[Ovmsdev] MCP2515 driver bug?
Mon Jun 7 00:16:28 HKT 2021
Mark,
I've just found a spot-on post on this issue:
https://www.microchip.com/forums/tm.aspx?m=620741
Tom suggests implementing a state machine to reproduce the receive
order. His analysis & solution looks sound to me.
Am 06.06.21 um 14:50 schrieb Mark Webb-Johnson:
> I spent quite a bit of time on this. With my standard test packet of
> 11 CAN frames expected, and the standard driver, I get perhaps 4 or 5
> of them (about half are lost, and some are out of order).
> I made the suggested change to move the MyCan.IncomingFrame() call
out
> of the ‘can’ object (when frameReceived is true) to within the
> mcp2515 AsynchronousInterruptHandler itself. That allows the handler
> to receive more than one frame per call and is a very simple change.
> Once that is done, we can at least now try to tune it.
> So I then modified the code of mcp2515 AsynchronousInterruptHandler to
> loop so long as the interrupt flag says either buffer #0 or #1 has a
> frame. The result looks something like this:
> D (63192) mcp2515: AsynchronousInterruptHandler instat=01
> errflag=00 txb0ctrl=00
> D (63192) mcp2515: AsynchronousInterruptHandler rx frame from
> buffer #0 (ID 0x110 B1=54)
> D (63192) mcp2515: AsynchronousInterruptHandler instat=23
> errflag=40 txb0ctrl=00
> buffer #0 (ID 0x110 B1=40)
> buffer #1 (ID 0x110 B1=45)
> D (63192) mcp2515: AsynchronousInterruptHandler Clear RX buffer #0
> overflow flag
> buffer #0 (ID 0x110 B1=24)
> buffer #1 (ID 0x110 B1=34)
> D (63192) mcp2515: AsynchronousInterruptHandler instat=20
> The actual frames on the bus are (B1 values) 54, 45, 40, 0a, 7a, d5,
> 0c, 14, 1c, 24, 2c, and 34. Looking at the above debug output, we get:
> * Interrupt flags show buffer #0 has a frame. It is B1=54. Good.
> * Interrupt flags show buffers #0 and #1 both have frames. Buffer #0
> has B1=40 and buffer #1 has B1=45.
> * Etc etc
> That is not good. What must have happened is that the first B1=54
> frame arrived, got put in buffer #0, and interrupt was raised. We
> checked the interrupt flags, found buffer #0 had something, and read
> the frame ok. All is good. But what is happening now is that between
> the time we checked the interrupt flags and the time we finished
> reading the 13 bytes from buffer #0, a second frame arrived and was
> put in buffer #1. Then a third frame arrives and is put in buffer #0.
> We loop back to check the interrupt flags and find both buffers have
> frames ready. So we ready buffer #0 to get the third frame, then
> buffer #1 to get the second frame. We are out of sequence.
> By removing the ESP_LOGD statements, I can improve performance enough
> to get 10 out of the 11 frames, but still sometimes frames are swapped
> in order.
> By over-clocking the MCP2515 SPI bus (supposed to be 10MHz, but I push
> it to 15MHz), I can get all 11 frames, but two are out of order.
> I suppose I can minimise the chance of the out-of-order issue by
> repeating the call to read interrupt flags after processing buffer #0
> but before checking for buffer #1. That would at least reduce the time
> window to as small as possible, but would be another SPI call and is
> too slow. Doing that brings us back to losing frames.
> Another approach may relate to our current use of the READ command to
> read 5 status registers (interrupt flags, error flags, two skipped,
> then transmit buffer #0 flags). There are two specific commands ‘read
> status’ (which gets the rx and tx buffer status flags in one byte),
> and ‘rx status’ (which gets just the receive buffer status and some
> info on the frames received, again in one byte). I think those are
> more designed for what we are trying to do. I can try to optimise the
> read loop at the start of the AsynchronousInterruptHandler to use one
> of those - they are 2 SPI bytes vs 7 for what we are doing at the
> moment (so more than three times as fast).
> I think it will also be worthwhile having a look at some other open
> source mcp2515 drivers to see how other people are doing it.
>> On 4 Jun 2021, at 3:02 PM, Mark Webb-Johnson <mark at webb-johnson.net
>> <mailto:mark at webb-johnson.net>> wrote:
>> Signed PGP part
>> The handler can only return one frame. As it is, if both buffers #0
>> and #1 have a frame, it returns #0. I am not sure if it gets called
>> again (seems to depend on the interrupt gpio status).
