[Ovmsdev] Shell syntax to write a value
Thu Feb 25 15:51:53 HKT 2021
Didier,
Am 25.02.21 um 00:15 schrieb didier at ernotte.com:
> I can easily read a PID value using the shell syntax in the web
> browser : "obdii can1 request device 7e4 7ec 22ddd00" for example.
> I understand that "0x22" is used to read data by identifier, and I
> read that "0x2E" would be used to write data by identifier but what
> would be the correct syntax to write a value to a PID in the shell ?
> or it is not possible yet ?
You can send any OBD request that fits into a single frame.
If 2E is the write command for your device & PID (there are others and
even non standard ones), it's simply…
obdii can1 request device 7e4 7ec 2e<pid><value>
The poller doesn't yet support multi frame requests (only responses), so
the max request length for standard addressing mode is 7 bytes, leaving
4 bytes payload for a 16 bit PID command.
See ISO 15031 and ISO 14229 for standard OBD/UDS requests and responses.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210225/0d2d15f5/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210225/0d2d15f5/attachment.sig>
