[Ovmsdev] WiFi connect to non-broadcast SSID broken
Greg D.
gregd2350 at gmail.com
Wed Sep 2 05:25:53 HKT 2020
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200901/d8c36cc5/attachment-0001.html>
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.09.01 13:33:39 =~=~=~=~=~=~=~=~=~=~=~=
OVMS#
[6Cwifi[K
[6Cwifi[K
[6Cwifi mode apclient OVMS Netgear_Guest2[K
[6Cwifi[K
[K[0;32mI (65389854) ovms-server-v2: Send MP-0 S95.0,M,1,0,done,standard,159,148,24,0,0,410,7,4,0,0,0,0,0.00,0,0,0,0,0,0,0,0,0,0,0,0,0.00,0.00,0[0m
[0;32mI (65389864) ovms-server-v2: Send MP-0 D78,128,5,25,24,25,7775,539363,0,65389,24,2,1,1,13.02,0,12.6,0,25,0,0[0m
[0;32mI (65389864) ovms-server-v2: Send MP-0 L38.958851,-121.111031,314,381,1,1,0,7775,0,0.398,0,0[0m
[0;32mI (65389864) ovms-server-v2: Send MP-0 F3.2.014/ota_1/eap (build idf v3.3.2-881-g22d636b Aug 4 2020 16:26:20),5YJRE1A16A1000834,22,1,TR2N,Netgear_Guest2[0m
OVMS# wifi[K
[6Cwifi mode client gregnet 40:b0:76:32:ea:72[K
Starting WIFI as a client to gregnet (40:b0:76:32:ea:72)...
OVMS#
[K[0;32mI (65392534) esp32wifi: Stopping WIFI station[0m
[0;32mI (65392534) netmanager: WIFI client stop[0m
[0;32mI (65392534) netmanager: Interface priority is pp3 (10.52.33.103/255.255.255.255 gateway 10.64.64.64)[0m
[0;32mI (65392534) netmanager: Set DNS#0 9.9.9.9[0m
[0;32mI (65392534) netmanager: Set DNS#1 8.8.8.8[0m
[0;32mI (65392534) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority[0m
I (65392534) wifi:state: run -> init (0)
I (65392544) wifi:pm stop, total sleep time: 627018803 us / 667166463 us
I (65392544) wifi:new:<6,0>, old:<6,0>, ap:<6,2>, sta:<6,0>, prof:1
[0;32mI (65392544) ovms-server-v2: Status: Disconnected[0m
[0;33mW (65392554) netmanager: CleanupConnections: can't get AP station list[0m
I (65392554) wifi:flush txq
I (65392554) wifi:stop sw txq
I (65392554) wifi:lmac stop hw txq
[0;32mI (65392564) time: Network was reconfigured: restarting SNTP client[0m
[0;32mI (65392574) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (65392574) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (65392594) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE[0m
[0;32mI (65392624) netmanager: WIFI access point is down[0m
[0;32mI (65392624) esp32wifi: AP stopped[0m
I (65393074) wifi:mode : sta (30:ae:a4:43:92:88)
OVMS# [K
[K[0;32mI (65395254) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68[0m
I (65395384) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# [K
[KI (65396084) wifi:state: init -> auth (b0)
I (65396094) wifi:state: auth -> assoc (0)
I (65396104) wifi:state: assoc -> run (10)
OVMS# [K
[K[0;32mI (65400944) housekeeping: 2020-09-01 13:33:59 PDT (RAM: 8b=82676-83308 32b=9576)[0m
OVMS# [K
[K[0;32mI (65401854) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B[0m
[0;32mI (65401854) ovms-server-v2: Status: Connecting...[0m
OVMS# [K
[K[0;32mI (65402454) ovms-server-v2: Connection successful[0m
[0;32mI (65402454) ovms-server-v2: Status: Logging in...[0m
[0;32mI (65402454) ovms-server-v2: Sending server login: MP-C 0 3tU3AjUBWDjTegrKhFv8SQ rvrEFsVvIpc1WcPcnFTuAA== ROADSTER834B[0m
OVMS# [K
[KW (65402854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65402854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
[0;32mI (65402974) ovms-server-v2: Got server response: MP-S 0 +8G+EBcHanqxI+T5lvipOU p23wI7eWAhPkK6DU97Iu7A==[0m
[0;32mI (65402974) ovms-server-v2: Server token is +8G+EBcHanqxI+T5lvipOU and digest is p23wI7eWAhPkK6DU97Iu7A==[0m
[0;32mI (65402974) ovms-server-v2: Status: Server authentication ok. Now priming crypto.[0m
[0;32mI (65402974) ovms-server-v2: Shared secret key is +8G+EBcHanqxI+T5lvipOU3tU3AjUBWDjTegrKhFv8SQ (44 bytes)[0m
[0;32mI (65402974) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established[0m
[0;32mI (65402984) ovms-server-v2: Incoming Msg: MP-0 Z0[0m
OVMS# [K
[KI (65404214) wifi:state: run -> init (fc0)
I (65404214) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65404224) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
