[Ovmsdev] GPS location glitch (flatbed theft false alert)
    Wed Jun 30 16:05:21 HKT 2021
Craig,
Am 30.06.21 um 01:44 schrieb Craig Leres:
> On 6/29/21 12:27 AM, Michael Balzer wrote:
>> How about testing latitude & longitude individually for sudden peaks
>> from their previous average, and discarding a new coordinate
>> completely while such a peak is present?
> Overnight I had the idea that instead of looking for specific broken
> values (0.0, 0.05, etc.) maybe the way to go is to suppress values
> when the only the latitude or the longitude has a big jump. Maybe
> something like this:
>     lat1, lon1 // previous position
>     lat2, lon2 // new position
>     tlat = (lat1 + lat2) / 2
>     delta_lat = haversine(tlat, lon1, tlat, lon2)
>     tlon = (lon1 + lon2) / 2
>     delta_lon = haversine(lat1, tlon, lat2, tlon)
>     if (delta_lat > simcombugdist && delta_lon < (simcombugdist / 10))
>         # toss
>     if (delta_lon > simcombugdist && delta_lat < (simcombugdist / 10))
>         # toss
…or maybe just testing the value deltas for m_latitude & m_longitude in
their Updated…() methods. Calculating an actual distance doesn't seem to
be necessary here.
A sudden jump after having no GPS lock or on init should be considered OK.
> Another (possibly far fetched) idea I had was is it possible we'
> seeing corruption transferring the gps location from the simcom to the
> esp32? A race condition where the latitude or the longitude gets
> clobbered while reading it? I don't have a good idea of what other
> symptoms that kind of problem would have.
Actually… not far fetched at all, as we continuously see multiplex frame
errors in the logs -- see my previous posts on this. We don't have flow
control on the ESP-SIMCOM serial line, and the handler may not catch all
losses.
You can test that theory by enabling the verbose log on "gsm-nmea". Be
aware that's a lot of log messages.
Better option: I already do some consistency checks in
GsmNMEA::IncomingLine(), but I didn't implement the NMEA checksum. You
might give that a try first.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210630/5ccd8d4d/attachment.sig>
