[Ovmsdev] Branch for-v3.3 network issues
Tue Mar 23 13:47:08 HKT 2021
OK, some progress…
I’ve added a check in the OvmsSyncHttpClient code to refuse to block while running as the netman (mongoose) task. This will now simply fail the http connection, and log an error. Not perfect, and not a solution to the core problem, but at least it avoids a known problem.
I’m not sure of the best permanent solution to this. It seems that we need a callback interface to run commands asynchronously, and use that in mongoose event handlers. Adding another mongoose event loop, or using a separate networking socket with select(), just minimise the problem - they don’t solve it. The core issue here is blocking during a mongoose event delivery. That is going to pause all high level networking.
I found a race condition in ovms_netmanager that seems nasty. The new cellular code could raise duplicate modem.down signals, picked up and handled in ovms_netmanager. As part of that it calls a PrioritiseAndIndicate() function that iterates over the network interface list (maintained by LWIP). If that network interface list is modified (eg; removing an interface) while it is being traversed, nasty crashes can happen. The ‘fix’ I’ve done is again just a workaround to try to reduce the duplicate signals and hence reduce the likelyhood of the problem happening, but it won’t fix the core problem (that is in both master and for-v3.3).
There is a netif_find function in LWIP, but (a) that requires an interface number that we don’t have, and (b) doesn’t seem to lock the list either.
Can’t think of an elegant solution to this, other than modifications to lwip. We could add our own mutex and use that whenever we talk to lwip, but even that would miss out on some modifications to the network interface list, I guess.
These two changes are in ‘pre’ now, and I am trying them in my car.
> On 22 Mar 2021, at 6:06 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Signed PGP part
> In master, running commands via ssh or server-v2 block, because these are running synchronously in the mongoose context.
> Running commands via web doesn't block, as the webcommand class starts a separate task for each execution.
> The firmware config page does a synchronous call to MyOTA.GetStatus(), so that call is executed in the mongoose context. It still works in master, just needs a second or two to fetch the version file.
> Am 22.03.21 um 10:38 schrieb Mark Webb-Johnson:
>> In master branch, at the moment, if a command is run from the web shell (or server v2), surely the mongoose task will block as the web server / server v2 blocks waiting for the command to run to completion?
>> Doesn’t necessarily need to be a networking command. Something long running like the string speed tests.
>> In v3.3 I can easily detect the task wait being requested in the http library (by seeing if current task id == mongoose task), and fail (which I should do anyway). But I am more concerned with the general case now (which I think may be wrong in both master and for-v3.3).
>> Regards, Mark
>>> On 22 Mar 2021, at 5:22 PM, Michael Balzer <dexter at expeedo.de> <mailto:dexter at expeedo.de> wrote:
>>>  I think we must avoid blocking the Mongoose task, as that's the central network dispatcher.
>>> Chris had implemented a workaround in one of his PRs that could allow that to be done temporarily by running a local Mongoose main loop during a synchronous operation, but I still see potential issues from that, as it wasn't the standard handling as done by the task, and as it may need to recurse.
>>> Maybe the old OvmsHttpClient using socket I/O is the right way for synchronous network operations?
>>> Am 22.03.21 um 07:15 schrieb Mark Webb-Johnson:
>>>> Not sure how to resolve this.
>>>> OvmsSyncHttpClient is currently used in commands from ovms_plugins and ovms_ota.
>>>> I could bring back the OvmsHttpClient blocking (non-mongoose) implementation, but I don’t think that would address the core problem here:
>>>> Inside a mongoose callback (inside the mongoose networking task), we are making blocking calls (and in particular calls that could block for several tens of seconds).
>>>> But fundamentally is it ok to block the mongoose networking task for extended periods during a mongoose event callback?
>>>> Mark
>>>>> On 21 Mar 2021, at 9:57 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>> Signed PGP part
>>>>> I've found opening the web UI firmware page or calling "ota status" via ssh to consistently deadlock the network on my module.