[0;32mI (65404234) esp32wifi: STA disconnected with reason 15 = 4WAY_HANDSHAKE_TIMEOUT[0m
OVMS# [Kwifi
[K[0;32mI (65414914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68[0m
I (65415034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65415034) wifi:state: init -> auth (b0)
I (65415044) wifi:state: auth -> assoc (0)
I (65415044) wifi:state: assoc -> run (10)
OVMS# wifi[K
Power: on
Mode: Client mode
STA SSID: Netgear_Guest2 (-127.0 dBm) [fixed]
MAC: 00:00:00:00:00:00
IP: 0.0.0.0/0.0.0.0
GW: 0.0.0.0
AP: 00:00:00:00:00:00
OVMS#
[KW (65422854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65422854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
OVMS# [K
[KI (65423144) wifi:state: run -> init (fc0)
I (65423154) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# [K
[6Cwifi[K
[K[0;32mI (65434914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69[0m
I (65435034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65435034) wifi:state: init -> auth (b0)
I (65435034) wifi:state: auth -> assoc (0)
I (65435044) wifi:state: assoc -> run (10)
OVMS# wifi mode client gregnet 40:b0:76:32:ea:72[K
OVMS#
[KI (65437934) wifi:state: run -> init (0)
I (65437934) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
[0;32mI (65437944) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE[0m
OVMS# [K
[K[0;32mI (65452544) event: station ip lost[0m
[0;32mI (65452554) esp32wifi: STA lost IP from SSID 'gregnet' AP 00:00:00:00:00:00[0m
OVMS# [K
[6Cwifi[K
Power: on
Mode: Client mode
STA SSID: gregnet (-127.0 dBm) [fixed]
IP: 0.0.0.0/0.0.0.0
GW: 0.0.0.0
OVMS#
[6Cwifi[K
OVMS#
[6Cwifi[K
Power: on
Mode: Client mode
IP: 0.0.0.0/0.0.0.0
GW: 0.0.0.0
OVMS#
[6Cwifi[K
[6Cwifi[K
[6Cwifi[K
[6Cwifi[K
[6Cwifi[K
Starting WIFI as Access Point and Client...
OVMS#
[K[0;32mI (65544274) esp32wifi: Stopping WIFI station[0m
I (65544284) wifi:flush txq
I (65544284) wifi:stop sw txq
I (65544284) wifi:lmac stop hw txq
I (65544804) wifi:mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89)
I (65544804) wifi:Total power save buffer number: 8
[0;32mI (65544854) netmanager: WIFI access point is up[0m
[0;32mI (65544854) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1[0m
OVMS# [K
[K[0;32mI (65547284) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68[0m
I (65547414) wifi:ap channel adjust o:1,1 n:6,2
I (65547414) wifi:new:<6,0>, old:<1,1>, ap:<6,2>, sta:<6,0>, prof:1
OVMS# [K
[KI (65548114) wifi:state: init -> auth (b0)
I (65548144) wifi:state: auth -> assoc (0)
I (65548144) wifi:state: assoc -> run (10)
I (65548194) wifi:connected with Netgear_Guest2, aid = 1, channel 6, BW20, bssid = 40:b0:76:32:ea:72
I (65548194) wifi:security type: 3, phy: bgn, rssi: -67
I (65548194) wifi:pm start, type: 1
[0;32mI (65548204) esp32wifi: STA connected with SSID: Netgear_Guest2, BSSID: 40:b0:76:32:ea:72, Channel: 6, Auth: WPA2[0m
I (65548354) wifi:AP's beacon interval = 102400 us, DTIM period = 3
OVMS# [K
[K[0;32mI (65549944) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1[0m
[0;32mI (65549964) netmanager: WIFI client got IP[0m
[0;32mI (65549964) esp32wifi: STA got IP with SSID 'Netgear_Guest2' AP 40:b0:76:32:ea:72: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1[0m
[0;32mI (65549994) netmanager: WIFI client has good signal quality (-86.7 dBm); connect[0m
[0;32mI (65549994) netmanager: Interface priority is st21 (10.30.1.105/255.255.255.0 gateway 10.30.1.1)[0m
[0;32mI (65549994) netmanager: Set DNS#0 9.9.9.9[0m
[0;32mI (65549994) netmanager: Set DNS#1 8.8.8.8[0m
[0;32mI (65549994) netmanager: WIFI client up (with MODEM up): reconfigured for WIFI client priority[0m
[0;32mI (65550034) time: Network was reconfigured: restarting SNTP client[0m
[0;32mI (65550034) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (65550034) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (65550044) ovms-server-v2: Status: Disconnected[0m
OVMS# [K
[6Cwifi[K
Power: on
Mode: Access-Point + Client mode
STA SSID: Netgear_Guest2 (-68.2 dBm) [fixed]
IP: 10.30.1.105/255.255.255.0
GW: 10.30.1.1
