[Ovmsdev] GPS theft alert
Mon Mar 1 15:39:17 HKT 2021
Craig,
when connecting my bench module to my Arduino CAN shield, I need to add
a terminal resistor in between. Did you try that?
You could then test if can2 & can3 are also affected. can1 is the
internal bus of the ESP32 module, can2/3 are external MCP2515 buses
accessed via SPI.
If it's can1 only, you could try running some CAN tester using the
latest esp-idf driver. Maybe there are differences between the hardware
revisions, revision 1 has some hardware bugs in the CAN controller as well.
From a first look into the current esp-idf master, there is now a HAL
for CAN (now called TWAI "two-way async interface" for whatever reason),
and there seem to be some differences between the revisions. But AFAICT
only minor ones:
https://github.com/espressif/esp-idf/blob/master/components/soc/esp32/include/soc/soc_caps.h#L221
Am 01.03.21 um 02:28 schrieb Craig Leres:
> Michael, thanks for pointers on sd card logging. Meanwhile I've
> figured out my problem is basic and the theft alert is just a symptom.
> Last week I get sd logging configured and the first time I drove I got
> to my destination (slightly more than 500m away) and happened to
> notice that the ovms ios app showed my car had been parked for > 20
> days... Thanks to the persistent metrics feature I didn't notice but
> it appears that my modules haven't communicated with my cars since
> about the end of January; for example the fuel gauge was at 1/4 but
> the app showed 87%. So in fact my theft alert problem is that v.e.on
> is *never* true.
> Today I did some debugging. I tried running older builds (I keep an
> archive of everything I actually run) and even went back to the
> 3.2.015 and 3.2.014 factory builds but when the car is running I don't
> see any metrics getting updated. I did see a can bus error message but
> it looks like I didn't capture it.
> At this point I transitioned to the bench and my dev ovms module. I
> have a raspberry pi 2 that has a can shield I've used for other
> projects. I verified that candump/cansend could exchange canbus frames
> with a prototype arduino project I had sitting around and then plugged
> it into ovms module. I've appended my test session; I only tried
> sending from ovms with the pi running "candump any".
> Given that all three of my modules have canbus issues and the fact
> that this problem started around the time I swapped esp32 modules I
> think it's clear that I have a hardware problem related to the new
> esp32 modules. And it's probably not a bad solder joint as I inspected
> them with the stereo microscope (and it's not likely I'd botch the
> same pin(s) on all three modules).
> Unfortunately I don't have much debugging left this weekend but what
> do you suggest for my next move?
> Craig
> Welcome to the Open Vehicle Monitoring System (OVMS) - SSH Console
> Firmware: 3.2.015-718-g3f74c233/ota_0/main
> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3
> OVMS# vehicle status
> Vehicle module 'Empty Vehicle' (code NONE) loaded and running
> OVMS# can list
> can1: Off/1000000 dbc none
> can2: Off/1000000 dbc none
> can3: Off/1000000 dbc none
> OVMS# can can1 start active 500000
> Can bus can1 started in mode active at speed 500000bps
> OVMS# can list
> can1: Active/500000 dbc none
> OVMS# log level verbose can
> Logging level for can set to verbose
> OVMS# can log start vfs crtd /sd/can.crtd
> CAN logging to VFS active: Type:vfs Format:crtd(discard) Filter:off
> Vehicle:NONE Path:/sd/can.crtd
> OVMS# can can1 tx standard 87 DEAD
> E (982009) can: can1: intr=1 rxpkt=0 txpkt=0 errflags=0x8000a2 rxerr=1
> txerr=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
> E (982009) can: can1: intr=11 rxpkt=0 txpkt=0 errflags=0x8040a2
> rxerr=100 txerr=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0
> errreset=0
> E (982009) can: can1: intr=15 rxpkt=0 txpkt=0 errflags=0x204000
> rxerr=135 txerr=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0
> errreset=0
> E (982009) can: can1: intr=19 rxpkt=0 txpkt=0 errflags=0x8040a2
> errreset=0
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210301/18321764/attachment.sig>