>>>>> I (130531) webserver: HTTP GET /cfg/firmware
>>>>> D (130531) http: OvmsSyncHttpClient: Connect to ovms.dexters-web.de:80 <http://ovms.dexters-web.de/>
>>>>> D (130541) http: OvmsSyncHttpClient: waiting for completion
>>>>> After that log message, the network is dead, and the netmanager also doesn't respond:
>>>>> OVMS# network list
>>>>> ERROR: job failed
>>>>> D (183241) netmanager: send cmd 1 from 0x3ffe7054
>>>>> W (193241) netmanager: ExecuteJob: cmd 1: timeout
>>>>> The interfaces seem to be registered and online, but nothing gets in or out:
>>>>> OVMS# network status
>>>>> Interface#3: pp3 (ifup=1 linkup=1)
>>>>>   IPv4: 10.170.195.13/255.255.255.255 gateway 10.64.64.64
>>>>> Interface#2: ap2 (ifup=1 linkup=1)
>>>>>   IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
>>>>> Interface#1: st1 (ifup=1 linkup=1)
>>>>>   IPv4: 192.168.2.106/255.255.255.0 gateway 192.168.2.1
>>>>> DNS: 192.168.2.1
>>>>> Default Interface: st1 (192.168.2.106/255.255.255.0 gateway 192.168.2.1)
>>>>> A couple of minutes later, server-v2 recognizes the stale connection and issues a network restart, which fails resulting in the same behaviour as shown below with finally forced reboot by loss of an important event.
>>>>> Doing "ota status" from USB works normally, so this looks like OvmsSyncHttpClient not being able to run from within a mongoose client.
>>>>> Regards,
>>>>> Michael
>>>>> Am 18.03.21 um 08:14 schrieb Mark Webb-Johnson:
>>>>>> Tried to repeat this, but not having much success. Here is my car module, with network still up:
>>>>>> OVMS# boot status
>>>>>> Last boot was 262355 second(s) ago
>>>>>> I did manage to catch one network related crash after repeatedly disconnecting and reconnecting the cellular antenna. This was:
>>>>>> I (3717989) cellular: PPP Connection disconnected
>>>>>> Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
>>>>>> 0x400fe082 is in OvmsNetManager::PrioritiseAndIndicate() (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_netmanager.cpp:707).
>>>>>> 707         if ((pri->name[0]==search[0])&&
>>>>>> 0x400ed360 is in OvmsMetricString::SetValue(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_metrics.cpp:1358).
>>>>>> 1357    void OvmsMetricString::SetValue(std::string value)
>>>>>> 0x4008bdad is at ../../../../.././newlib/libc/machine/xtensa/strcmp.S:586.
>>>>>> 0x4008bdd1 is at ../../../../.././newlib/libc/machine/xtensa/strcmp.S:604.
>>>>>> 0x400fe886 is in OvmsNetManager::ModemDown(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_netmanager.cpp:522).
>>>>>> 522         PrioritiseAndIndicate();
>>>>>> 0x400fd752 is in std::_Function_handler<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*), std::_Bind<std::_Mem_fn<void (OvmsNetManager::*)(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)> (OvmsNetManager*, std::_Placeholder<1>, std::_Placeholder<2>)>                                     >::_M_invoke(std::_Any_data const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, void*&&) (/home/openvehicles/build/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600).
>>>>>> 600             { return (__object->*_M_pmf)(std::forward<_Args>(__args)...); }
>>>>>> 0x400f512e is in std::function<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)>::operator()(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) const (/home/openvehicles/build/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271).
>>>>>> 2271          return _M_invoker(_M_functor, std::forward<_ArgTypes>(__args)...);
>>>>>> 0x400f52f1 is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_events.cpp:283).
>>>>>> 283             m_current_callback->m_callback(m_current_event, msg->body.signal.data);
>>>>>> 0x400f53d8 is in OvmsEvents::EventTask() (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_events.cpp:237).
>>>>>> 237               HandleQueueSignalEvent(&msg);
>>>>>> 0x400f545d is in EventLaunchTask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-pre/vehicle/OVMS.V3/main/ovms_events.cpp:80).
>>>>>> 80        me->EventTask();
>>>>>> My for_v3.3 branch does include the preliminary changes to support the wifi at 20MHz bandwidth, and perhaps those could be affecting things. I do notice that if I ‘power wifi off’, then ‘wifi mode client’, it can connect to the station, but not get an IP address. I’ve just tried to merge in the latest fixes to that, and rebuilt a release. I will continue to test with that.
>>>>>> Regards, Mark.
>>>>>>> On 12 Mar 2021, at 10:32 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>> Signed PGP part
>>>>>>> I just tried switching to for-v3.3 in my car module after tests on my desk module were OK, and I've run into the very same problem with for-v3.3. So the issue isn't related to esp-idf.