AP: 40:b0:76:32:ea:72
AP SSID: OVMS
IP: 192.168.4.1
AP Stations: 0
OVMS#
[K[0;32mI (65609854) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B[0m
[0;32mI (65609854) ovms-server-v2: Status: Connecting...[0m
OVMS# [K
[K[0;32mI (65610484) ovms-server-v2: Connection successful[0m
[0;32mI (65610484) ovms-server-v2: Status: Logging in...[0m
[0;32mI (65610484) ovms-server-v2: Sending server login: MP-C 0 ETTIk8+djSnT2pvZkaoXqP noJBBLMTQuDoIULvoK4vaA== ROADSTER834B[0m
OVMS# [K
[K[0;32mI (65610794) ovms-server-v2: Got server response: MP-S 0 ICVwbgzYKsBHB76n8Dhvh0 cDdLQRD5nBdzLGNKZtymRA==[0m
[0;32mI (65610794) ovms-server-v2: Server token is ICVwbgzYKsBHB76n8Dhvh0 and digest is cDdLQRD5nBdzLGNKZtymRA==[0m
[0;32mI (65610804) ovms-server-v2: Status: Server authentication ok. Now priming crypto.[0m
[0;32mI (65610804) ovms-server-v2: Shared secret key is ICVwbgzYKsBHB76n8Dhvh0ETTIk8+djSnT2pvZkaoXqP (44 bytes)[0m
[0;32mI (65610804) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established[0m
[0;32mI (65610824) ovms-server-v2: Incoming Msg: MP-0 Z0[0m
OVMS# [K
[6Cwifi[K
[6Cwifi[K
OVMS#
[K[0;32mI (65626034) esp32wifi: Stopping WIFI station[0m
[0;32mI (65626034) netmanager: WIFI client stop[0m
[0;32mI (65626034) netmanager: Interface priority is pp3 (10.52.33.103/255.255.255.255 gateway 10.64.64.64)[0m
[0;32mI (65626034) netmanager: Set DNS#0 9.9.9.9[0m
[0;32mI (65626034) netmanager: Set DNS#1 8.8.8.8[0m
[0;32mI (65626034) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority[0m
I (65626044) wifi:state: run -> init (0)
I (65626044) wifi:pm stop, total sleep time: 71417171 us / 77847939 us
I (65626044) wifi:new:<6,0>, old:<6,0>, ap:<6,2>, sta:<6,0>, prof:1
[0;32mI (65626054) ovms-server-v2: Status: Disconnected[0m
[0;33mW (65626064) netmanager: CleanupConnections: can't get AP station list[0m
I (65626064) wifi:flush txq
I (65626064) wifi:stop sw txq
I (65626064) wifi:lmac stop hw txq
[0;32mI (65626074) time: Network was reconfigured: restarting SNTP client[0m
[0;32mI (65626074) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (65626074) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (65626094) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE[0m
[0;32mI (65626124) netmanager: WIFI access point is down[0m
[0;32mI (65626124) esp32wifi: AP stopped[0m
I (65626574) wifi:mode : sta (30:ae:a4:43:92:88)
OVMS# [K
[K[0;32mI (65628764) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68[0m
I (65628884) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# [K
[KI (65629594) wifi:state: init -> auth (b0)
I (65629604) wifi:state: auth -> assoc (0)
I (65629614) wifi:state: assoc -> run (10)
OVMS# [K
[KW (65635854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65635854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
[0;32mI (65635854) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B[0m
[0;32mI (65635854) ovms-server-v2: Status: Connecting...[0m
OVMS# [K
[K[0;32mI (65636384) ovms-server-v2: Connection successful[0m
[0;32mI (65636384) ovms-server-v2: Status: Logging in...[0m
[0;32mI (65636384) ovms-server-v2: Sending server login: MP-C 0 fP1CbH+MJWKj2XaEcw8rDr d4NYQ2/bqw445o92cdIQGQ== ROADSTER834B[0m
OVMS# [K
[K[0;32mI (65636904) ovms-server-v2: Got server response: MP-S 0 yEAMezBVOYp1Im8YoKC6lP L5PXJRAw90Ue1YaTrisN0A==[0m
[0;32mI (65636904) ovms-server-v2: Server token is yEAMezBVOYp1Im8YoKC6lP and digest is L5PXJRAw90Ue1YaTrisN0A==[0m
[0;32mI (65636904) ovms-server-v2: Status: Server authentication ok. Now priming crypto.[0m
[0;32mI (65636904) ovms-server-v2: Shared secret key is yEAMezBVOYp1Im8YoKC6lPfP1CbH+MJWKj2XaEcw8rDr (44 bytes)[0m
[0;32mI (65636904) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established[0m
[0;32mI (65636914) ovms-server-v2: Incoming Msg: MP-0 Z0[0m
OVMS# [K
[KI (65637674) wifi:state: run -> init (fc0)
I (65637684) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
[0;32mI (65637694) esp32wifi: STA disconnected with reason 15 = 4WAY_HANDSHAKE_TIMEOUT[0m
OVMS# [K
