[Ovmsdev] OBD/UDS Poller receiver rework
Sun Sep 6 16:03:40 HKT 2020
On a second thought: you don't use the poller at all in the current T26A
e-Up code.
Am 06.09.20 um 09:57 schrieb Michael Balzer:
> Chris,
> did you pull the fix already?
> Also, please enable at least debug logging on the "vehicle" component
> when reporting issues with the poller.
> Thanks,
> Am 06.09.20 um 09:39 schrieb Chris van der Meijden:
>> I see some strange behaviour on the T26A e-Up with the new code. I
>> don't get all values from the bus after a fresh reboot (mostly no
>> VIN, sometimes also no SOC)). I have to sent a wakeup call first:
>> I (160137) ovms-server-v2: Send MP-0
>> S0,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
>> D0,0,5,0,0,0,0,0,0,159,0,0,0,0,11.83,0,12.6,0,0,0,0
>> I (160147) ovms-server-v2: Send MP-0 F3.2.015-42-g2ab8d062/ota_0/main
>> (build idf v3.3.2-881-g22d636b7b Sep 6 2020
>> 09:04:40),,18,1,VWUP.T26,CWLAN
>> I (169127) webserver: HTTP POST /api/execute
>> I (169147) webcommand: HttpCommandStream[0x3f852fcc]: 3964692 bytes
>> free, executing: wakeup
>> I (171147) v-vweup-t26: Sent Wakeup Command - stage 1
>> I (171267) v-vweup-t26: Sent Wakeup Command - stage 2
>> OVMS# wakeup
>> Vehicle has been woken
>> I (193527) v-vweup-t26: Comfort CAN calls for sleep
>> I (221137) ovms-server-v2: Send MP-0
>> S100.0,K,0,0,stopped,standard,260,241,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
>> I (221147) ovms-server-v2: Send MP-0
>> D0,0,5,16,0,0,0,36030,0,220,25,0,1,1,11.47,0,12.6,0,0,0,0
>> I (221147) ovms-server-v2: Send MP-0 F3.2.015-42-g2ab8d062/ota_0/main
>> 09:04:40),xxxxxxxxxxxxxxxx,18,1,VWUP.T26,CWLAN
>> I did not change my code and have never seen this before. Perhaps a
>> problem with the new polling code?
>> Regards
>> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200906/af0b9272/attachment-0001.html>
