[Ovmsdev] External Wifi antenna
Sun Jan 31 16:02:04 HKT 2021
Forgot to explain: to fully disable the PSRAM workaround, you also need
to modify main/component.mk:
COMPONENT_ADD_LDFLAGS = -Wl,--whole-archive -l$(COMPONENT_NAME)
-Wl,--no-whole-archive -T main/ovms_boot.ld \
     -mfix-esp32-psram-cache-issue
Remove the "-mfix-esp32-psram-cache-issue" here.
Am 31.01.21 um 08:58 schrieb Michael Balzer:
> Craig,
> congratulations to a successful heart transplantation :-)
> Regarding RAM, I think you need to enable bank switching
> (CONFIG_SPIRAM_BANKSWITCH_ENABLE).
> Please also disable the PSRAM bug workaround and maybe do some
> performance comparison. SPIRAM operations should run much faster
> without the workaround.
> Am 31.01.21 um 08:29 schrieb Craig Leres:
>> On 1/30/21 9:47 PM, Craig Leres wrote:
>>> It doesn't look like ovms knows there is extra memory?
>> I think actually the idf assumes 4 MB of SPIRAM and a future version
>> will allow use of more memory.
>> I also figured out that my oldest ovms module has 16 MB of flash.
>>         Craig
>> ice 6540 % python esptool_py/esptool/esptool.py \
>>     --chip esp32 \
>>     --port /dev/tty.SLAB_USBtoUART \
>>     --baud 921600 \
>>     flash_id
>> esptool.py v2.8
>> Serial port /dev/ovms-dev
>> Connecting........_
>> Chip is ESP32D0WDQ6 (revision 1)
>> Features: WiFi, BT, Dual Core, Coding Scheme None
>> Crystal is 40MHz
>> MAC: 30:ae:a4:??:??:??
>> Uploading stub...
>> Running stub...
>> Stub running...
>> Changing baud rate to 921600
>> Changed.
>> Manufacturer: ef
>> Device: 6018
>> Detected flash size: 16MB
>> Hard resetting via RTS pin...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210131/c5627fb1/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210131/c5627fb1/attachment.sig>
