[Ovmsdev] Fwd: How does TPMS work now?
Sun Jan 24 01:22:11 HKT 2021
It seems the list server still has issues:
-------- Weitergeleitete Nachricht --------
Betreff: Re: [Ovmsdev] How does TPMS work now?
Datum: Mon, 18 Jan 2021 07:54:31 +0100
Von: Michael Balzer <dexter at expeedo.de>
An: ovmsdev at lists.openvehicles.com
Craig,
vector metrics can (as all metrics btw) be set by their string
representation, i.e.
metrics set v.t.pressure 210.29,210.29,210.29,210.29
…and all TPMS metrics (also the new ones) are persistent now, see my
post "extended metrics persistence".
Regarding the sensor sets, I haven't used them yet, and documentation is
lacking, so you need to check the source.
Am 18.01.21 um 04:11 schrieb Craig Leres:
> It used to be possible to manually set tire pressure with:
> metrics set v.tp.fl.p 210.29
> metrics set v.tp.fr.p 210.29
> metrics set v.tp.rl.p 210.29
> metrics set v.tp.rr.p 210.29
> but after upgrading to the latest persistent metrics code I see these
> are all gone.
> I looked at the tpms command but it seems to be designed to track
> different sets of tpms sensor id numbers.
> Is it possible to set these from the command line? Are tpms tire
> pressures (and temperatures) still persistent across warm reboots? Is
> my problem that these are stored in vectors now and there is not yet a
> way to manipulate them from the command line?
> Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210123/f34b1421/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210123/f34b1421/attachment.sig>
