[Ovmsdev] MacOS Monterey
    Tamás Kovács
    kommykt at gmail.com
    Wed Dec 29 16:11:05 HKT 2021
I think my main problem with the python, because esp first step is:
sudo easy_install pip
and get the following:
Password:
Searching for pip
Reading https://pypi.org/simple/pip/
Downloading
https://files.pythonhosted.org/packages/da/f6/c83229dcc3635cdeb51874184241a9508ada15d8baa337a41093fab58011/pip-21.3.1.tar.gz#sha256=fd11ba3d0fdb4c07fbc5ecbba0b1b719809420f25038f8ee3cd913d3faa3033a
Best match: pip 21.3.1
Processing pip-21.3.1.tar.gz
Writing /tmp/easy_install-_tOHJQ/pip-21.3.1/setup.cfg
Running pip-21.3.1/setup.py -q bdist_egg --dist-dir
/tmp/easy_install-_tOHJQ/pip-21.3.1/egg-dist-tmp-nFLUCL
Traceback (most recent call last):
  File "/usr/bin/easy_install", line 13, in <module>
    load_entry_point('setuptools==41.0.1', 'console_scripts',
'easy_install')()
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/command/easy_install.py",
line 2319, in main
    **kw
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/__init__.py",
line 145, in setup
    return distutils.core.setup(**attrs)
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/distutils/core.py",
line 151, in setup
    dist.run_commands()
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/distutils/dist.py",
line 953, in run_commands
    self.run_command(cmd)
  File
line 972, in run_command
    cmd_obj.run()
  File
line 418, in run
    self.easy_install(spec, not self.no_deps)
  File
line 679, in easy_install
    return self.install_item(spec, dist.location, tmpdir, deps)
  File
line 705, in install_item
    dists = self.install_eggs(spec, download, tmpdir)
  File
line 890, in install_eggs
    return self.build_and_install(setup_script, setup_base)
  File
line 1158, in build_and_install
    self.run_setup(setup_script, setup_base, args)
  File
line 1144, in run_setup
    run_setup(setup_script, args)
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py",
line 253, in run_setup
    raise
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/contextlib.py",
line 35, in __exit__
    self.gen.throw(type, value, traceback)
  File
line 195, in setup_context
    yield
  File
  File
line 166, in save_modules
    saved_exc.resume()
  File
line 141, in resume
    six.reraise(type, exc, self._tb)
  File
line 154, in save_modules
    yield saved
  File
    yield
  File
line 250, in run_setup
    _execfile(setup_script, ns)
  File
line 44, in _execfile
    code = compile(script, filename, 'exec')
  File "/tmp/easy_install-_tOHJQ/pip-21.3.1/setup.py", line 7
    def read(rel_path: str) -> str:
SyntaxError: invalid syntax
Monterey defaul python is:
kommykt at Tamass-Air esp % python --version
Python 2.7.18
Now i create a new fresh install.
Mark Webb-Johnson <mark at webb-johnson.net> ezt írta (időpont: 2021. dec.
29., Sze, 0:44):
> I build on Monterey ok.
> Perhaps double check the sdkconfig vs support/sdkconfig.default.hw31? And
> a ‘make clean’?
> > On 29 Dec 2021, at 12:26 AM, Tamás Kovács <kommykt at gmail.com> wrote:
> > I now update (create a fresh install) my Mac  (Macbok air 2017) to macOS
> Monterey and developing not working.
> > I get a following when compile a code, this a main repo, without
> modification, fresh install.
> > Any suggestions? Go back to BigSur?
> > <Terminal>_______________________________________________
> > OvmsDev mailing list
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211229/b10263de/attachment-0001.htm>
