[Ovmsdev] Duktape Persistent Function References
Fri Sep 25 21:34:22 HKT 2020
I understood I should add the change to std::function in ovms_command
only to the for-v3.3 branch, so Chris didn't take that into account yet.
Am 25.09.20 um 15:22 schrieb Mark Webb-Johnson:
> Wow. That would have taken me hours to work out. Thanks.
> Any idea why it compiled in master, but not in for-v3.3?
>> On 25 Sep 2020, at 9:10 PM, Michael Balzer <dexter at expeedo.de
>> Mark,
>> the issue is, there are ambiguous overloads of these methods in their
>> classes, and the compiler doesn't know which one to pick.
>> https://stackoverflow.com/questions/10111042/wrap-overloaded-function-via-stdfunction
>> https://stackoverflow.com/questions/30393285/stdfunction-fails-to-distinguish-overloaded-functions
>> I prefer to keep my command stub names distinguished from their
>> implementation counterparts, but apparently that doesn't apply to all
>> of us ;-)
>> Coming C++ versions may be smart enough to deduce the method to pick
>> from the expected signature.
>> For now, the compiler needs a hint here. I've added two preprocessor
>> macros to make these hints readable.
>> Am 25.09.20 um 08:07 schrieb Mark Webb-Johnson:
>>> @Michael,
>>> I’ve tried merging this (along with all the other recent changes in
>>> master) into the for-v3.3 branch, but am now getting compilation
>>> errors. The two files with issues are:
>>> components/retools_testerpresent/src/retools_testerpresent.cpp
>>> components/vehicle_mgev/src/vehicle_mgev.cpp
>>> Both in the RegisterCommand function call with the static class
>>> member function as a parameter. Not sure if that new way is used
>>> elsewhere?
>>> Example compiler output is:
>>> CXX build/retools_testerpresent/src/retools_testerpresent.o
>>> .../components/retools_testerpresent/src/retools_testerpresent.cpp:
>>> In constructor
>>> 'OvmsReToolsTesterPresentInit::OvmsReToolsTesterPresentInit()':
>>> .../components/retools_testerpresent/src/retools_testerpresent.cpp:140:5:
>>> error: no matching function for call to
>>> 'OvmsCommand::RegisterCommand(const char [6], const char [48],
>>> <unresolved overloaded function type>, const char [23], int, int)'
>>> CXX build/vehicle_mgev/src/vehicle_mgev.o
>>> .../components/vehicle_mgev/src/vehicle_mgev.cpp: In constructor
>>> 'OvmsVehicleMgEv::OvmsVehicleMgEv()':
>>> .../components/vehicle_mgev/src/vehicle_mgev.cpp:143:5: error:
>>> 'OvmsCommandApp::RegisterCommand(const char [8], const char
>>> [15], <unresolved overloaded function type>)'
>>> ^mand(const char* name, const char* title,
>>> I tried for a while, but can’t see what is wrong. Perhaps some
>>> missing header file? Anyway, I’ve committed the merge of master into
>>> for-v3.3 (even though it doesn’t compile) and just commented out
>>> those registrations in my local copy.
>>> Can you help?
>>> Thanks, Mark.
>>>> On 12 Sep 2020, at 5:12 AM, Michael Balzer <dexter at expeedo.de
>>>> Mark,
>>>> Am 11.09.20 um 18:11 schrieb Michael Balzer:
>>>>>> I agree it is not necessary; my suggestion is purely to clean it up
>>>>>> and enhance functionality. The problem at the moment is that
>>>>>> OvmsCommand execute callbacks can only be to function callbacks (not
>>>>>> objects). It doesn’t even use the c++ bind function callback
>>>>>> mechanism (like notification, etc, for example). It is what it is,
>>>>>> and changing now is very hard.
>>>>> That slipped my attention, but upgrading OvmsCommand to accept any
>>>>> function type should be simply changing m_execute and m_validate to
>>>>> std::function, or do I miss something?
>>>> Just did this locally, works perfectly. Shall I push the change or have
>>>> you begun working on ovms_command?
>>>> If so, it's really just exchanging the function signatures for
>>>> these types:
>>>> typedef std::function<void(int, OvmsWriter*, OvmsCommand*, int, const
>>>> char* const*)> OvmsCommandExecuteCallback_t;
>>>> typedef std::function<int(OvmsWriter*, OvmsCommand*, int, const char*
>>>> const*, bool)> OvmsCommandValidateCallback_t;
>>>> Patch attached.
>>>> Regards,
>>>> Michael
>>>> <ovmscommand.patch>_______________________________________________
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200925/b2fcd9b7/attachment-0001.htm>
