[Ovmsdev] GPS location glitch (flatbed theft false alert)
Craig Leres leres at xse.com
Thu Jul 1 01:39:07 HKT 2021
On 6/30/21 1:05 AM, Michael Balzer wrote:
>> Another (possibly far fetched) idea I had was is it possible we'
>> seeing corruption transferring the gps location from the simcom to the
>> esp32? A race condition where the latitude or the longitude gets
>> clobbered while reading it? I don't have a good idea of what other
>> symptoms that kind of problem would have.
> Actually… not far fetched at all, as we continuously see multiplex frame
> errors in the logs -- see my previous posts on this. We don't have flow
> control on the ESP-SIMCOM serial line, and the handler may not catch all
> losses.
> You can test that theory by enabling the verbose log on "gsm-nmea". Be
> aware that's a lot of log messages.
> Better option: I already do some consistency checks in
> GsmNMEA::IncomingLine(), but I didn't implement the NMEA checksum. You
> might give that a try first.
Ooooh NMEA... Yeah, if we're getting errors there I can guess where the
0.0's are coming from; gps2latlon() uses atof() so if the field it tries
to parse is empty or is a non-numeric, it'll return 0.0.
I'll spend some time looking at that module, at a minimum implementing
the checksum is worth doing.
		Craig
