[Ovmsdev] Time for release 3.2.016?
Steve Davies steve at telviva.co.za
Mon Feb 15 23:28:20 HKT 2021
Hi,
I went out yesterday and looking now at the esp32wifi log entries:
Here's when it doesn't find anything:
2021-02-14 15:31:25.113 SAST V (13273) esp32wifi: StartConnect: scan started
2021-02-14 15:31:28.433 SAST V (16593) esp32wifi: EventWifiScanDone: no
access points found
Here's where it finds "foreign" ones:
2021-02-14 15:45:23.852 SAST V (33292) esp32wifi: StartConnect: scan started
2021-02-14 15:45:27.482 SAST V (36922) esp32wifi: ScanDone: #01
ssid='BMWi23024 CarPlay' bssid='b8:9f:09:26:0f:9f' chan=11 rssi=-49
2021-02-14 15:45:27.482 SAST V (36922) esp32wifi: EventWifiScanDone: no
known SSID found
and:
2021-02-14 15:47:11.947 SAST V (13287) esp32wifi: StartConnect: scan started
2021-02-14 15:47:16.177 SAST V (17517) esp32wifi: ScanDone: #01
ssid='BMWi23024 CarPlay' bssid='b8:9f:09:26:0f:9f' chan=11 rssi=-54
2021-02-14 15:47:16.177 SAST V (17517) esp32wifi: ScanDone: #02
ssid='Residenz2' bssid='c8:3a:35:50:a2:d0' chan=6 rssi=-91
2021-02-14 15:47:16.177 SAST V (17517) esp32wifi: ScanDone: #03
ssid='mywifi' bssid='04:95:e6:d1:f2:b0' chan=5 rssi=-93
2021-02-14 15:47:16.177 SAST V (17517) esp32wifi: ScanDone: #04
ssid='HUAWEI-A5F9' bssid='34:12:f9:fd:a5:f9' chan=11 rssi=-95
2021-02-14 15:47:16.177 SAST V (17517) esp32wifi: EventWifiScanDone: no
known SSID found
and:
2021-02-14 15:47:31.947 SAST V (33287) esp32wifi: StartConnect: scan started
2021-02-14 15:47:36.477 SAST V (37817) esp32wifi: ScanDone: #01
ssid='BMWi23024 CarPlay' bssid='b8:9f:09:26:0f:9f' chan=11 rssi=-50
2021-02-14 15:47:36.477 SAST V (37817) esp32wifi: ScanDone: #02
ssid='TP-LINK_58FEB6' bssid='c4:e9:84:58:fe:b6' chan=6 rssi=-89
2021-02-14 15:47:36.477 SAST V (37817) esp32wifi: ScanDone: #03
ssid='TP-Link_F60F' bssid='d8:47:32:04:f6:0f' chan=1 rssi=-92
2021-02-14 15:47:36.477 SAST V (37817) esp32wifi: ScanDone: #04
ssid='TP-Link_Guest_F60F' bssid='da:47:32:14:f6:0f' chan=1 rssi=-92
2021-02-14 15:47:36.477 SAST V (37817) esp32wifi: ScanDone: #05 ssid=''
bssid='c4:e9:84:58:f7:8e' chan=6 rssi=-92
2021-02-14 15:47:36.477 SAST V (37817) esp32wifi: ScanDone: #06
ssid='David's Unifi' bssid='0a:18:d6:a9:f9:a6' chan=1 rssi=-93
2021-02-14 15:47:36.477 SAST V (37817) esp32wifi: ScanDone: #07
ssid='Shalombosch' bssid='d4:6a:91:70:c9:e4' chan=7 rssi=-93
2021-02-14 15:47:36.477 SAST V (37817) esp32wifi: EventWifiScanDone: no
known SSID found
So the scan seems to take 4-5 seconds.
As the car drives along the scan picks up a wide variety of SSIDs.
I'm sure that you are right that the SSID disappears for long enough for
the tablet to lose connection.  Unfortunately the tablet then jumps to LTE
(so no more connection to 192.168.4 network) and it is quite a while before
IT notices that the SSID is back and reconnects.
I don't really follow though why the AP is taken down to do this since when
the car is home it is able to connect to my home Wifi AND operate the AP?
>From the log it appears that sometimes the scan is done every 10 seconds
and sometimes it seems to be every 80 seconds or so.
Obviously a scan done every 10 seconds that takes the SSID down for 4 to 5
seconds isn't going to make the AP near useless.
Steve
On Sat, 13 Feb 2021 at 20:50, Michael Balzer <dexter at expeedo.de> wrote:
> You're right, the same scan timing parameters are applied in fixed mode
> after losing the connection.
> So you need to try disabling client mode.
> Am 13.02.21 um 19:43 schrieb Steve Davies:
> Hi Michael,
> On Sat, 13 Feb 2021 at 20:31, Michael Balzer <dexter at expeedo.de> wrote:
>> do you run the wifi client in scanning mode or with a fixed SSID?
> Gotta say I don't know.
> I have added the SSID  for the house.  And only that one.
> I don't see anything in the settings about scanning, or on the web
> interface?
> OVMS# config list wifi.ssid
> wifi.ssid (protected writeable)
>   DvDevs
> OVMS# config list wifi.ap
> wifi.ap (protected writeable)
>   DvPanda
> But even with just DvDevs defined, surely if the OVMS is going to
> reconnect when I get home then it will have to scan from time to time for
> DvDevs otherwise how would it ever know to reconnect?    (Well - one idea
> is to be able to tell it to only look if you are in a specific location
> ("Home").
> I did enable verbose logging for esp32wifi and I'll see what that tells me.
> Steve
> https://www.telviva.co.za/legal/email-disclaimer
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
<https://www.telviva.co.za/legal/email-disclaimer>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210215/e6f4c07d/attachment-0003.htm>
