[Ovmsdev] Tesla Powered RAV4 EV support
    Michael Iimura
    rav4ev1462 at gmail.com
    Sat Jul  3 12:48:14 HKT 2021
Stephen,
You were right on. Most of the Tesla Model S code worked straight away. I
have made a pull request for my initial work that involves only the Tesla
CAN bus on Can1. I have not even started looking at the Toyota CAN because
most of the useful stuff is already broadcast on the Tesla bus.
I pulled the cooling system temperatures and pump speed percentages and put
them in new vehicle specific metrics. I fumbled my way through copying the
method of making a vehicle specific web page from the Nissan Leaf code so
that I could display that information. However, I got stuck when populating
those metrics into the web page. The compiler throws this error for each of
my new metrics:
L:/OVMS/home/miimura/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_toyotarav4ev/src/vehicle_toyotarav4ev.cpp:
In static member function 'static void
OvmsVehicleToyotaRav4Ev::WebCooling(PageEntry_t&, PageContext_t&)':
L:/OVMS/home/miimura/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_toyotarav4ev/src/vehicle_toyotarav4ev.cpp:100:50:
error: invalid use of member
'OvmsVehicleToyotaRav4Ev::m_v_bat_cool_in_temp' in static member function
   c.printf("<p>Battery Coolant Inlet: %.1f C</p>",
m_v_bat_cool_in_temp->AsFloat());
In file included from
L:/OVMS/home/miimura/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_toyotarav4ev/src/vehicle_toyotarav4ev.cpp:38:0:
L:/OVMS/home/miimura/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/vehicle_toyotarav4ev/src/vehicle_toyotarav4ev.h:90:22:
note: declared here
     OvmsMetricFloat *m_v_bat_cool_in_temp;
Anybody have a clue what I'm doing wrong here?
- Mike
On Thu, May 27, 2021 at 4:23 PM Stephen Casner <casner at acm.org> wrote:
> On Thu, 27 May 2021, Michael Iimura wrote:
> > I am planning to work on support for the Tesla Powered 2012-2014 Toyota
> > RAV4 EV. I don't see any evidence of earlier work on Github. I have done
> > some preliminary recon and determined that only the main Toyota CAN and
> > Tesla CAN are needed for the desired information. Maybe K-Line for TPMS
> > would be nice since the car won't display pressures, but the Toyota
> > Techstream diagnostic software does. The most valuable information is on
> > the Tesla CAN and should be similar or exactly the same as other Tesla
> > models.
> Welcome!  The Tesla Roadster is one of the most complete
> implementations since it was first, but the CAN protocols in later
> models are much different.  I know Mark has implemented some support
> for the Model S which should be more similar.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210702/aec4d67b/attachment.htm>
