[Ovmsdev] Duktape Persistent Function References
Mon Sep 28 15:36:41 HKT 2020
OK, that makes more sense now. I was worried that I messed up the merge somehow.
> On 25 Sep 2020, at 9:34 PM, Michael Balzer <dexter at expeedo.de> wrote:
> I understood I should add the change to std::function in ovms_command only to the for-v3.3 branch, so Chris didn't take that into account yet.
> Am 25.09.20 um 15:22 schrieb Mark Webb-Johnson:
>> Wow. That would have taken me hours to work out. Thanks.
>> Any idea why it compiled in master, but not in for-v3.3?
>>> On 25 Sep 2020, at 9:10 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Mark,
>>> the issue is, there are ambiguous overloads of these methods in their classes, and the compiler doesn't know which one to pick.
>>> - https://stackoverflow.com/questions/10111042/wrap-overloaded-function-via-stdfunction <https://stackoverflow.com/questions/10111042/wrap-overloaded-function-via-stdfunction>
>>> - https://stackoverflow.com/questions/30393285/stdfunction-fails-to-distinguish-overloaded-functions <https://stackoverflow.com/questions/30393285/stdfunction-fails-to-distinguish-overloaded-functions>
>>> I prefer to keep my command stub names distinguished from their implementation counterparts, but apparently that doesn't apply to all of us ;-)
>>> Coming C++ versions may be smart enough to deduce the method to pick from the expected signature.
>>> For now, the compiler needs a hint here. I've added two preprocessor macros to make these hints readable.
>>> Am 25.09.20 um 08:07 schrieb Mark Webb-Johnson:
>>>> @Michael,
>>>> I’ve tried merging this (along with all the other recent changes in master) into the for-v3.3 branch, but am now getting compilation errors. The two files with issues are:
>>>> components/retools_testerpresent/src/retools_testerpresent.cpp
>>>> components/vehicle_mgev/src/vehicle_mgev.cpp
>>>> Both in the RegisterCommand function call with the static class member function as a parameter. Not sure if that new way is used elsewhere?
>>>> Example compiler output is:
>>>> CXX build/retools_testerpresent/src/retools_testerpresent.o
>>>> .../components/retools_testerpresent/src/retools_testerpresent.cpp: In constructor 'OvmsReToolsTesterPresentInit::OvmsReToolsTesterPresentInit()':
>>>> .../components/retools_testerpresent/src/retools_testerpresent.cpp:140:5: error: no matching function for call to 'OvmsCommand::RegisterCommand(const char [6], const char [48], <unresolved overloaded function type>, const char [23], int, int)'
>>>> CXX build/vehicle_mgev/src/vehicle_mgev.o
>>>> .../components/vehicle_mgev/src/vehicle_mgev.cpp: In constructor 'OvmsVehicleMgEv::OvmsVehicleMgEv()':
>>>> .../components/vehicle_mgev/src/vehicle_mgev.cpp:143:5: error: no matching function for call to 'OvmsCommandApp::RegisterCommand(const char [8], const char [15], <unresolved overloaded function type>)'
>>>> ^mand(const char* name, const char* title,
>>>> I tried for a while, but can’t see what is wrong. Perhaps some missing header file? Anyway, I’ve committed the merge of master into for-v3.3 (even though it doesn’t compile) and just commented out those registrations in my local copy.
>>>> Can you help?
>>>> Thanks, Mark.
>>>>> On 12 Sep 2020, at 5:12 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>> Mark,
>>>>> Am 11.09.20 um 18:11 schrieb Michael Balzer:
>>>>>>> I agree it is not necessary; my suggestion is purely to clean it up
>>>>>>> and enhance functionality. The problem at the moment is that
>>>>>>> OvmsCommand execute callbacks can only be to function callbacks (not
>>>>>>> objects). It doesn’t even use the c++ bind function callback
>>>>>>> mechanism (like notification, etc, for example). It is what it is,
>>>>>>> and changing now is very hard.
>>>>>> That slipped my attention, but upgrading OvmsCommand to accept any
>>>>>> function type should be simply changing m_execute and m_validate to
>>>>>> std::function, or do I miss something?
>>>>> Just did this locally, works perfectly. Shall I push the change or have
>>>>> you begun working on ovms_command?
>>>>> If so, it's really just exchanging the function signatures for these types:
>>>>> typedef std::function<void(int, OvmsWriter*, OvmsCommand*, int, const
>>>>> char* const*)> OvmsCommandExecuteCallback_t;
>>>>> typedef std::function<int(OvmsWriter*, OvmsCommand*, int, const char*
>>>>> const*, bool)> OvmsCommandValidateCallback_t;
>>>>> Patch attached.
>>>>> Regards,
>>>>> Michael
>>>>> <ovmscommand.patch>_______________________________________________
>>>>> OvmsDev mailing list
>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200928/05892450/attachment.htm>