>>>>>>> The network only occasionally starts normally, but even then all connectivity is lost after a couple of minutes.
>>>>>>> The stale connection watchdog in server-v2 triggers a network restart, but that also doesn't seem to succeed:
>>>>>>> 2021-03-12 14:53:01.802 CET W (981652) ovms-server-v2: Detected stale connection (issue #241), restarting network
>>>>>>> 2021-03-12 14:53:01.802 CET I (981652) esp32wifi: Restart
>>>>>>> 2021-03-12 14:53:01.802 CET I (981652) esp32wifi: Stopping WIFI station
>>>>>>> 2021-03-12 14:53:01.812 CET I (981662) wifi:state: run -> init (0)
>>>>>>> 2021-03-12 14:53:01.812 CET I (981662) wifi:pm stop, total sleep time: 831205045 us / 975329961 us
>>>>>>> 2021-03-12 14:53:01.812 CET I (981662) wifi:new:<1,0>, old:<1,1>, ap:<1,1>, sta:<1,1>, prof:1
>>>>>>> 2021-03-12 14:53:01.832 CET I (981682) wifi:flush txq
>>>>>>> 2021-03-12 14:53:01.842 CET I (981692) wifi:stop sw txq
>>>>>>> 2021-03-12 14:53:01.842 CET I (981692) wifi:lmac stop hw txq
>>>>>>> 2021-03-12 14:53:01.852 CET I (981702) esp32wifi: Powering down WIFI driver
>>>>>>> 2021-03-12 14:53:01.852 CET I (981702) wifi:Deinit lldesc rx mblock:16
>>>>>>> 2021-03-12 14:53:01.862 CET I (981712) esp32wifi: Powering up WIFI driver
>>>>>>> 2021-03-12 14:53:01.862 CET I (981712) wifi:nvs_log_init, erase log key successfully, reinit nvs log
>>>>>>> 2021-03-12 14:53:01.882 CET I (981732) wifi:wifi driver task: 3ffd4d84, prio:23, stack:3584, core=0
>>>>>>> 2021-03-12 14:53:01.882 CET I (981732) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
>>>>>>> 2021-03-12 14:53:01.902 CET I (981752) wifi:wifi firmware version: 30f9e79
>>>>>>> 2021-03-12 14:53:01.912 CET I (981762) wifi:config NVS flash: enabled
>>>>>>> 2021-03-12 14:53:01.912 CET I (981762) wifi:config nano formating: disabled
>>>>>>> 2021-03-12 14:53:01.912 CET I (981762) wifi:Init data frame dynamic rx buffer num: 16
>>>>>>> 2021-03-12 14:53:01.912 CET I (981762) wifi:Init management frame dynamic rx buffer num: 16
>>>>>>> 2021-03-12 14:53:01.922 CET I (981772) wifi:Init management short buffer num: 32
>>>>>>> 2021-03-12 14:53:01.922 CET I (981772) wifi:Init dynamic tx buffer num: 16
>>>>>>> 2021-03-12 14:53:01.922 CET I (981772) wifi:Init static rx buffer size: 2212
>>>>>>> 2021-03-12 14:53:01.922 CET I (981772) wifi:Init static rx buffer num: 16
>>>>>>> 2021-03-12 14:53:01.922 CET I (981772) wifi:Init dynamic rx buffer num: 16
>>>>>>> 2021-03-12 14:53:02.642 CET I (982492) wifi:mode : sta (30:ae:a4:5f:e7:ec) + softAP (30:ae:a4:5f:e7:ed)
>>>>>>> 2021-03-12 14:53:02.652 CET I (982502) wifi:Total power save buffer number: 8
>>>>>>> 2021-03-12 14:53:02.652 CET I (982502) cellular-modem-auto: Restart
>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) cellular: State: Enter PowerOffOn state
>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) gsm-ppp: Shutting down (hard)...
