[Ovmsdev] Coding help
Mon Feb 15 16:05:07 HKT 2021
Shane,
I forgot to mention: if you're working on a new vehicle module, you'll
also need to start the bus somewhere in your initialization code. Example:
RegisterCanBus(1, CAN_MODE_ACTIVE, CAN_SPEED_500KBPS);
Am 15.02.21 um 08:36 schrieb Michael Balzer:
> Shane,
> Am 14.02.21 um 16:42 schrieb Shane @ Kilve Engineering:
>> can any one help me with a bit of code to retrieve ve some data from
>> ecu can1/6f2 00 4c 00 00 01 97 bc 00 as i cant poll this ecu it just
>> broadcasts when its active, ive tried polling it but does not
>> respond, i need to choose one byte and allocate it to a PID.
> I don't know what you mean by "allocating a byte to a PID", but if you
> want to process frames received directly, simply override
> IncomingFrameCan1() (or …2/3/4 depending on your bus).
> Reduced example:
> void OvmsVehicleXYZ::IncomingFrameCan1(CAN_frame_t *p_frame)
> uint8_t *d = p_frame->data.u8;
> switch (p_frame->MsgID)
> case 0x6f2:
> // for example, assuming the SOC is in byte 1:
> StdMetrics.ms_v_bat_soc->SetValue(d[1]);
> break;
> If you're outside a vehicle context, you can register your own CAN
> receiver by creating a queue and calling MyCan.RegisterListener(). See
> the vehicle module for an example.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210215/32a74792/attachment.sig>