>> // Read the interrupt pin status and if it's still active (low),
>> require another interrupt handling iteration
>> return !gpio_get_level((gpio_num_t)m_intpin);
>> Maybe a quick solution is to just return true, immediately
>> after *frameReceived=true, if intflag=0x01 and (intstat &
>> CANINTF_RX1IF)? That would dispatch the incoming frame, then call
>> back for more (from the loop in the can object).
>> I am not sure in general why AsynchronousInterruptHandler uses a bool
>> frameReceived flag, and doesn’t just simply dispatch the frame
>> immediately to the can object? That would simplify things and allow
>> the AsynchronousInterruptHandler to handle receiving both frames in
>> the same call. Given that MCP2515 is the only driver
>> using AsynchronousInterruptHandler, that would be an easy fix.
>>> On 4 Jun 2021, at 2:29 PM, Michael Balzer <dexter at expeedo.de
>>> <mailto:dexter at expeedo.de>> wrote:
>>> Signed PGP part
>>> Mark,
>>> the handler is meant to read both buffers sequentially, and on a
>>> quick glance I don't see why it wouldn't. But it can't hurt if you
>>> do an audit of the code.
>>> I remember having had that out-of-order discussion when handling
>>> both RX buffers before here, but don't remember the outcome. Too bad
>>> the list archives cannot be searched.
>>> I think it was the MCP not doing overflows from RX buffer 1 to 0.
>>> I.e. if buffer 1 still has a frame on arrival, the new frame will be
>>> lost. That means losing a frame if the handler cannot react fast
>>> enough, but receiving out of order would be worse.
>>> Am 04.06.21 um 04:16 schrieb Mark Webb-Johnson:
>>>> Michael,
>>>> Good suggestion on the timing. I think it best to use the same
>>>> timings as the Arduino library, and have committed that change. No
>>>> vehicle modules currently use 1Mbps on MCP2515 anyway.
>>>> Unfortunately, it didn’t resolve my problem.
>>>> Looking at the error flags I see:
>>>> Error flag: 0x23401c01
>>>> intstat 0x23
>>>> ERRIF Error Interrupt pending
>>>> RX0IF Rx buffer 0 full interrupt
>>>> RX1IF Rx buffer 1 full interrupt
>>>> errflag 0x40
>>>> RX0OVR Rx buffer 0 overflow
>>>> intflag 0x1c01
>>>> 0x01 Implied from Rx buffer 0 full
>>>> 0x1c = 0001 1100
>>>> Means RXB0 overflow. No data lost in this case (it went into
>>>> RXB1)
>>>> Means (errflag & EFLG_RX01OVR), clear RX buffer overflow flags
>>>> Means (intstat & (CANINTF_MERRF | CANINTF_WAKIF |
>>>> CANINTF_ERRIF)), clear error & wakeup interrupts
>>>> So we have CAN frames in BOTH rx buffers #0 and #1. Looking at our
>>>> driver code (mcp2515::AsynchronousInterruptHandler), it seems in
>>>> that case we only read from buffer #0. From the flow I can see, we
>>>> are going to lose that second frame. We’re not really handling the
>>>> issue of two frames being in the buffers when the interrupt handler
>>>> is called.
>>>> As the architecture of mcp2515::AsynchronousInterruptHandler can
>>>> only receive one frame, it is not so simple to fix. We could simply
>>>> read and return the frame in buffer #0, requesting to be called
>>>> again (return true), but another frame may arrive (into buffer #0)
>>>> before we get called again, and that is going to result in
>>>> out-of-order frames.
>>>> I’ll work on improving the handling of this case.
>>>> Regards, Mark.
>>>>> On 3 Jun 2021, at 3:07 PM, Michael Balzer <dexter at expeedo.de
>>>>> Signed PGP part
>>>>> Mark,
>>>>> I'd give the bit timing a try first, the MCP2515 seems to be very
>>>>> sensitive for this. I've even had some trouble finding a working
>>>>> configuration for the 50 kbit timing I've added a couple weeks ago.
>>>>> We currently use 00 / D0 / 82 which is also the result of the old
>>>>> Intrepid timing calculator. That's a propagation segment of 1 Tq
>>>>> and 3 Tq per phase, resulting in samling between 50% - 62.5%.
>>>>> The Arduino MCP CAN lib by Cory Fowler also had this previously,
>>>>> but then changed in…
>>>>> https://github.com/coryjfowler/MCP_CAN_lib/commit/ece730cf697fef1cbe8a90111694868168d41000
>>>>> …to 00 / CA / 81, which is a propagation segment of 3 Tq and 2 Tq
>>>>> per phase, shifting the sampling window to 62.5 - 75%.
