[Ovmsdev] can log vfs crashes
Derek Caudwell d.caudwell at gmail.com
Wed Sep 30 14:43:42 HKT 2020
Hi Michael,
When the vehicle is not set to poll and only receiving can1 messages I
managed to obtain a 10Mb file - logging a variety of signals some with 10ms
timing without any issues. However, when polling and can1/can2 are
operating and I try to log the same signals I get the following crash
trace. I would suspect the underlying cause of the crashing relates to both
buses being active as opposed to the polling but that may not be the case.
Last crash: abort() was called on core 0 Backtrace: 0x4008e627 0x4008e8c1
0x400e7060 0x40083f6a Event: ticker.1 at esp32wifi 0 secs WDT tasks:
IDLE1|OVMS DukTape
0x4008e627 is in invoke_abort
(/mnt/c/linux/ovms/esp-idf/components/esp32/panic.c:156).
151     #endif
152         while (1) {
153             if (esp_cpu_in_ocd_debug_mode()) {
154                 __asm__ ("break 0,0");
155             }
156             *((int *) 0) = 0;
157         }
158     }
159
160     void abort()
0x4008e8c1 is in abort
(/mnt/c/linux/ovms/esp-idf/components/esp32/panic.c:171).
166          * don't overwrite that.
167          */
168         if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) {
169             esp_reset_reason_set_hint(ESP_RST_PANIC);
170         }
171         invoke_abort();
172     }
173
174
175     static const char *edesc[] = {
0x400e7060 is in task_wdt_isr
(/mnt/c/linux/ovms/esp-idf/components/esp32/task_wdt.c:174).
169         esp_task_wdt_isr_user_handler();
170         if (twdt_config->panic){     //Trigger Panic if configured to
do so
171             ESP_EARLY_LOGE(TAG, "Aborting.");
172             portEXIT_CRITICAL_ISR(&twdt_spinlock);
173             esp_reset_reason_set_hint(ESP_RST_TASK_WDT);
174             abort();
175         }
176
177         portEXIT_CRITICAL_ISR(&twdt_spinlock);
178     }
0x40083f6a is at
/mnt/c/linux/ovms/esp-idf/components/freertos/xtensa_vectors.S:1154.
1149        wsr     a0, PS
1150        rsync
1151
1152        /* OK to call C code at this point, dispatch user ISRs */
1153
1154        dispatch_c_isr 1 XCHAL_INTLEVEL1_MASK
1155
1156        /* Done handling interrupts, transfer control to OS */
1157        call0   XT_RTOS_INT_EXIT                /* does not return
directly here */
1158
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200930/3d8c241c/attachment-0002.htm>
