[Ovmsdev] Coding help
Sat Mar 6 04:45:59 HKT 2021
Shane,
OvmsVehicle::PollSetPidList(m_can1, obdii_polls);
     OvmsVehicle::PollSetState(0);
needs to be done in your vehicle init, i.e. the constructor after
RegisterCanBus().
Please read the vehicle_obdii module source for a complete polling example.
Am 05.03.21 um 17:59 schrieb Shane @ Kilve Engineering:
> Thanks Michael,
> Had a try and ended up with this bit added but return anything
> Where am I going wrong?
> Shane
> #include "ovms_log.h"
> *static**const**char**TAG= "v-edeliver3";
> #include "vehicle_edeliver3.h"
> #include "metrics_standard.h"
> *namespace*  {
> *const*OvmsVehicle::poll_pid_tobdii_polls[] =
>     { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xf194, { 10, 10,
> 10, 10  }, 0, ISOTP_STD }, //VIN
>     { 0x7e3, 0x7eb, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0xe003, { 10, 10,
> 10, 10  }, 0, ISOTP_STD }, //SOH
> POLL_LIST_END
> OvmsVehicleEdeliver3::OvmsVehicleEdeliver3()
> ESP_LOGI(TAG, "Start eDeliver3 vehicle module");
> RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
> OvmsVehicleEdeliver3::~OvmsVehicleEdeliver3()
> ESP_LOGI(TAG, "Stop eDeliver3 vehicle module");
> memset(m_vin, 0, *sizeof*(m_vin));
> //testing polls
> *void*OvmsVehicleEdeliver3::IncomingPollReply(
>    canbus* bus, uint16_t type, uint16_t pid, uint8_t* data, uint8_t
> length, uint16_t mlremain)
>    string& rxbuf = med_obd_rxbuf;
> // init / fill rx buffer:
> *if* (m_poll_ml_frame == 0) {
> rxbuf.clear();
> rxbuf.reserve(length + mlremain);
> rxbuf.append((*char**)data, length);
> *if* (mlremain)
> *return*;
> // complete:
> *switch* (pid) {
> *case* 0xe003: {
> *unsigned* *int* soh_raw = ((*unsigned* *int*)rxbuf[0] << 8) |
> (*unsigned* *int*)rxbuf[1];
> *float* soh = soh_raw / 10;
> StdMetrics.ms_v_bat_soh->SetValue(soh);
> *break*;
> // end testing polls
>> On 5 Mar 2021, at 12:37, Michael Balzer <dexter at expeedo.de
>> Shane,
>> on OBD polling basics:
>> http://lists.openvehicles.com/pipermail/ovmsdev/2020-December/014758.html
>> Am 04.03.21 um 19:45 schrieb Shane @ Kilve Engineering:
>>> Good evening Michael,
>>> Or any one that has the time to help,
>>> Ive now successfully retrieved as much info as I can without polling
>>> any info for the maxus, but I have have now found an ecu that
>>> responds to pid requests.
>>> For example if I use the obdii pid scanner I get the loads of data
>>> back and I’ve decoded some of it, just need a bit of guidance how to
>>> write the code to get the same info
>>> A part of a scan is as follows
>>> Scan complete (7e3 e000-e100)
>>> Scan started : 2021-03-04 18:32:36 GMT
>>> Last response: 2021-03-04 18:32:39 GMT
>>> 7e3[7eb]:e000 00
>>> 7e3[7eb]:e001 64
>>> 7e3[7eb]:e002 4b
>>> 7e3[7eb]:e003 26 bc
>>> 7e3[7eb]:e004 00 07
>>> 7e3[7eb]:e005 2f
>>> 7e3[7eb]:e006 2e
>>> 7e3[7eb]:e007 02 00
>>> 7e3[7eb]:e008 01 ff
>>> 7e3[7eb]:e009 02 00
>>> 7e3[7eb]:e010 02 00
>>> I know that e003 is SOH = 26bc = 9916 /100 = 99.16% SOH
>>> And e002 is a temp 4b = 75 / 10 = 7.5 degrees
>>> So if some one can help me with an example of how to correctly code
>>> this one I can work out the rest,
>>> Ive looked through various vehicles but everyone uses different
>>> methods and I can’t seem to get one to work for me.
>>> Any help much appreciated
>>> Shane
>>>> On 15 Feb 2021, at 08:05, Michael Balzer <dexter at expeedo.de
>>>> Shane,
>>>> I forgot to mention: if you're working on a new vehicle module,
>>>> you'll also need to start the bus somewhere in your initialization
>>>> code. Example:
>>>>   RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS);
>>>> Regards,
>>>> Michael
>>>> Am 15.02.21 um 08:36 schrieb Michael Balzer:
>>>>> Shane,
>>>>> Am 14.02.21 um 16:42 schrieb Shane @ Kilve Engineering:
>>>>>> can any one help me with a bit of code to retrieve ve some data
>>>>>> from ecu can1/6f2 00 4c 00 00 01 97 bc 00 as i cant poll this ecu
>>>>>> it just broadcasts when its active, ive tried polling it but does
>>>>>> not respond, i need to choose one byte and allocate it to a PID.
>>>>> I don't know what you mean by "allocating a byte to a PID", but if
>>>>> you want to process frames received directly, simply override
>>>>> IncomingFrameCan1() (or …2/3/4 depending on your bus).
>>>>> Reduced example:
>>>>> void OvmsVehicleXYZ::IncomingFrameCan1(CAN_frame_t *p_frame)
>>>>>   uint8_t *d = p_frame->data.u8;
>>>>>   switch (p_frame->MsgID)
>>>>>     case 0x6f2:
>>>>>       // for example, assuming the SOC is in byte 1:
>>>>> StdMetrics.ms_v_bat_soc->SetValue(d[1]);
>>>>>       break;
>>>>> If you're outside a vehicle context, you can register your own CAN
>>>>> receiver by creating a queue and calling MyCan.RegisterListener().
>>>>> See the vehicle module for an example.
>>>>> Regards,
>>>>> Michael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210305/2e429854/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210305/2e429854/attachment-0001.sig>
