[Ovmsdev] MacOS Monterey
Tamás Kovács kommykt at gmail.com
Wed Dec 29 16:43:51 HKT 2021
Now working all fine.
I installed Homebrew with a following:
/bin/bash -c "$(curl -fsSL
https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
After that installed python2.7 with the following command:
python2.7 -m ensurepip --default-pip --user
After tha install requirement.txt but i can install tornado, and nose
packages as well, because this dependencies:
python -m pip install --user tornado
python -m pip install --user nose
Now everythings compile fine.
Tamás Kovács <kommykt at gmail.com> ezt írta (időpont: 2021. dec. 29., Sze,
9:11):
> I think my main problem with the python, because esp first step is:
> sudo easy_install pip
> and get the following:
> Password:
> Searching for pip
> Reading https://pypi.org/simple/pip/
> Downloading
> https://files.pythonhosted.org/packages/da/f6/c83229dcc3635cdeb51874184241a9508ada15d8baa337a41093fab58011/pip-21.3.1.tar.gz#sha256=fd11ba3d0fdb4c07fbc5ecbba0b1b719809420f25038f8ee3cd913d3faa3033a
> Best match: pip 21.3.1
> Processing pip-21.3.1.tar.gz
> Writing /tmp/easy_install-_tOHJQ/pip-21.3.1/setup.cfg
> Running pip-21.3.1/setup.py -q bdist_egg --dist-dir
> /tmp/easy_install-_tOHJQ/pip-21.3.1/egg-dist-tmp-nFLUCL
> Traceback (most recent call last):
>   File "/usr/bin/easy_install", line 13, in <module>
>     load_entry_point('setuptools==41.0.1', 'console_scripts',
> 'easy_install')()
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/command/easy_install.py",
> line 2319, in main
>     **kw
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/__init__.py",
> line 145, in setup
>     return distutils.core.setup(**attrs)
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/distutils/core.py",
> line 151, in setup
>     dist.run_commands()
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/distutils/dist.py",
> line 953, in run_commands
>     self.run_command(cmd)
>   File
> line 972, in run_command
>     cmd_obj.run()
>   File
> line 418, in run
>     self.easy_install(spec, not self.no_deps)
>   File
> line 679, in easy_install
>     return self.install_item(spec, dist.location, tmpdir, deps)
>   File
> line 705, in install_item
>     dists = self.install_eggs(spec, download, tmpdir)
>   File
> line 890, in install_eggs
>     return self.build_and_install(setup_script, setup_base)
>   File
> line 1158, in build_and_install
>     self.run_setup(setup_script, setup_base, args)
>   File
> line 1144, in run_setup
>     run_setup(setup_script, args)
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py",
> line 253, in run_setup
>     raise
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/contextlib.py",
> line 35, in __exit__
>     self.gen.throw(type, value, traceback)
>   File
> line 195, in setup_context
>     yield
>   File
>   File
> line 166, in save_modules
>     saved_exc.resume()
>   File
> line 141, in resume
>     six.reraise(type, exc, self._tb)
>   File
> line 154, in save_modules
>     yield saved
>   File
>     yield
>   File
> line 250, in run_setup
>     _execfile(setup_script, ns)
>   File
> line 44, in _execfile
>     code = compile(script, filename, 'exec')
>   File "/tmp/easy_install-_tOHJQ/pip-21.3.1/setup.py", line 7
>     def read(rel_path: str) -> str:
> SyntaxError: invalid syntax
> Monterey defaul python is:
> kommykt at Tamass-Air esp % python --version
> Python 2.7.18
> Now i create a new fresh install.
> Mark Webb-Johnson <mark at webb-johnson.net> ezt írta (időpont: 2021. dec.
> 29., Sze, 0:44):
>> I build on Monterey ok.
>> Perhaps double check the sdkconfig vs support/sdkconfig.default.hw31? And
>> a ‘make clean’?
>> > On 29 Dec 2021, at 12:26 AM, Tamás Kovács <kommykt at gmail.com> wrote:
>> > I now update (create a fresh install) my Mac  (Macbok air 2017) to
>> macOS Monterey and developing not working.
>> > I get a following when compile a code, this a main repo, without
>> modification, fresh install.
>> > Any suggestions? Go back to BigSur?
>> > <Terminal>_______________________________________________
>> > OvmsDev mailing list
>> > OvmsDev at lists.openvehicles.com
>> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> Üdvözlettel:
> Kovács Tamás
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211229/50058279/attachment-0001.htm>
