[Ovmsdev] GPS theft alert
Chris van der Meijden
chris at arachnon.de
Fri Feb 12 19:36:11 HKT 2021
Just a side information.
On Andorid phones it can take 10 minutes to find the satelites if the
time of the phone and the satelites is out of sync. And in that case
the position can also be a few 100 meters off track. As soon as the
times are in sync the GPS signal is immediately there and the position
is correct.
Regards
Chris
Am Freitag, den 12.02.2021, 12:24 +0100 schrieb sharkcow:
> OK, in my case OVMS lost the GPS fix for one log entry, then
> apparently
> my car took a 400m dive! Strange theft approach... ;-)
> Took about 10mins. for GPS to be back in the correct position.
> So, would we want to implement a workaround? Maybe wait with the
> alert
> after fix is lost? But then again, if the car really is towed, I'd
> like
> to know asap...
> Thanks,
> sharkcow
> Am 12.02.21 um 10:35 schrieb Michael Balzer:
> > Please check your "L" log at the time of the alert: what did your
> > GPS
> > data look like just before the alert?
> > There's the option of raising the alert threshold. It's 500 meters
> > by
> > default (config vehicle flatbed.alarmdistance). But we should first
> > determine the cause of the false alerts.
> > Regards,
> > Michael
> > Am 12.02.21 um 10:28 schrieb sharkcow:
> > > I got the theft alert again last night, the car had been standing
> > > for
> > > several hours... so at least in my case I would think the alert
> > > trigger
> > > is too sensitive compared to the resolution/accuracy of the GPS
> > > measurement.
> > > Best regards,
> > > sharkcow
> > > Am 09.02.21 um 18:40 schrieb Michael Balzer:
> > > > I found the reason for the false theft/flatbed alert in my case
> > > > by
> > > > checking my telemetry archive: the car lost GPS on the road.
> > > > Coordinates
> > > > were stale when I parked the car. The stale coordinates were
> > > > taken as
> > > > the initial park coordinates, causing an alert when the GPS
> > > > receiver
> > > > delivered the next valid data (the actual park position).
> > > > So the bad antenna placement actually was the cause in my case,
> > > > but we
> > > > can solve that in software.
> > > > I've just pushed a fix (untested) for this, consisting of a)
> > > > making the
> > > > location module aware of parking coordinate staleness and b)
> > > > lowering
> > > > the staleness thresholds for the GPS metrics to 10 seconds.
> > > > Please verify.
> > > > Regards,
> > > > Michael
> > > > Am 09.02.21 um 10:29 schrieb Michael Balzer:
> > > > > I had the alert once with my Mii, also shortly after parking.
> > > > > With the
> > > > > module being mounted with the GPS antenna placed under the
> > > > > hood, I
> > > > > assumed that to be the cause.
> > > > > I doubt it, but I'll check if any of our changes could have
> > > > > had an
> > > > > impact on the GPS movement detection.
> > > > > Regarding open changes to be included in 3.2.016: sharkcow is
> > > > > currently working on finishing the UpMiiGo TPMS feature, it's
> > > > > already
> > > > > been tested so we'll wait for that.
> > > > > Regards,
> > > > > Michael
> > > > > Am 09.02.21 um 09:57 schrieb sharkcow:
> > > > > > Hi all,
> > > > > > > Twice in the last few weeks I've gotten the "possible
> > > > > > > theft/flatbed"
> > > > > > alert just as I was backing out of the garage. I have never
> > > > > > received
> > > > > > that alert before. I hadn't posted anything yet because I
> > > > > > was
> > > > > > waiting to
> > > > > > drive the other car and see if has the same problem.
> > > > > > I get this too every once in a while with my e-Up. Mostly
> > > > > > shortly
> > > > > > after
> > > > > > parking, I think (and tragically, the one time I'd have
> > > > > > needed it
> > > > > > because I actually _did_ get towed, I had crashed OVMS into
> > > > > > a boot
> > > > > > loop
> > > > > > just before :-/).
> > > > > > sharkcow
> > > > > _______________________________________________
> > > > > OvmsDev mailing list
> > > > > OvmsDev at lists.openvehicles.com
> > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> > > > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210212/d586edad/attachment.htm>