[K[0;32mI (65647914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68[0m
I (65648034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65648034) wifi:state: init -> auth (b0)
I (65648054) wifi:state: auth -> assoc (0)
I (65648074) wifi:state: assoc -> run (10)
OVMS# [K
[KW (65655854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65655854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
OVMS# [K
[KI (65656434) wifi:state: run -> init (fc0)
I (65656434) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# [K
[K[0;32mI (65667914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-67[0m
I (65668034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65668034) wifi:state: init -> auth (b0)
I (65668044) wifi:state: auth -> assoc (0)
I (65668054) wifi:state: assoc -> run (10)
OVMS# [K
[KW (65675854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65675854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
OVMS# [K
[KI (65676074) wifi:state: run -> init (fc0)
I (65676074) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# [K
[K[0;32mI (65686054) event: station ip lost[0m
[0;32mI (65686064) esp32wifi: STA lost IP from SSID 'Netgear_Guest2' AP 00:00:00:00:00:00[0m
OVMS# [K
[K[0;32mI (65687914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69[0m
I (65688034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65688034) wifi:state: init -> auth (b0)
I (65688044) wifi:state: auth -> assoc (0)
I (65688054) wifi:state: assoc -> run (10)
OVMS# [Kwi
[KW (65695854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65695854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
OVMS# wi[K
[KI (65696154) wifi:state: run -> init (fc0)
I (65696164) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# wi[K
Power: on
Mode: Client mode
IP: 0.0.0.0/0.0.0.0
GW: 0.0.0.0
OVMS#
[K[0;32mI (65700934) housekeeping: 2020-09-01 13:38:59 PDT (RAM: 8b=82204-83048 32b=9576)[0m
OVMS# [K
[K[0;32mI (65707914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69[0m
I (65708034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65708034) wifi:state: init -> auth (b0)
I (65708034) wifi:state: auth -> assoc (0)
I (65708044) wifi:state: assoc -> run (10)
OVMS# [K
[KW (65715854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65715854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
OVMS# [K
[KI (65716224) wifi:state: run -> init (fc0)
I (65716224) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# [K
[6Cwi[K
Power: on
Mode: Client mode
IP: 0.0.0.0/0.0.0.0
GW: 0.0.0.0
OVMS#
[K[0;32mI (65727914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69[0m
I (65728034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65728034) wifi:state: init -> auth (b0)
I (65728034) wifi:state: auth -> assoc (0)
I (65728054) wifi:state: assoc -> run (10)
OVMS# [K
[KW (65735854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65735854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
OVMS# [K
[KI (65736084) wifi:state: run -> init (fc0)
I (65736094) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# [K
[K[0;32mI (65747914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-68[0m
I (65748034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65748034) wifi:state: init -> auth (b0)
I (65748034) wifi:state: auth -> assoc (0)
I (65748054) wifi:state: assoc -> run (10)
OVMS# [K
[KW (65755854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65755854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
OVMS# [K
[KI (65756134) wifi:state: run -> init (fc0)
I (65756134) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS# [K
[6Cwi[K
Power: on
Mode: Client mode
IP: 0.0.0.0/0.0.0.0
GW: 0.0.0.0
OVMS#
[6Cwi[K
[6Cwi[K
[6Cwi[K
[K[0;32mI (65767914) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-69[0m
I (65768034) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
I (65768034) wifi:state: init -> auth (b0)
I (65768064) wifi:state: auth -> assoc (0)
I (65768074) wifi:state: assoc -> run (10)
[6Cwifi[K
[KW (65775854) wifi:sta_scan: STA is connecting, scan are not allowed!
