[Ovmsdev] dexters-web.de has moved to a new server
Sat Sep 26 19:07:26 HKT 2020
Everyone,
I've just moved dexters-web.de to a new server.
This applies as well to the OVMS server. If you already used the name
ovms.dexters-web.de to access the server, you don't need to change anything.
If you want to or need to use the IP address, you need to change that
now to the new IP: 146.0.237.226
The port forwarding will be stopped in about two weeks.
Please contact me in case of any issues.
The new server of course is also run on 100% renewable energy. The new
data center is located in Frankfurt (Germany), in close proximity to the
DE-CIX. Due to this and the new hardware, latency and performance should
show substantial improvement.