>>>>> Our current configuration scheme for the internal SJA1000
>>>>> compatible CAN seems to sample at 62.5 - 75% as well, so that
>>>>> would also match.
>>>>> Regards,
>>>>> Michael
>>>>> Am 03.06.21 um 07:36 schrieb Mark Webb-Johnson:
>>>>>> I’m working on an implementation of IP stack over CAN for the
>>>>>> Tesla Roadster. IP frames are encoded as a length followed by a
>>>>>> sequence of CAN frames, all on the same ID. This runs over a 1MHz
>>>>>> bus, so presumably the traffic volume could be high at times.
>>>>>> I was having problems with this running on CAN2, so tried CAN1
>>>>>> and it worked perfectly. Here are some simple dumps of a single
>>>>>> PING packet (and single PING response packet):
>>>>>> ID #111 is used to transmit an IP packet, and ID #110 is used to
>>>>>> receive an IP packet. The special empty data frame is an
>>>>>> acknowledgment.
>>>>>> Using latest master branch code (3.2.016-196-g0aad1a9f/ota_1/edge
>>>>>> (build idf v3.3.4-848-g1ff5e24b1 Jun 2 2021 09:28:58)).
>>>>>> So, first let’s test with traffic on CAN1 (active, 1Mbps),
and
>>>>>> listening on CAN2 (listen, 1Mbps):
>>>>>> TCPDUMP:
>>>>>> 05:57:55.980291 IP (tos 0x0, ttl 64, id 43101, offset
>>>>>> 0, flags [DF], proto ICMP (1), length 84)
>>>>>> 10.10.99.3 > 10.10.99.2: ICMP echo request, id 23372,
>>>>>> seq 1, length 64
>>>>>> 0x0000: 4500 0054 a85d 4000 4001 b832 0a0a 6303
>>>>>> E..T.]@. at ..2..c.
>>>>>> 0x0010: 0a0a 6302 0800 7df8 5b4c 0001 5361 b860
>>>>>> ..c...}.[L..Sa.`
>>>>>> 0x0020: 19f5 0e00 0809 0a0b 0c0d 0e0f 1011 1213
>>>>>> 0x0030: 1415 1617 1819 1a1b 1c1d 1e1f 2021 2223
>>>>>> 0x0040: 2425 2627 2829 2a2b 2c2d 2e2f 3031 3233
>>>>>> $%&'()*+,-./0123
>>>>>> 0x0050: 3435 3637 4567
>>>>>> 05:57:56.436190 IP (tos 0x0, ttl 64, id 14937, offset
>>>>>> 0, flags [none], proto ICMP (1), length 84)
>>>>>> 10.10.99.2 > 10.10.99.3: ICMP echo reply, id 23372,
>>>>>> seq 1, length 64
>>>>>> 0x0000: 4500 0054 3a59 0000 4001 6637 0a0a 6302
>>>>>> E..T:Y.. at .f7..c.
>>>>>> 0x0010: 0a0a 6303 0000 85f8 5b4c 0001 5361 b860
>>>>>> ..c.....[L..Sa.`
>>>>>> $%&'()*+,-./0123
>>>>>> Traffic (as shown on PC the other end of the can log tcp
>>>>>> connection):
>>>>>> tx: #111 54 00
>>>>>> tx: #111 45 00 00 54 a8 5d 40 00
>>>>>> tx: #111 40 01 b8 32 0a 0a 63 03
>>>>>> tx: #111 0a 0a 63 02 08 00 7d f8
>>>>>> tx: #111 5b 4c 00 01 53 61 b8 60
>>>>>> tx: #111 19 f5 0e 00 08 09 0a 0b
>>>>>> tx: #111 0c 0d 0e 0f 10 11 12 13
>>>>>> tx: #111 14 15 16 17 18 19 1a 1b
>>>>>> tx: #111 1c 1d 1e 1f 20 21 22 23
>>>>>> tx: #111 24 25 26 27 28 29 2a 2b
>>>>>> tx: #111 2c 2d 2e 2f 30 31 32 33
>>>>>> tx: #111 34 35 36 37
>>>>>> rx: #110
>>>>>> rx: #110 54 00
