[Ovmsdev] dexters-web.de has moved to a new server
Sat Sep 26 21:38:50 HKT 2020
In case someone else gets into this on a new server installation:
HTTP requests done by the server to post push notifications to Google
all failed, logging…
EV: error in callback (ignoring): dh params schmorp1539: failed to set
DH parameters at /usr/share/perl5/vendor_perl/AnyEvent/HTTP.pm line 850.
I had installed the distribution's (CentOS 8) perl packages as far as
available instead of using CPAN, so I got perl-AnyEvent version 7.14
(from the PowerTools repository).
Unfortunately, that doesn't include a crucial fix to default to
schmorp2048 instead of schmorp1539. See this blog entry for the patch:
https://blog.kutej.net/2019/09/failed-to-set-DH-parameters
On CentOS 8, the patch needs to be applied to:
/usr/lib64/perl5/vendor_perl/AnyEvent/TLS.pm
Am 26.09.20 um 13:07 schrieb Michael Balzer:
> Everyone,
> I've just moved dexters-web.de to a new server.
> This applies as well to the OVMS server. If you already used the name
> ovms.dexters-web.de to access the server, you don't need to change anything.
> If you want to or need to use the IP address, you need to change that
> now to the new IP: 146.0.237.226
> The port forwarding will be stopped in about two weeks.
> Please contact me in case of any issues.
> The new server of course is also run on 100% renewable energy. The new
> data center is located in Frankfurt (Germany), in close proximity to the
> DE-CIX. Due to this and the new hardware, latency and performance should
> show substantial improvement.