>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) gsm-ppp: StatusCallBack: User Interrupt
>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) gsm-ppp: PPP connection has been closed
>>>>>>> 2021-03-12 14:53:02.662 CET I (982512) gsm-ppp: PPP is shutdown
>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) gsm-ppp: StatusCallBack: User Interrupt
>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) gsm-ppp: PPP connection has been closed
>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) gsm-ppp: PPP is shutdown
>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) gsm-nmea: Shutdown (direct)
>>>>>>> 2021-03-12 14:53:02.672 CET I (982522) cellular-modem-auto: Power Cycle
>>>>>>> 2021-03-12 14:53:04.682 CET D (984532) events: Signal(system.wifi.down)
>>>>>>> 2021-03-12 14:53:04.682 CET I (984532) netmanager: WIFI client stop
>>>>>>> 2021-03-12 14:53:04.682 CET E (984532) netmanager: Inconsistent state: no interface of type 'pp' found
>>>>>>> 2021-03-12 14:53:04.682 CET I (984532) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority
>>>>>>> 2021-03-12 14:53:04.692 CET D (984542) events: Signal(system.event)
>>>>>>> 2021-03-12 14:53:04.692 CET D (984542) events: Signal(system.wifi.sta.disconnected)
>>>>>>> 2021-03-12 14:53:04.692 CET E (984542) netmanager: Inconsistent state: no interface of type 'pp' found
>>>>>>> 2021-03-12 14:53:04.692 CET I (984542) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE
>>>>>>> 2021-03-12 14:53:04.702 CET D (984552) events: Signal(system.event)
>>>>>>> 2021-03-12 14:53:04.702 CET D (984552) events: Signal(system.wifi.sta.stop)
>>>>>>> 2021-03-12 14:53:04.702 CET E (984552) netmanager: Inconsistent state: no interface of type 'pp' found
>>>>>>> 2021-03-12 14:53:04.712 CET D (984562) events: Signal(system.event)
>>>>>>> 2021-03-12 14:53:04.712 CET D (984562) events: Signal(system.wifi.ap.stop)
>>>>>>> 2021-03-12 14:53:04.712 CET E (984562) netmanager: Inconsistent state: no interface of type 'pp' found
>>>>>>> 2021-03-12 14:53:04.712 CET I (984562) netmanager: WIFI access point is down
>>>>>>> 2021-03-12 14:53:04.712 CET I (984562) esp32wifi: AP stopped
>>>>>>> 2021-03-12 14:53:04.722 CET D (984572) events: Signal(network.wifi.sta.bad)
>>>>>>> 2021-03-12 14:53:04.722 CET D (984572) events: Signal(system.event)
>>>>>>> 2021-03-12 14:53:04.722 CET D (984572) events: Signal(system.wifi.sta.start)
>>>>>>> 2021-03-12 14:53:04.732 CET D (984582) events: Signal(system.modem.down)
>>>>>>> 2021-03-12 14:53:04.742 CET I (984592) netmanager: MODEM down (with WIFI client down): network connectivity has been lost
>>>>>>> 2021-03-12 14:53:04.742 CET D (984592) events: Signal(system.modem.down)
>>>>>>> 2021-03-12 14:53:04.752 CET D (984602) events: Signal(system.event)
>>>>>>> 2021-03-12 14:53:04.752 CET D (984602) events: Signal(system.wifi.ap.start)
>>>>>>> 2021-03-12 14:53:04.752 CET I (984602) netmanager: WIFI access point is up
>>>>>>> 2021-03-12 14:53:26.802 CET E (1006652) events: SignalEvent: queue overflow (running system.wifi.ap.start->netmanager for 23 sec), event 'ticker.1' dropped
>>>>>>> 2021-03-12 14:53:27.802 CET E (1007652) events: SignalEvent: queue overflow (running system.wifi.ap.start->netmanager for 24 sec), event 'ticker.1' dropped
>>>>>>> 2021-03-12 14:53:28.802 CET E (1008652) events: SignalEvent: queue overflow (running system.wifi.ap.start->netmanager for 25 sec), event 'ticker.1' dropped
>>>>>>> …and so on until
>>>>>>> 2021-03-12 14:54:01.802 CET E (1041652) events: SignalEvent: lost important event => aborting
>>>>>>> I need my car now, so will switch back to master for now.
>>>>>>> Mark, if you've got specific debug logs I should fetch on the next try, tell me.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 12.03.21 um 05:47 schrieb Craig Leres:
>>>>>>>> I just updated to 3.2.016-68-g8e10c6b7 and still get the network hang immediately after booting and logging into the web gui.
>>>>>>>> But I see now my problem is likely that I'm not using the right esp-idf (duh). Is there a way I can have master build using ~/esp/esp-idf and have for-v3.3 use a different path?)
>>>>>>>>         Craig
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210323/b4f08a88/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210323/b4f08a88/attachment-0001.sig>
