[Ovmsdev] External Wifi antenna
Sun Jan 31 15:58:02 HKT 2021
Craig,
congratulations to a successful heart transplantation :-)
Regarding RAM, I think you need to enable bank switching
(CONFIG_SPIRAM_BANKSWITCH_ENABLE).
Please also disable the PSRAM bug workaround and maybe do some
performance comparison. SPIRAM operations should run much faster without
the workaround.
Am 31.01.21 um 08:29 schrieb Craig Leres:
> On 1/30/21 9:47 PM, Craig Leres wrote:
>> It doesn't look like ovms knows there is extra memory?
> I think actually the idf assumes 4 MB of SPIRAM and a future version
> will allow use of more memory.
> I also figured out that my oldest ovms module has 16 MB of flash.
> Craig
> ice 6540 % python esptool_py/esptool/esptool.py \
> --chip esp32 \
> --port /dev/tty.SLAB_USBtoUART \
> --baud 921600 \
> flash_id
> esptool.py v2.8
> Serial port /dev/ovms-dev
> Connecting........_
> Chip is ESP32D0WDQ6 (revision 1)
> Features: WiFi, BT, Dual Core, Coding Scheme None
> Crystal is 40MHz
> MAC: 30:ae:a4:??:??:??
> Uploading stub...
> Running stub...
> Stub running...
> Changing baud rate to 921600
> Changed.
> Manufacturer: ef
> Device: 6018
> Detected flash size: 16MB
> Hard resetting via RTS pin...
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210131/60266727/attachment.sig>
