[Ovmsdev] Bolt Ampera-e support
Edwin ten Haaf edwin at familietenhaaf.nl
Sun Apr 25 14:18:03 HKT 2021
Goodmorning all,
I made little progress but now I'm stuck and could need some help/advice.
Made a new vehicle template from the hyundayionic as advised.
Changed the pids but it's not working very well. Sometimes the app seems to
come alive and shows it's charging but it's not reproducable.
Same happens when picking Volt/Ampera module for my ampera-e.
I don't know how to investigate this further. I have some logs attached and
my work in progress on Github
<https://github.com/Edwintenhaaf/Open-Vehicle-Monitoring-System-3/tree/bolt-amperae-support/vehicle/OVMS.V3/components/vehicle_boltamperae>
Thanks in advance,
Edwin
I (37857379) v-bae: Chevrolet Bolt / Opel Ampera-e vehicle module
D (37857379) events: Signal(power.can1.on)
D (37857379) max7317: egpio.output.2.low
D (37857379) events: Signal(egpio.output.2.low)
D (37857389) metrics: pmetrics_register: 'xbae.c.state' => slot=68, used 78/100
D (37857389) metrics: pmetrics_register: 'xbae.b.soc.bms' => slot=69,
used 78/100
D (37857389) events: Signal(vehicle.type.set)
D (37857759) events: Signal(config.changed)
D (37857759) webserver: ConfigChanged: config.changed auto
I (37858279) webserver: HTTP GET /menu
I (37858299) location: UpdateParkPosition: vehicle is driving
I (37858299) v-bae: PollerStateTicker: [online] charge_state=00 =>
PollState 0->1
D (37858299) vehicle: PollerSend(1): send [bus=0, type=22, pid=8334],
expecting 7e4/7ec-7ec
E (37858299) can: can1: intr=1 rxpkt=0 txpkt=0 errflags=0x8000d9
rxerr=0 txerr=8 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
wdgreset=0 errreset=0
E (37858309) can: can1: intr=3 rxpkt=0 txpkt=0 errflags=0x8000d9
rxerr=0 txerr=24 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
E (37858309) can: can1: intr=5 rxpkt=0 txpkt=0 errflags=0x8000d9
rxerr=0 txerr=40 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
E (37858309) can: can1: intr=7 rxpkt=0 txpkt=0 errflags=0x8000d9
rxerr=0 txerr=56 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
E (37858309) can: can1: intr=9 rxpkt=0 txpkt=0 errflags=0x8000d9
rxerr=0 txerr=72 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
E (37858309) can: can1: intr=10 rxpkt=0 txpkt=0 errflags=0x8000d9
rxerr=0 txerr=80 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
E (37858309) can: can1: intr=13 rxpkt=0 txpkt=0 errflags=0x8040d9
rxerr=0 txerr=104 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
E (37858309) can: can1: intr=19 rxpkt=0 txpkt=0 errflags=0x8040a4
rxerr=5 txerr=112 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
E (37858309) can: can1: intr=24 rxpkt=0 txpkt=0 errflags=0x8040a4
rxerr=12 txerr=112 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
E (37858309) can: can1: intr=27 rxpkt=0 txpkt=0 errflags=0xa040d9
rxerr=13 txerr=128 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0
E (37858319) can: can1: intr=28 rxpkt=0 txpkt=0 errflags=0x804cd9
rxerr=13 txerr=128 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=1
D (37858309) events: Signal(vehicle.aux.12v.on)
D (37858319) events: Signal(vehicle.charge.12v.start)
D (37858319) events: Signal(vehicle.awake)
D (37858329) events: Signal(vehicle.on)
D (37858329) events: Signal(vehicle.charge.state)
I (37859289) powermgmt: Charging 12V battery..
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210425/ea359c9e/attachment.htm>
