[Ovmsdev] Time for release 3.2.016?
Sat Feb 13 09:06:48 HKT 2021
On Fri, 12 Feb 2021, Stephen Casner wrote:
> > > switching mongoose to use wolfSSL would require increasing that
> > > set.  I'd be happy to try that.
> > That would be great.
> > Mongoose has an SSL library abstraction layer, but there certainly will be
> > dragons...
> The Espressif reference you cited included a step of switching the
> ESP-TLS configuration parameter from mbedtls to wolfssl.  If Mongoose
> was going to mbedtls through ESP-TLS, then that configuration might
> take care of it.  But if not, ...
Hmmm, it looks like the documentation on using wolfssl with ESP-IDF
assumes the new CMake build system, not the older build system that we
are still using for OVMS.  You may be right about the dragons.