>>>>>> rx: #110 45 00 00 54 3a 59 00 00
>>>>>> rx: #110 40 01 66 37 0a 0a 63 02
>>>>>> rx: #110 0a 0a 63 03 00 00 85 f8
>>>>>> rx: #110 5b 4c 00 01 53 61 b8 60
>>>>>> rx: #110 19 f5 0e 00 08 09 0a 0b
>>>>>> rx: #110 0c 0d 0e 0f 10 11 12 13
>>>>>> rx: #110 14 15 16 17 18 19 1a 1b
>>>>>> rx: #110 1c 1d 1e 1f 20 21 22 23
>>>>>> rx: #110 24 25 26 27 28 29 2a 2b
>>>>>> rx: #110 2c 2d 2e 2f 30 31 32 33
>>>>>> rx: #110 34 35 36 37
>>>>>> CAN1 active:
>>>>>> 1T11 111 54 00
>>>>>> 1R11 110
>>>>>> 1CER TX_Queue T11 111 40 01 b8 32 0a 0a 63 03
>>>>>> 1T11 111 45 00 00 54 a8 5d 40 00
>>>>>> 1T11 111 40 01 b8 32 0a 0a 63 03
>>>>>> 1CER TX_Queue T11 111 5b 4c 00 01 53 61 b8 60
>>>>>> 1T11 111 0a 0a 63 02 08 00 7d f8
>>>>>> 1T11 111 5b 4c 00 01 53 61 b8 60
>>>>>> 1CER TX_Queue T11 111 0c 0d 0e 0f 10 11 12 13
>>>>>> 1T11 111 19 f5 0e 00 08 09 0a 0b
>>>>>> 1T11 111 0c 0d 0e 0f 10 11 12 13
>>>>>> 1CER TX_Queue T11 111 1c 1d 1e 1f 20 21 22 23
>>>>>> 1T11 111 14 15 16 17 18 19 1a 1b
>>>>>> 1T11 111 1c 1d 1e 1f 20 21 22 23
>>>>>> 1CER TX_Queue T11 111 2c 2d 2e 2f 30 31 32 33
>>>>>> 1T11 111 24 25 26 27 28 29 2a 2b
>>>>>> 1T11 111 2c 2d 2e 2f 30 31 32 33
>>>>>> 1T11 111 34 35 36 37
>>>>>> 1R11 110 54 00
>>>>>> 1R11 110 45 00 00 54 3a 59 00 00
>>>>>> 1R11 110 40 01 66 37 0a 0a 63 02
>>>>>> 1R11 110 0a 0a 63 03 00 00 85 f8
>>>>>> 1R11 110 5b 4c 00 01 53 61 b8 60
>>>>>> 1R11 110 19 f5 0e 00 08 09 0a 0b
>>>>>> 1R11 110 0c 0d 0e 0f 10 11 12 13
>>>>>> 1R11 110 14 15 16 17 18 19 1a 1b
>>>>>> 1R11 110 1c 1d 1e 1f 20 21 22 23
>>>>>> 1R11 110 24 25 26 27 28 29 2a 2b
>>>>>> 1R11 110 2c 2d 2e 2f 30 31 32 33
>>>>>> 1R11 110 34 35 36 37
>>>>>> CAN2 listen:
>>>>>> 2R11 111 54 00
>>>>>> 2R11 110
>>>>>> 2R11 111 45 00 00 54 a8 5d 40 00
>>>>>> 2R11 111 40 01 b8 32 0a 0a 63 03
>>>>>> 2R11 111 0a 0a 63 02 08 00 7d f8
>>>>>> 2R11 111 5b 4c 00 01 53 61 b8 60
>>>>>> 2R11 111 19 f5 0e 00 08 09 0a 0b
>>>>>> 2R11 111 0c 0d 0e 0f 10 11 12 13
>>>>>> 2R11 111 14 15 16 17 18 19 1a 1b
>>>>>> 2R11 111 1c 1d 1e 1f 20 21 22 23
>>>>>> 2R11 111 24 25 26 27 28 29 2a 2b
>>>>>> 2R11 111 2c 2d 2e 2f 30 31 32 33
>>>>>> 2R11 111 34 35 36 37
>>>>>> 2R11 110 54 00
>>>>>> 2CER Error intr=10 rxpkt=14 txpkt=0
>>>>>> errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0
>>>>>> txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
>>>>>> 2R11 110 40 01 66 37 0a 0a 63 02
>>>>>> 2R11 110 19 f5 0e 00 08 09 0a 0b
>>>>>> 2R11 110 34 35 36 37
>>>>>> 2R11 110 45 00 00 54 3a 59 00 00
>>>>>> Conclusion is that the CAN1 traffic looks fine, and the PING
>>>>>> packet gets a good reply. All successful. But the CAN2 listen is
>>>>>> missing a few packets and the last packet is out of order.
