[Ovmsdev] Wifi AP bandwidth
Tue Mar 9 10:34:33 HKT 2021
Probably better to make it configurable. Not sure what the default config should be, though. We don’t need a lot of throughput - just reliability.
> On 9 Mar 2021, at 3:26 AM, Derek Caudwell <d.caudwell at gmail.com> wrote:
> Hi all,
> I've noticed the default wifi AP is using a 40mhz width. This is not ideal at 2.4ghz as it can be less stable and create interference see https://learntomato.flashrouters.com/wifi-frequency-wifi-channel-width-wireless-spectrum/#:~:text=By%20default%2C%20the%202.4%20GHz,a%2020%20MHz%20channel%20width.&text=In%20crowded%20areas%20with%20a,as%20well%20in%20crowded%20areas <https://learntomato.flashrouters.com/wifi-frequency-wifi-channel-width-wireless-spectrum/#:~:text=By%20default%2C%20the%202.4%20GHz,a%2020%20MHz%20channel%20width.&text=In%20crowded%20areas%20with%20a,as%20well%20in%20crowded%20areas>.
> Does anyone mind if I submit a PR to default it to 20mhz instead?
> Cheers Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210309/981757e7/attachment.htm>
