[Ovmsdev] ESP32/3 benchmark (was: External Wifi antenna)
Craig Leres
leres at xse.com
Sun Mar 14 02:00:28 HKT 2021
On 2/8/21 5:20 AM, Michael Balzer wrote:
> Am 31.01.21 um 19:58 schrieb Craig Leres:
>>> Please also disable the PSRAM bug workaround and maybe do some
>>> performance comparison. SPIRAM operations should run much faster
>>> without the workaround.
>> What kind of tests should I run?
> I've just added an execution time output to my SPIRAM test command,
> which was meant to trigger the memory corruption, but can also serve as
> a memory benchmark.
> To get comparable results, run the tests after booting with "config set
> auto init no" (you'll need a USB connection).
> Tests with my results (ESP32/1, SPIRAM fix enabled, debug output removed):
> OVMS# test string 1000 2
> finished 1000 loops for mode 2 using extram in 33503 ms
> OVMS# test string 5000 4
> finished 5000 loops for mode 4 using extram in 30268 ms
> OVMS# test string 25000 6
> finished 25000 loops for mode 6 using extram in 34681 ms
> Test mode 2 reads from metrics (involves locks & stream formatting),
> mode 4 reads a fixed string from the config, mode 6 is mostly pure
> memory copying.
I ran these with 3.2.016-27-g8564963b-dirty with this sdkconfig:
ice 1186 % diff sdkconfig support/sdkconfig.default.hw31 | fgrep -v
VEHICLE | egrep '^[<>]'
< CONFIG_SPIRAM_CACHE_WORKAROUND=
> CONFIG_SPIRAM_CACHE_WORKAROUND=y
The first time I just pasted the test lines into the serial window and
the 2nd test caused a watchdog reset. But I wasn't able to reproduce it.
Craig
#1: stdlen = 1034
0,1,2,3,4,5,6,7,8,92,4,5,6,7,8,94202392OVMS WIFI BLE BT cores=2
rev=ESP32/3104-1271416156578083.2.016-27-g8564963b-dirty/ota_1/main
(build idf v3.3.4-848-g1ff5e24b1 Mar 13 2021
09:19:45)11.5512.6no5889830,1,2,3,4,5,6,7,8,92,4,5,6,7,8,94202392OVMS
WIFI BLE BT cores=2
WIFI BLE BT cores=2
WIFI BLE BT cores=2
WIFI BLE BT cores=2
finished 1000 loops for mode 2 using extram in 37348 ms
#1: stdlen = 1030
2020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100202005310020200531002020053100
E (166099) task_wdt: Task watchdog got triggered. The following tasks
did not reset the watchdog in time:
E (166099) task_wdt: - IDLE1 (CPU 1)
E (166099) task_wdt: - OVMS DukTape (CPU 1)
E (166099) task_wdt: Tasks currently running:
E (166099) task_wdt: CPU 0: IDLE0
E (166099) task_wdt: CPU 1: OVMS Events
E (166099) task_wdt: Aborting.
abort() was called at PC 0x400e6984 on core 0
ELF file SHA256: 3099b1f81632b65f
Backtrace: 0x40089947:0x3ffb0690 0x40089be1:0x3ffb06b0
0x400e6984:0x3ffb06d0 0x40083cd2:0x3ffb06f0
Rebooting...
ets Jul 29 2019 12:21:46
ice 1189 % ./backtrace.sh 0x40089947:0x3ffb0690 0x40089be1:0x3ffb06b0
+ xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x40089947:0x3ffb0690
0x40089be1:0x3ffb06b0 0x400e6984:0x3ffb06d0 0x40083cd2:0x3ffb06f0
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/task_wdt.c:274
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/freertos/xtensa_vectors.S:1154
#1: stdlen = 1030
finished 5000 loops for mode 4 using extram in 28945 ms
#1: stdlen = 1035
0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-0123456789-abcdefghijk-
finished 25000 loops for mode 6 using extram in 34205 ms
#1: stdlen = 1034
0,1,2,3,4,5,6,7,8,92,4,5,6,7,8,94202384OVMS WIFI BLE BT cores=2
rev=ESP32/3405-1271416156582763.2.016-27-g8564963b-dirty/ota_1/main
09:19:45)11.5412.6no5889830,1,2,3,4,5,6,7,8,92,4,5,6,7,8,94202384OVMS
WIFI BLE BT cores=2
WIFI BLE BT cores=2
WIFI BLE BT cores=2
WIFI BLE BT cores=2
finished 1000 loops for mode 2 using extram in 37315 ms
W (441099) script: DuktapeDispatch: msg type 3 lost, queue full
W (442099) script: DuktapeDispatch: msg type 3 lost, queue full
W (443099) script: DuktapeDispatch: msg type 3 lost, queue full
OVMS#
