[Ovmsdev] Coding help
Fri Mar 5 20:37:51 HKT 2021
Shane,
on OBD polling basics:
http://lists.openvehicles.com/pipermail/ovmsdev/2020-December/014758.html
Am 04.03.21 um 19:45 schrieb Shane @ Kilve Engineering:
> Good evening Michael,
> Or any one that has the time to help,
> Ive now successfully retrieved as much info as I can without polling
> any info for the maxus, but I have have now found an ecu that responds
> to pid requests.
> For example if I use the obdii pid scanner I get the loads of data
> back and I’ve decoded some of it, just need a bit of guidance how to
> write the code to get the same info
> A part of a scan is as follows
> Scan complete (7e3 e000-e100)
> Scan started : 2021-03-04 18:32:36 GMT
> Last response: 2021-03-04 18:32:39 GMT
> 7e3[7eb]:e000 00
> 7e3[7eb]:e001 64
> 7e3[7eb]:e002 4b
> 7e3[7eb]:e003 26 bc
> 7e3[7eb]:e004 00 07
> 7e3[7eb]:e005 2f
> 7e3[7eb]:e006 2e
> 7e3[7eb]:e007 02 00
> 7e3[7eb]:e008 01 ff
> 7e3[7eb]:e009 02 00
> 7e3[7eb]:e010 02 00
> I know that e003 is SOH = 26bc = 9916 /100 = 99.16% SOH
> And e002 is a temp 4b = 75 / 10 = 7.5 degrees
> So if some one can help me with an example of how to correctly code
> this one I can work out the rest,
> Ive looked through various vehicles but everyone uses different
> methods and I can’t seem to get one to work for me.
> Any help much appreciated
> Shane
>> On 15 Feb 2021, at 08:05, Michael Balzer <dexter at expeedo.de
>> Shane,
>> I forgot to mention: if you're working on a new vehicle module,
>> you'll also need to start the bus somewhere in your initialization
>> code. Example:
>> RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS);
>> Am 15.02.21 um 08:36 schrieb Michael Balzer:
>>> Shane,
>>> Am 14.02.21 um 16:42 schrieb Shane @ Kilve Engineering:
>>>> can any one help me with a bit of code to retrieve ve some data
>>>> from ecu can1/6f2 00 4c 00 00 01 97 bc 00 as i cant poll this ecu
>>>> it just broadcasts when its active, ive tried polling it but does
>>>> not respond, i need to choose one byte and allocate it to a PID.
>>> I don't know what you mean by "allocating a byte to a PID", but if
>>> you want to process frames received directly, simply override
>>> IncomingFrameCan1() (or …2/3/4 depending on your bus).
>>> Reduced example:
>>> void OvmsVehicleXYZ::IncomingFrameCan1(CAN_frame_t *p_frame)
>>> uint8_t *d = p_frame->data.u8;
>>> switch (p_frame->MsgID)
>>> case 0x6f2:
>>> // for example, assuming the SOC is in byte 1:
>>> StdMetrics.ms_v_bat_soc->SetValue(d[1]);
>>> break;
>>> If you're outside a vehicle context, you can register your own CAN
>>> receiver by creating a queue and calling MyCan.RegisterListener().
>>> See the vehicle module for an example.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210305/de59a3ce/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210305/de59a3ce/attachment.sig>
