[Ovmsdev] OBD/UDS Poller receiver rework
Sun Sep 6 15:57:03 HKT 2020
Chris,
did you pull the fix already?
Also, please enable at least debug logging on the "vehicle" component
when reporting issues with the poller.
Thanks,
Am 06.09.20 um 09:39 schrieb Chris van der Meijden:
> I see some strange behaviour on the T26A e-Up with the new code. I
> don't get all values from the bus after a fresh reboot (mostly no VIN,
> sometimes also no SOC)). I have to sent a wakeup call first:
> I (160137) ovms-server-v2: Send MP-0
> S0,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
> D0,0,5,0,0,0,0,0,0,159,0,0,0,0,11.83,0,12.6,0,0,0,0
> I (160147) ovms-server-v2: Send MP-0 F3.2.015-42-g2ab8d062/ota_0/main
> (build idf v3.3.2-881-g22d636b7b Sep 6 2020
> 09:04:40),,18,1,VWUP.T26,CWLAN
> I (169127) webserver: HTTP POST /api/execute
> I (169147) webcommand: HttpCommandStream[0x3f852fcc]: 3964692 bytes
> free, executing: wakeup
> I (171147) v-vweup-t26: Sent Wakeup Command - stage 1
> I (171267) v-vweup-t26: Sent Wakeup Command - stage 2
> OVMS# wakeup
> Vehicle has been woken
> I (193527) v-vweup-t26: Comfort CAN calls for sleep
> I (221137) ovms-server-v2: Send MP-0
> S100.0,K,0,0,stopped,standard,260,241,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
> I (221147) ovms-server-v2: Send MP-0
> D0,0,5,16,0,0,0,36030,0,220,25,0,1,1,11.47,0,12.6,0,0,0,0
> I (221147) ovms-server-v2: Send MP-0 F3.2.015-42-g2ab8d062/ota_0/main
> 09:04:40),xxxxxxxxxxxxxxxx,18,1,VWUP.T26,CWLAN
> I did not change my code and have never seen this before. Perhaps a
> problem with the new polling code?
> Regards
> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200906/00843d72/attachment.html>