[0;31mE (65775854) esp32wifi: StartConnect: error 0xffffffff starting scan[0m
OVMS# wifi mode apclient OVMS Netgear_Guest2[K
[KI (65776184) wifi:state: run -> init (fc0)
I (65776184) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1
OVMS#
[K[0;32mI (65783094) esp32wifi: Stopping WIFI station[0m
I (65783104) wifi:flush txq
I (65783104) wifi:stop sw txq
I (65783104) wifi:lmac stop hw txq
I (65783624) wifi:mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89)
I (65783634) wifi:Total power save buffer number: 8
[0;32mI (65783674) netmanager: WIFI access point is up[0m
[0;32mI (65783674) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1[0m
OVMS# [K
[K[0;32mI (65786114) esp32wifi: ScanDone: connect to ssid='Netgear_Guest2' bssid='40:b0:76:32:ea:72' chan=6 rssi=-67[0m
I (65786234) wifi:ap channel adjust o:1,1 n:6,2
I (65786234) wifi:new:<6,0>, old:<1,1>, ap:<6,2>, sta:<6,0>, prof:1
OVMS# [K
[KI (65786944) wifi:state: init -> auth (b0)
I (65786954) wifi:state: auth -> assoc (0)
I (65786964) wifi:state: assoc -> run (10)
I (65787004) wifi:connected with Netgear_Guest2, aid = 1, channel 6, BW20, bssid = 40:b0:76:32:ea:72
I (65787004) wifi:security type: 3, phy: bgn, rssi: -67
I (65787004) wifi:pm start, type: 1
I (65787014) wifi:AP's beacon interval = 102400 us, DTIM period = 3
[0;32mI (65787024) esp32wifi: STA connected with SSID: Netgear_Guest2, BSSID: 40:b0:76:32:ea:72, Channel: 6, Auth: WPA2[0m
[0;32mI (65787044) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1[0m
[0;32mI (65787064) netmanager: WIFI client got IP[0m
[0;32mI (65787064) esp32wifi: STA got IP with SSID 'Netgear_Guest2' AP 40:b0:76:32:ea:72: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1[0m
OVMS# [K
[K[0;32mI (65788854) netmanager: WIFI client has good signal quality (-86.3 dBm); connect[0m
[0;32mI (65788864) netmanager: Interface priority is st24 (10.30.1.105/255.255.255.0 gateway 10.30.1.1)[0m
[0;32mI (65788864) netmanager: Set DNS#0 9.9.9.9[0m
[0;32mI (65788864) netmanager: Set DNS#1 8.8.8.8[0m
[0;32mI (65788864) netmanager: WIFI client up (with MODEM up): reconfigured for WIFI client priority[0m
[0;32mI (65788904) time: Network was reconfigured: restarting SNTP client[0m
[0;32mI (65788904) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (65788904) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (65789034) ovms-server-v2: Status: Disconnected[0m
OVMS# [K
[6Cwi[K
Power: on
STA SSID: Netgear_Guest2 (-68.1 dBm) [fixed]
GW: 10.30.1.1
AP SSID: OVMS
IP: 192.168.4.1
AP Stations: 0
OVMS#
[6C[K
[6C[K
