[Ovmsdev] OVMS v3.3 hardware
Tue Aug 17 15:31:33 HKT 2021
Mark,
1. I had the impression we've had more than expected "modem not/stopped
working" issues. Is that impression wrong, or didn't those cases share a
hardware cause? I was wondering if that could be related to a voltage
regulator issue (e.g. https://www.openvehicles.com/node/2855).
2. Any chance to fix the missing HW flow control on the modem UART
connection?
3. Will v3.3 automatically be built using the latest ESP32 WROVER, i.e.
with the revision 3 ESP32 including the hardware SPIRAM fix?
Am 17.08.21 um 07:30 schrieb Mark Webb-Johnson:
> For the 4G modem options we need to go through FCC, CE, and ROHS
> certification. Minimising/eliminating the changes to the main board
> simplifies this (and brings down the exorbitant costs) but if there is
> anything urgent / necessary, now is the time to do it.
> The goal here is to maintain 100% compatibility with existing OVMS
> main boards, to keep this is a simple and relatively cheap upgrade of
> the modem board.
> So far, I have come up with this minimal list:
>  1. Main board v3.3: Improve soldering of micro USB port. Bigger
>     solder pads, and more solder to secure it better.
>  2. Modem board v1.3: Add support for SIM7600 module.
>  3. Modem board v1.3: Fix support for DTR sleep/awake support.
> Is there anything else required for this update?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210817/e26bb5e6/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210817/e26bb5e6/attachment.sig>