>>>>>> Now, let’s test with traffic on CAN2 (active, 1Mbps), and
>>>>>> listening on CAN1 (listen, 1Mbps):
>>>>>> TCPDUMP:
>>>>>> 06:00:33.004060 IP (tos 0x0, ttl 64, id 58240, offset 0,
>>>>>> 10.10.99.3 > 10.10.99.2: ICMP echo request, id 23393,
>>>>>> seq 1, length 64
>>>>>> 0x0000: 4500 0054 e380 4000 4001 7d0f 0a0a 6303
>>>>>> E..T.. at .@.}...c.
>>>>>> 0x0010: 0a0a 6302 0800 7cc8 5b61 0001 f161 b860
>>>>>> ..c...|.[a...a.`
>>>>>> 0x0020: 8b0f 0000 0809 0a0b 0c0d 0e0f 1011 1213
>>>>>> $%&'()*+,-./0123
>>>>>> connection):
>>>>>> tx: #111 54 00
>>>>>> tx: #111 45 00 00 54 e3 80 40 00
>>>>>> tx: #111 40 01 7d 0f 0a 0a 63 03
>>>>>> tx: #111 0a 0a 63 02 08 00 7c c8
>>>>>> tx: #111 5b 61 00 01 f1 61 b8 60
>>>>>> tx: #111 8b 0f 00 00 08 09 0a 0b
>>>>>> rx: #110
>>>>>> rx: #110 54 00
>>>>>> rx: #110 45 00 00 54 3a 5a 00 00
>>>>>> rx: #110 0a 0a 63 03 00 00 84 c8
>>>>>> rx: #110 8b 0f 00 00 08 09 0a 0b
>>>>>> rx: #110 40 01 66 36 0a 0a 63 02
>>>>>> CAN2 active:
>>>>>> 2T11 111 54 00
>>>>>> 2R11 110
>>>>>> 2CER TX_Queue T11 111 40 01 7d 0f 0a 0a 63 03
>>>>>> 2T11 111 45 00 00 54 e3 80 40 00
>>>>>> 2T11 111 40 01 7d 0f 0a 0a 63 03
>>>>>> 2CER TX_Queue T11 111 5b 61 00 01 f1 61 b8 60
>>>>>> 2T11 111 0a 0a 63 02 08 00 7c c8
>>>>>> 2T11 111 5b 61 00 01 f1 61 b8 60
>>>>>> 2CER TX_Queue T11 111 0c 0d 0e 0f 10 11 12 13
>>>>>> 2T11 111 8b 0f 00 00 08 09 0a 0b
>>>>>> 2T11 111 0c 0d 0e 0f 10 11 12 13
>>>>>> 2CER TX_Queue T11 111 1c 1d 1e 1f 20 21 22 23
>>>>>> 2T11 111 14 15 16 17 18 19 1a 1b
>>>>>> 2T11 111 1c 1d 1e 1f 20 21 22 23
>>>>>> 2CER TX_Queue T11 111 2c 2d 2e 2f 30 31 32 33
>>>>>> 2T11 111 24 25 26 27 28 29 2a 2b
>>>>>> 2T11 111 2c 2d 2e 2f 30 31 32 33
>>>>>> 2T11 111 34 35 36 37
>>>>>> 2R11 110 54 00
>>>>>> 2R11 110 45 00 00 54 3a 5a 00 00
>>>>>> 2CER Error intr=15 rxpkt=3 txpkt=12 errflags=0x23401c01
>>>>>> rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=5
>>>>>> 2R11 110 0a 0a 63 03 00 00 84 c8
>>>>>> 2R11 110 8b 0f 00 00 08 09 0a 0b
>>>>>> 2R11 110 40 01 66 36 0a 0a 63 02
>>>>>> CAN1 listen:
>>>>>> 1R11 111 54 00
>>>>>> 1R11 110
>>>>>> 1R11 111 45 00 00 54 e3 80 40 00
>>>>>> 1R11 111 40 01 7d 0f 0a 0a 63 03
>>>>>> 1R11 111 0a 0a 63 02 08 00 7c c8
>>>>>> 1R11 111 5b 61 00 01 f1 61 b8 60
>>>>>> 1R11 111 8b 0f 00 00 08 09 0a 0b
>>>>>> 1R11 111 0c 0d 0e 0f 10 11 12 13
>>>>>> 1R11 111 14 15 16 17 18 19 1a 1b
>>>>>> 1R11 111 1c 1d 1e 1f 20 21 22 23
>>>>>> 1R11 111 24 25 26 27 28 29 2a 2b
>>>>>> 1R11 111 2c 2d 2e 2f 30 31 32 33
>>>>>> 1R11 111 34 35 36 37
>>>>>> 1R11 110 54 00
>>>>>> 1R11 110 45 00 00 54 3a 5a 00 00
>>>>>> 1R11 110 40 01 66 36 0a 0a 63 02
>>>>>> 1R11 110 0a 0a 63 03 00 00 84 c8
>>>>>> 1R11 110 5b 61 00 01 f1 61 b8 60
>>>>>> 1R11 110 8b 0f 00 00 08 09 0a 0b
>>>>>> Conclusion is that the CAN2 transmit traffic looks fine, but no
>>>>>> PING reply received via CAN. The CAN1 listen shows the reply just
>>>>>> fine.
