem-auto: Restart
>>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) cellular: State: Enter
>>>>>>>> PowerOffOn state
>>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) gsm-ppp: Shutting down
>>>>>>>> (hard)...
>>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) gsm-ppp: StatusCallBack:
>>>>>>>> User Interrupt
>>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) gsm-ppp: PPP connection
>>>>>>>> has been closed
>>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) gsm-ppp: PPP is shutdown
>>>>>>>> (hard)...
>>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) gsm-ppp: StatusCallBack:
>>>>>>>> User Interrupt
>>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) gsm-ppp: PPP connection
>>>>>>>> has been closed
>>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) gsm-ppp: PPP is shutdown
>>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) gsm-nmea: Shutdown (direct)
>>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) cellular-modem-auto:
>>>>>>>> Power Cycle
>>>>>>>> 2021-03-12 14:53:04.682 CET D (984532) events:
>>>>>>>> Signal(system.wifi.down)
>>>>>>>> 2021-03-12 14:53:04.682 CET I (984532) netmanager: WIFI client stop
>>>>>>>> 2021-03-12 14:53:04.682 CET E (984532) netmanager: Inconsistent
>>>>>>>> state: no interface of type 'pp' found
>>>>>>>> down (with MODEM up): reconfigured for MODEM priority
>>>>>>>> 2021-03-12 14:53:04.692 CET D (984542) events: Signal(system.event)
>>>>>>>> Signal(system.wifi.sta.disconnected)
>>>>>>>> 2021-03-12 14:53:04.692 CET E (984542) netmanager: Inconsistent
>>>>>>>> 2021-03-12 14:53:04.692 CET I (984542) esp32wifi: STA
>>>>>>>> disconnected with reason 8 = ASSOC_LEAVE
>>>>>>>> 2021-03-12 14:53:04.702 CET D (984552) events: Signal(system.event)
>>>>>>>> Signal(system.wifi.sta.stop)
>>>>>>>> 2021-03-12 14:53:04.702 CET E (984552) netmanager: Inconsistent
>>>>>>>> 2021-03-12 14:53:04.712 CET D (984562) events: Signal(system.event)
>>>>>>>> Signal(system.wifi.ap.stop)
>>>>>>>> 2021-03-12 14:53:04.712 CET E (984562) netmanager: Inconsistent
>>>>>>>> 2021-03-12 14:53:04.712 CET I (984562) netmanager: WIFI access
>>>>>>>> point is down
>>>>>>>> 2021-03-12 14:53:04.712 CET I (984562) esp32wifi: AP stopped
>>>>>>>> 2021-03-12 14:53:04.722 CET D (984572) events:
>>>>>>>> Signal(network.wifi.sta.bad)
>>>>>>>> 2021-03-12 14:53:04.722 CET D (984572) events: Signal(system.event)
>>>>>>>> Signal(system.wifi.sta.start)
>>>>>>>> 2021-03-12 14:53:04.732 CET D (984582) events:
>>>>>>>> Signal(system.modem.down)
>>>>>>>> 2021-03-12 14:53:04.742 CET I (984592) netmanager: MODEM down
>>>>>>>> (with WIFI client down): network connectivity has been lost
>>>>>>>> 2021-03-12 14:53:04.742 CET D (984592) events:
>>>>>>>> 2021-03-12 14:53:04.752 CET D (984602) events: Signal(system.event)
>>>>>>>> Signal(system.wifi.ap.start)
>>>>>>>> 2021-03-12 14:53:04.752 CET I (984602) netmanager: WIFI access
>>>>>>>> point is up
>>>>>>>> 2021-03-12 14:53:26.802 CET E (1006652) events: SignalEvent:
>>>>>>>> queue overflow (running system.wifi.ap.start->netmanager for 23
>>>>>>>> sec), event 'ticker.1' dropped
>>>>>>>> 2021-03-12 14:53:27.802 CET E (1007652) events: SignalEvent:
>>>>>>>> queue overflow (running system.wifi.ap.start->netmanager for 24
>>>>>>>> 2021-03-12 14:53:28.802 CET E (1008652) events: SignalEvent:
>>>>>>>> queue overflow (running system.wifi.ap.start->netmanager for 25
>>>>>>>> …and so on until
>>>>>>>> 2021-03-12 14:54:01.802 CET E (1041652) events: SignalEvent:
>>>>>>>> lost important event => aborting
>>>>>>>> I need my car now, so will switch back to master for now.
>>>>>>>> Mark, if you've got specific debug logs I should fetch on the
>>>>>>>> next try, tell me.
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 12.03.21 um 05:47 schrieb Craig Leres:
>>>>>>>>> I just updated to 3.2.016-68-g8e10c6b7 and still get the
>>>>>>>>> network hang immediately after booting and logging into the
>>>>>>>>> web gui.
>>>>>>>>> But I see now my problem is likely that I'm not using the
>>>>>>>>> right esp-idf (duh). Is there a way I can have master build
>>>>>>>>> using ~/esp/esp-idf and have for-v3.3 use a different path?)
>>>>>>>>>         Craig
>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>> <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>> <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210323/a01912d6/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210323/a01912d6/attachment-0001.sig>
