[Ovmsdev] Reset Standard Metrics on vehicle change
Soko
ovms at soko.cc
Thu Sep 10 20:21:23 HKT 2020
Let's say with the two VWUP it's the first time this use case even makes
sense ;-)
But I will forward him the command, thanks
Soko
On 10.09.2020 14:18, Michael Balzer wrote:
> So you've got a user who switches between two different vehicles without
> taking the module offline?
> Well… that's not actually a common use case, is it? ;-)
> I'd expect a user doing this to know how to do a "metrics persist -r" if
> needed…
> Am 10.09.20 um 14:10 schrieb Soko:
>> Heya,
>> In this particular case:
>> The user changes between VWUP.T26 and VWUP.OBD and was wondering about
>> the weird range metrics...
>> The issue is that OBD doesn't set the range... or T26 doesn't set the
>> voltage. So he is left with values in the metrics although those are
>> not set by the current/active vehicle.
>> Soko
>> On 10.09.2020 14:06, Michael Balzer wrote:
>>> Soko,
>>> what do you mean by vehicle change?
>>> Am 10.09.20 um 13:33 schrieb Soko:
>>>> Hi again,
>>>> Another issue reported is about (persistent) metrics who keep there
>>>> value after vehicle change. First I thought the vehicles need to
>>>> address this. But wouldn't it be better that all standard metrics get
>>>> a reset on every vehicle change?
>>>> Soko
>>>> OvmsDev mailing list
