[Ovmsdev] 3.2.016 released to EAP
Sat Mar 6 21:34:09 HKT 2021
Sure. Will do on Sunday.
Mark
> On 5 Mar 2021, at 9:30 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Everyone,
> I've just tagged the 3.2.016 release, uploaded it to my "eap" directory and published the info on my site.
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/releases/tag/3.2.016
> https://dexters-web.de/firmware-release-3.2.016-text_98.en.htm
> Mark, I suggest you do the same on openvehicles.com.
> If no issues turn up, we should aim at the "main" release in about 1-2 weeks.
> Summary of changes:
> - New vehicle: VW e-Up via OBD-II Port (VWUP.OBD)
> - New vehicle: MG ZS EV via OBD-II Port (MGEV)
> - New vehicle: BMW i3/i3s via OBD-II Port (BMWI3)
> - VW e-Up: combined T26A & OBD module, extended standard metrics coverage,
> charge notifications & durations (OBD), enhanced cabin pre-heating (T26)
> - VW e-UP T26A: add climate control and charging detection
> - VW e-Up: BMS cell monitoring (@OBD)
> - VW e-Up: CCS (DC) charge detection & data
> New metrics:
> xvu.c.ccs.u -- CCS charger supplied voltage [V]
> xvu.c.ccs.i -- CCS Charger supplied current [A]
> xvu.c.ccs.p -- CCS Charger supplied power [kW]
> - VW e-Up: replaced MFD range based CAC/SOH by charge coulomb count based
> Removed metrics:
> xvu.b.cap.range
> xvu.b.cap.chg.ah.norm
> xvu.b.cap.chg.kwh.norm
> xvu.b.cap.chg.kwh.abs
> New metrics:
> xvu.b.energy.range -- MFD range estimation energy [kWh]
> xvu.b.cap.kwh.range -- … usable battery capacity derived [kWh]
> xvu.b.cap.ah.abs -- Charge coulomb based capacity [Ah]
> xvu.b.cap.ah.norm -- … normalized (usable) [Ah]
> xvu.b.cap.kwh.abs -- Charge energy based capacity [kWh]
> xvu.b.cap.kwh.norm -- … normalized (usable) [kWh]
> - MG ZS EV: Add Charging Metrics page.
> - MG ZS EV: Add support for ms_v_charge_kwh, ms_v_bat_energy_used and ms_v_bat_coulomb_used metrics
> - Volt/Ampera: BMS cell monitoring (CAN1 polling), fast CAN polling when waking up,
> estimated range gets from CAN instead of calculation,
> lock/unlock status processing fixed for Volt 14MY;
> New standard metrics:
> trip (this charge), energy used (this charge), HV battery capacity (CAC, Ah),
> transmission temp, doors, trunk, hood, lightings;
> - Volt/Ampera: new xva metrics:
> xva.v.p.trip.ev = trip using electric, km;
> xva.v.e.fuel = fuel tank level, %;
> - Renault Twizy: new metrics to reflect extended lock & valet modes:
> xrt.v.e.locked.speed -- Speed limit [kph] set for Twizy lock mode
> xrt.v.e.valet.odo -- Odometer limit [km] set for Twizy valet mode
> - Renault Twizy: support additional OBD/UDS request types & arguments on "xrt obd request"
> - ZOE: BMS cell monitoring (PH1)
> - SmartED: add Drivmode for Brabus
> - Nissan Leaf: invert batt current sign to match standard metrics definition, populate charger power/efficiency
> - Vehicle framework: generic single OBD2/UDS request shell command & API call
> New commands:
> obdii can[1-4] request device [-t<timeout_ms>] [-e] txid rxid request
> obdii can[1-4] request broadcast [-t<timeout_ms>] request
> - BMS: optional cell voltage & temperature logging
> New configs:
> [vehicle] bms.log.voltage.interval Interval [s] for cell voltage logging, default 0=disable
> [vehicle] bms.log.temp.interval Interval [s] for cell temperature logging, default 0=disable
> - BMS: detection of inconsistent voltage series by gradient & stddev average deviation
> thresholds, added pack metrics to battery monitor web UI, change cell warning & alert
> thresholds to be applied exceeding stddev level
> New metrics:
> v.b.p.voltage.grad Cell voltage - gradient of current series [V]
> New configs:
> [vehicle] bms.dev.voltage.maxgrad Max gradient for a valid series
> [vehicle] bms.dev.voltage.maxsddev Max stddev deviation from average for valid series
> - Notifications: added optional long term trip & grid (charge/generator session) server logs.
