[Ovmsdev] GPS location glitch (flatbed theft false alert)
    Craig Leres
    leres at xse.com
    Wed Jun 30 07:44:32 HKT 2021
On 6/29/21 12:27 AM, Michael Balzer wrote:
> How about testing latitude & longitude individually for sudden peaks
> from their previous average, and discarding a new coordinate completely
> while such a peak is present?
Overnight I had the idea that instead of looking for specific broken
values (0.0, 0.05, etc.) maybe the way to go is to suppress values when
the only the latitude or the longitude has a big jump. Maybe something
like this:
     lat1, lon1 // previous position
     lat2, lon2 // new position
     tlat = (lat1 + lat2) / 2
     delta_lat = haversine(tlat, lon1, tlat, lon2)
     tlon = (lon1 + lon2) / 2
     delta_lon = haversine(lat1, tlon, lat2, tlon)
     if (delta_lat > simcombugdist && delta_lon < (simcombugdist / 10))
         # toss
     if (delta_lon > simcombugdist && delta_lat < (simcombugdist / 10))
         # toss
On 6/29/21 12:31 AM, Michael Balzer wrote:
 > I'd also suggest doing this detection in the modem NMEA code already,
 > to prevent feeding false coordinates into the metrics first place.
That sounds right considering it's a simcom bug we're mitigating.
On 6/29/21 9:05 AM, Stephen Casner wrote:
 > For vehicles like the Tesla Roadster that don't use the modem's GPS,
 > putting the detection only in the modem NMEA code would not help.
Unless the roadster's gps has the same wacky problem with latitude or
longitude temporarily jumps to zero (or near zero) and back, I think the
roadster should have its own code to deal with gps bugs.
On 6/29/21 1:01 PM, Stephen Casner wrote:
 > What would qualify as exactly the same bug behavior?  If it is
 > specifically that the latitude or longitude is reported as 0, that may
 > not be the same.  What we see is a sharp deviation in the GPS
 > position.
So both latitude and longitude temporarily jump? The kind of fix we
currently have for the simcom gps (and what I'm proposing we do instead)
won't help with that.
Another (possibly far fetched) idea I had was is it possible we' seeing
corruption transferring the gps location from the simcom to the esp32? A
race condition where the latitude or the longitude gets clobbered while
reading it? I don't have a good idea of what other symptoms that kind of
problem would have.
		Craig
