[Ovmsdev] External Wifi antenna
Charles B Cangialose chip at cangmag.com
Mon Feb 1 10:59:19 HKT 2021
Very impressive, well done(!).  Thanks for sharing, but I don’t have the soldering skills to pull this one off.
> On Jan 31, 2021, at 5:53 PM, Stephen Casner <casner at acm.org> wrote:
> It might be possible to make an adapter between the two pinouts using
> one or two layers of PCB.  But the OVMS v3.0 board made connections
> the the pins on the end that are marked NC on the newer modules but
> were active on the older ESP32-WROOM-32.  The v3.0 board has external
> flash connected there, which wouldn't be needed, but I seem to recall
> that the SD0-3 pins may have been used for some other function in
> addition.
