[Ovmsdev] Reset Standard Metrics on vehicle change
Thu Sep 10 20:18:32 HKT 2020
So you've got a user who switches between two different vehicles without
taking the module offline?
Well… that's not actually a common use case, is it? ;-)
I'd expect a user doing this to know how to do a "metrics persist -r" if
needed…
Am 10.09.20 um 14:10 schrieb Soko:
> Heya,
> In this particular case:
> The user changes between VWUP.T26 and VWUP.OBD and was wondering about
> the weird range metrics...
> The issue is that OBD doesn't set the range... or T26 doesn't set the
> voltage. So he is left with values in the metrics although those are
> not set by the current/active vehicle.
> Soko
> On 10.09.2020 14:06, Michael Balzer wrote:
>> Soko,
>> what do you mean by vehicle change?
>> Am 10.09.20 um 13:33 schrieb Soko:
>>> Hi again,
>>> Another issue reported is about (persistent) metrics who keep there
>>> value after vehicle change. First I thought the vehicles need to
>>> address this. But wouldn't it be better that all standard metrics get
>>> a reset on every vehicle change?
>>> Soko