> See https://docs.openvehicles.com/en/latest/userguide/notifications.html for details.
> New configs:
> [notify] log.trip.storetime Trip log storage time in days, 0/empty = off (default)
> [notify] log.trip.minlength … minimum trip length in km, default 0.2 km
> [notify] log.grid.storetime Grid log storage time in days, 0/empty = off (default)
> - Metrics: extended reboot persistence: most vehicle state and long term counter
> metrics will now retain their values over a reboot (e.g. OTA update)
> - Metrics: new standard metrics for grid integration (V2G) / generator role
> v.c.kwh.grid Energy drawn from grid during running session
> v.c.kwh.grid.total Energy drawn from grid total (life time)
> v.g.generating True = currently delivering power
> v.g.climit Maximum generator input current (from battery)
> v.g.current Momentary generator input current (from battery)
> v.g.duration.empty Estimated time remaining for full discharge
> v.g.duration.range … for range limit
> v.g.duration.soc … for SOC limit
> v.g.efficiency Momentary generator efficiency
> v.g.kwh Energy sum generated in the running session
> v.g.kwh.grid Energy sent to grid during running session
> v.g.kwh.grid.total Energy sent to grid total
> v.g.limit.range Minimum range limit for generator mode
> v.g.limit.soc Minimum SOC limit for generator mode
> v.g.mode Generator mode (TBD)
> v.g.pilot Pilot signal present
> v.g.power Momentary generator output power
> v.g.state Generator state (TBD)
> v.g.substate Generator substate (TBD)
> v.g.temp Generator temperature
> v.g.time Duration of generator running
> v.g.timermode True if generator timer enabled
> v.g.timerstart Time generator is due to start
> v.g.type Connection type (chademo, ccs, …)
> v.g.voltage Momentary generator output voltage
> - TPMS: metrics rework & standard alert notifications on new v.t.alert metric.
> Replaced metrics…
> v.tp.fl.p TPMS front left pressure
> v.tp.fl.t TPMS front left temperature
> v.tp.fr.p TPMS front right pressure
> v.tp.fr.t TPMS front right temperature
> v.tp.rl.p TPMS rear left pressure
> v.tp.rl.t TPMS rear left temperature
> v.tp.rr.p TPMS rear right pressure
> v.tp.rr.t TPMS rear right temperature
> …by…
> v.t.pressure TPMS tyre pressures vector (fl,fr,rl,rr)
> v.t.temp TPMS tyre temperatures vector
> v.t.alert TPMS tyre alert levels [0=normal, 1=warning, 2=alert]
> v.t.health TPMS tyre health states
> - New standard metrics for total (life time) energy and coulomb
> - Events: added automatic events on v.e.aux12v changes.
> New events:
> vehicle.aux.12v.on
> vehicle.aux.12v.off
> - Location: add metric for name of current location
> New metrics:
> v.p.location -- Name of current location if defined
> - Server V3 improvements:
> a) On first connection to MQTT broker we used to send all metrics. Now
> we only send metrics for which we have a value.
> b) New config settings:
> "updatetime.on" which sets updatetime when the car is on (driving)
> "updatetime.charging" which sets updatetime when the car is charging
> "updatetime.awake" which sets updatetime when the car is awake
> If unset the server uses the "idle" or "connected" interval as before
> c) New config setting "updatetime.sendall". If you set this we will publish
> _all_ valid metrics at this interval. Helpful to keep a steady flow of
> values for charting.
> PLEASE NOTE: These settings will increase OVMS' data usage.
> - Wifi: option to immediately disconnect/reconnect on bad signal level
> New config:
> [network] wifi.bad.reconnect [bool], default no
> - WiFi: replace fixed scan times by config instances
> New configs:
> [network] wifi.scan.tmin Min scan time per channel [ms], default 120 ms
> [network] wifi.scan.tmax Max scan time per channel [ms], default 120 ms
> - Updated wolfssh and wolfssl so the restriction of clients to use
> aes128-cbc cipher is no longer required.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210306/e3469f17/attachment.htm>
