[Ovmsdev] CAN drivers: fix & harmonize frame transmission failure handling
Fri Jan 8 00:02:01 HKT 2021
Everyone,
please pull & test the new "can-txfail-fix" branch. It's up to date and
includes the BMW i3 code already.
I need to get feedback from users of both can1 (esp32can) & can2/3/4
(mcp2515), as changes had to be made to both drivers.
I'll quote from my commit:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/c94592a11ad2c989e65313d23a8876cf38787d70
Design goals:
- any TX can either fail or succeed, the result state is terminal
- the respective TX callback is called exactly once
- transmissions fail on reaching the error-passive bus state
and on message/bus errors while in error-passive state
- a failed TX will be aborted (no retries after bus recovery),
i.e. will be retried at most 128 times (in error-active phase)
- reduce excessive CAN error logging
- reduce excessive interrupt load with switched-off buses
This results in the application being able to reliably detect a
switched-off vehicle bus by the TX callback's success indicator.
It also results in frames no longer being held in the TX buffer
or added to the TX queue when the bus is switched off. The
application can now rely on getting a clean bus state on every
reconnect, without any queued old frames to be sent automatically.
Secondary benefit from aborting the transmission is, the module
doesn't need to handle the load from the continuously triggered
CAN error interrupts by retransmission attempts in error-passive
state.
Reason for this was a) Steve's question on aborting transmissions /
flushing the queue and b) my new car now also switching off the bus,
with the annoying effect of a frozen can1 every 2-3 days, needing to
reboot the module. I'm not sure yet if the freeze issue is solved, but I
haven't had it since running these changes on my module.
The other issue of the transceivers resending frames queued long ago may
have caused all sorts of strange & unrepeatable issues. I remember the
VW crew having problems that fell into this category.
I've verified the new MCP2515 implementation only on my workbench (with
an Arduino as the CAN tester), so real life tests are necessary.
Thanks,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210107/96587e6f/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210107/96587e6f/attachment.sig>
