[Ovmsdev] Fwd: How does TPMS work now?
sharkcow
sharkcow at gmx.de
Mon Jan 25 16:07:33 HKT 2021
Hello all,
probably this is a stupid question, but can I set/read individual
elements of an array on the command line? More importantly, is there a
way to access individual elements in WebPlugins (I know I could write a
script, but that seems to be overkill and I'd first have to find out
exactly how to do it :-/)
Thanks!
sharkcow
Am 23.01.21 um 18:22 schrieb Michael Balzer:
> It seems the list server still has issues:
> -------- Weitergeleitete Nachricht --------
> Betreff: Re: [Ovmsdev] How does TPMS work now?
> Datum: Mon, 18 Jan 2021 07:54:31 +0100
> Von: Michael Balzer <dexter at expeedo.de>
> An: ovmsdev at lists.openvehicles.com
> Craig,
> vector metrics can (as all metrics btw) be set by their string
> representation, i.e.
> metrics set v.t.pressure 210.29,210.29,210.29,210.29
> …and all TPMS metrics (also the new ones) are persistent now, see my
> post "extended metrics persistence".
> Regarding the sensor sets, I haven't used them yet, and documentation is
> lacking, so you need to check the source.
> Am 18.01.21 um 04:11 schrieb Craig Leres:
>> It used to be possible to manually set tire pressure with:
>> metrics set v.tp.fl.p 210.29
>> metrics set v.tp.fr.p 210.29
>> metrics set v.tp.rl.p 210.29
>> metrics set v.tp.rr.p 210.29
>> but after upgrading to the latest persistent metrics code I see these
>> are all gone.
>> I looked at the tpms command but it seems to be designed to track
>> different sets of tpms sensor id numbers.
>> Is it possible to set these from the command line? Are tpms tire
>> pressures (and temperatures) still persistent across warm reboots? Is
>> my problem that these are stored in vectors now and there is not yet a
>> way to manipulate them from the command line?
>> Craig