>>>>>> Here is that last CAN1 listen, with timestamps:
>>>>>> 1622696433.080107 1R11 111 54 00
>>>>>> 1622696433.081657 1R11 110
>>>>>> 1622696433.227479 1R11 111 45 00 00 54 e3 80 40 00
>>>>>> 1622696433.228318 1R11 111 40 01 7d 0f 0a 0a 63 03
>>>>>> 1622696433.245727 1R11 111 0a 0a 63 02 08 00 7c c8
>>>>>> 1622696433.246214 1R11 111 5b 61 00 01 f1 61 b8 60
>>>>>> 1622696433.248219 1R11 111 8b 0f 00 00 08 09 0a 0b
>>>>>> 1622696433.248772 1R11 111 0c 0d 0e 0f 10 11 12 13
>>>>>> 1622696433.250774 1R11 111 14 15 16 17 18 19 1a 1b
>>>>>> 1622696433.251338 1R11 111 1c 1d 1e 1f 20 21 22 23
>>>>>> 1622696433.253380 1R11 111 24 25 26 27 28 29 2a 2b
>>>>>> 1622696433.253944 1R11 111 2c 2d 2e 2f 30 31 32 33
>>>>>> 1622696433.265937 1R11 111 34 35 36 37
>>>>>> 1622696433.269221 1R11 110 54 00
>>>>>> 1622696433.272095 1R11 110 45 00 00 54 3a 5a 00 00
>>>>>> 1622696433.272125 1R11 110 40 01 66 36 0a 0a 63 02
>>>>>> 1622696433.272156 1R11 110 0a 0a 63 03 00 00 84 c8
>>>>>> 1622696433.272193 1R11 110 5b 61 00 01 f1 61 b8 60
>>>>>> 1622696433.272245 1R11 110 8b 0f 00 00 08 09 0a 0b
>>>>>> 1622696433.272277 1R11 110 0c 0d 0e 0f 10 11 12 13
>>>>>> 1622696433.272314 1R11 110 14 15 16 17 18 19 1a 1b
>>>>>> 1622696433.272354 1R11 110 1c 1d 1e 1f 20 21 22 23
>>>>>> 1622696433.272387 1R11 110 24 25 26 27 28 29 2a 2b
>>>>>> 1622696433.272420 1R11 110 2c 2d 2e 2f 30 31 32 33
>>>>>> 1622696433.272452 1R11 110 34 35 36 37
>>>>>> It is 1Mbps, with 30us or so between each packet. This is the
>>>>>> *only* traffic on the bus. Everything else is turned off. Roughly
>>>>>> 12 packets each way. Surely even if we were hitting a performance
>>>>>> limit, our buffers can handle 12 packets?
>>>>>> The good news is that I have a good environment to replicate this
>>>>>> issue now, so any fix should be easy to test.
>>>>>> I haven’t worked on the MCP2515 driver in our code in a long
>>>>>> time, but it certainly seems something is messed up and that
>>>>>> could be badly affecting vehicle modules using anything other
>>>>>> than CAN1.
>>>>>> I will start to look at this over the weekend, but has anyone got
>>>>>> any ideas/suggestions? Perhaps the bit timing registers are off
>>>>>> by a small amount (so it works on CAN1 but not on CAN2)? Or
>>>>>> something more serious in our driver?
>>>>>> Regards, Mark.
>>>>>> OvmsDev mailing list
>>>>> <MCP2515Calc-1000kbit.ods>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210606/23f218a5/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210606/23f218a5/attachment-0001.sig>
