[Ovmsdev] Temperature precision needlessly high
jaunius at gmx.com
jaunius at gmx.com
Wed Feb 10 06:46:15 HKT 2021
Well I dont't really see a benefit of higher precision for the cabin temperature as well. I guess if we really want to spent time on this it needs to be defined under standard metrics. My suggestion would be to create an issue on GitHub so it can be picked up.
Jaunius
Sent using the GMX mail app
On 2021-02-09 at 12:36, Lance Tjessem wrote:
> For me the value is shown in Home Assistant, which gets the value from
> my MQTT server. In the past I've just let it use the value directly,
> which used to operate with a precision of 0.5 C. I can filter it at
> the front end, it just seemed odd to suddenly jump from 0.5 to 0.00001
> precision for such a reading.
> "metrics list v.e.ca" is also returning the same 0.00001 precision
> but the OVMS android app displays it with a more sensible 0.1
> precision at least.
> On Tue, Feb 9, 2021 at 11:22 AM <jaunius at gmx.com> wrote:
> > Hi Lance,
> > The v.e.cabintemp was a float value before as well. But I guess this is because we introduced a user adjustment feature. Anyway, I think it's more of a GUI issue rather than metric itself.
> > Where are you trying to check it?
> > Regards,
> > Jaunius
> > On 2021-02-09 at 12:17, Lance Tjessem wrote:
> > > I just updated to the latest edge build, and I see that the cabin temp
> > > metric is now needlessly precise. Examples of v/e/cabintemp I've seen
> > > today are -5.55556 and -1.66667
> > > This is on a NL, not sure if it affects other cars as well.
> > > _______________________________________________
> > > OvmsDev mailing list
> > > OvmsDev at lists.openvehicles.com
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> mvh.
> Lance Tjessem
