[Ovmsdev] mongoose-wolfssl
Sun Mar 21 21:31:54 HKT 2021
Am 20.03.21 um 21:53 schrieb Stephen Casner:
> On Sat, 20 Mar 2021, Craig Leres wrote:
>> On 3/20/21 9:09 AM, Michael Balzer wrote:
>>> Assuming no objections from other developers, I would first merge
>>> mongoose-wolfssl into master, then master into for-v3.3.
>> As a developer I'd like to be the first to say, "yes, please."
> Motion and second is good enough for me.
> I have completed the following merge steps:
> - merge from mongoose-wolfssl branch to master branch in the
> mongoose submodule
> - cherry-pick from mongoose-wolfssl branch to master branch in the
> main ovms tree
> - merge from master branch to for-v3.3 branch in the main ovms tree
> Build and run of the master branch works for me with TLS server v2
> connection and ssh connection, so I hope that is a sufficient merge
> validation test.
It seems you actually cherry-picked all commits? If so, a standard merge
would have had the same effect (except tree-wise).
Cherry-picking is useful if you want to port some selected patch(es)
from a branch to another. If you take the whole branch, that's the
classic merge.
>> And a question: Does this bring us closer to being able to use https with the
>> gui? Even a self generated, self signed cert would allow an encrypted session
>> and protection of credentials. And I can imagine adding code to implement the
>> Let's Encrypt DNS-01 challenge type.
> The next step is to see what linkages to MBEDTLS remain. I think
> https may be part of that.
> -- Steve
I know of no public CA that allows private hosts or IP addresses in a
certificate, and I always thought it's impossible to support the LE DNS
challenge on an mDNS service, but would love to learn otherwise in both
cases.
However, supporting https/wss on the module's webserver has been
possible since we enabled SSL in mongoose.
I have now added that as a standard feature and included an info on how
to create a cert + key in the webserver configuration.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210321/160c09d3/attachment.sig>
