[Ovmsdev] static IP?
    sharkcow
    sharkcow at gmx.de
    Sat Sep 19 02:50:17 HKT 2020
works perfectly, thanks!
sharkcow
Am 18.09.20 um 18:13 schrieb Michael Balzer:
> Sharkcow,
> see changes.txt:
> - Wifi client: support static IP configuration, manually set or
> automatically applied by SSID
>    New commands:
>      wifi ip static [<ip> <subnet> <gateway>]
>      wifi ip dhcp
>    New configs:
>      wifi.ssid "<ssid>.ovms.staticip" "<ip>,<subnet>,<gateway>"
> Am 18.09.20 um 17:59 schrieb sharkcow:
>> Hi all,
>> is it (easily) possible to configure/compile OVMS with a static WiFi
>> client IP? I searched the sources for "FreeRTOS_IPInit" and looked
>> through the config file, but didn't find anything. (Yes, ideally I
>> should configure my router accordingly, but my current one is too cheap
>> for that :()
>> Thanks!
>> sharkcow
