[Ovmsdev] Open issues blocking release 3.2.016
sharkcow sharkcow at gmx.de
Sun Feb 28 02:57:03 HKT 2021
Ah, thanks for the tip (I had that on in the beginning but could'nt make
much of the logs so I'd turned it off meanwhile :-/)
Here's a bit more log info.
Am 27.02.21 um 17:57 schrieb Michael Balzer:
> Heiko,
> off-topic, but that's why I provide the email export feature on my
> server. Simply tick the checkbox and set your desired export time, and
> the server will send you a full data export zipped once per day.
> That way you can always go gack in time to any point.
> Your log excerpt was a bit too narrowed down, please show a few more
> messages with the "location" tag around the alert.
> Am 27.02.21 um 17:41 schrieb sharkcow:
>> I got one false theft alert a few days back, but it seems the server
>> logs aren't saved that long... :(
>> relevant lines of console log attached.
>> sharkcow
>> Am 27.02.21 um 16:47 schrieb Michael Balzer:
>>> As the other thread got off-topic: I'd still like to get forward
>>> regarding release 3.2.016.
>>> We identified three open issues:
>>>  1. VW e-Up sometimes stays awake for 4-5 hours.
>>>  2. Wifi AP connection is unstable with some devices.
>>>  3. More frequent location flatbed theft false alerts.
>>> My current status on these is:
>>>  1. …is probably not a bug on the OVMS but rather a real behaviour of
>>>     the e-Up performing an extended 12V trickle charge.
>>>  2. …has only been reported by Steve Davies and seems (?) to have been
>>>     solved by the default scan timings – Steve?
>>>  3. …seems to be a Heisenbug, i.e. hasn't had any reports since we added
>>>     extended logging.
>>> Is my status correct? If so, I think these should no longer stop us from
>>> releasing 3.2.016.
Type: text/x-log
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210227/e0d96402/attachment-0001.bin>
