[Ovmsdev] Coding help
Mon Feb 15 15:36:51 HKT 2021
Shane,
Am 14.02.21 um 16:42 schrieb Shane @ Kilve Engineering:
> can any one help me with a bit of code to retrieve ve some data from ecu can1/6f2  00 4c 00 00 01 97 bc 00 as i cant poll this ecu it just broadcasts when its active, ive tried polling it but does not respond, i need to choose one byte and allocate it to a PID.
I don't know what you mean by "allocating a byte to a PID", but if you
want to process frames received directly, simply override
IncomingFrameCan1() (or …2/3/4 depending on your bus).
Reduced example:
void OvmsVehicleXYZ::IncomingFrameCan1(CAN_frame_t *p_frame)
   uint8_t *d = p_frame->data.u8;
   switch (p_frame->MsgID)
     case 0x6f2:
       // for example, assuming the SOC is in byte 1:
       StdMetrics.ms_v_bat_soc->SetValue(d[1]);
       break;
If you're outside a vehicle context, you can register your own CAN
receiver by creating a queue and calling MyCan.RegisterListener(). See
the vehicle module for an example.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210215/d51e7c64/attachment.sig>
